GSOC 2015: Raspberry Pi Low Level Peripherals and SD Card
    Gedare Bloom
    gedare at rtems.org
    Wed Mar 25 14:17:51 UTC 2015
On Wed, Mar 25, 2015 at 4:49 AM, André Marques
<andre.lousa.marques at gmail.com> wrote:
> Hello everyone,
> My GSoC proposal entitled "Raspberry Pi Low Level Peripherals and SD Card"
> can be found for review at:
> https://docs.google.com/document/d/11K0qU3OsbSMhNYkTTWt4kitAbd6uuJBcMfA_07Lg6j8
> One issue I would like to discuss here is related to the SD card support,
> which as exposed on the proposal the GPIOs to which the SD card is connected
> internally do not have SPI hardware capabilities, meaning that to access the
> card via SPI mode it would have to be bit-banged on those GPIOs (a problem
> on performance). This is more detailed on the proposal, but another
> alternative would be to use the SD mode instead, with the help of the PI's
> EMMC module, and the SD simplified specifications as documentation for the
> SD protocol. I have already used this setup with success in the past, and it
> should have better performance. In this setup the FreeBSD SD/MMC stack may
> be used (such as the one Sebastian Huber ported last year ->
> https://git.rtems.org/sebh/rtems-libusb.git/tree/rtems/freebsd/dev/mmc?id=3c82a1500da3192de2504a1360e065fd84a1f3a0)
Is this code in the libbsd.git now?
> which implements the SD protocol also based on the simplified specs. This
> would help avoiding implementing the protocol from scratch (which is sort of
> what I did in my previous effort with the SD card and the PI) and would be
> better for maintenance probably.
> My issue is then on the feasibily (licence wise) of having the FreeBSD SD
> stack or having code based on the SD Simplified Specs on the RTEMS tree.
FreeBSD code should be fine. The complexity of getting libbsd working
could be the real stumbling block. But I think others will be working
on the same problem too, so there may be some ability to share
knowledge.
> In SPI mode an implementation of the protocol can be found in
> libchip/i2c/spi-sd-card.*, which could in that case be used/improved further
> during the project, if it is decided it is best to use SPI mode. This uses
> the libi2c API, which is deprecated for I2C but, as I understand, still
> stands as the API for SPI (information about that would also be
> appreciated).
It's just the no one has replaced it yet! There seem to be multiple
efforts going on now to get more driver-like frameworks into RTEMS.
> Thanks,
> André Marques.
> devel mailing list
> devel at rtems.org
