[PATCH 12/42] libcrypt/crypt-md5.c: Fix overflow issues
Daniel Gutson
daniel.gutson at tallertechnologies.com
Thu Mar 26 03:24:54 UTC 2015
El 25/03/2015 21:41, "Joel Sherrill" <joel.sherrill at oarcorp.com> escribió:
> On March 24, 2015 8:37:57 AM CDT, Daniel Gutson <
daniel.gutson at tallertechnologies.com> wrote:
> >In order to avoid code duplication and ease future bugfixing, I suggest
> >to have a conditional casting and leave the core code alone, something
> >like
> >#ifdef __rtems__
> >#define cast(x) ((unsigned long int)x)
> >#else
> >#define cast(x) (x)
> >#endif
> >...cast(final[ 0] << 16)...
> >#undef cast
> Good suggestion. The big concern is really just making sure changes made
to the imported code is clear. I suppose this does it as well.
Is this really RTEMS-specific? If it isn't, what about contributing it to
the original code?
> >El 23/03/2015 11:52, "Joel Sherrill" <joel.sherrill at oarcorp.com>
> >escribió:
> > cpukit/libcrypt/crypt-md5.c | 12 ++++++++++++
> > 1 file changed, 12 insertions(+)
> >diff --git a/cpukit/libcrypt/crypt-md5.c b/cpukit/libcrypt/crypt-md5.c
> >index c60dcf8..78ae0bc 100644
> >--- a/cpukit/libcrypt/crypt-md5.c
> >+++ b/cpukit/libcrypt/crypt-md5.c
> >@@ -133,6 +133,17 @@ crypt_md5_r(const char *pw, const char *salt,
> >struct crypt_data *data)
> > p = passwd + strlen(passwd);
> >+#if defined(__rtems__)
> >+ l = ((long int) final[ 0]<<16) | ((long int) final[ 6]<<8) |
> >final[12];
> >+ _crypt_to64(p, l, 4); p += 4;
> >+ l = ((long int) final[ 1]<<16) | ((long int) final[ 7]<<8) |
> >final[13];
> >+ l = ((long int) final[ 2]<<16) | ((long int) final[ 8]<<8) |
> >final[14];
> >+ l = ((long int) final[ 3]<<16) | ((long int) final[ 9]<<8) |
> >final[15];
> >+ l = ((long int) final[ 4]<<16) | ((long int) final[10]<<8) |
> >final[ 5];
> >+#else
> > l = (final[ 0]<<16) | (final[ 6]<<8) | final[12];
> > l = (final[ 1]<<16) | (final[ 7]<<8) | final[13];
> >@@ -142,6 +153,7 @@ crypt_md5_r(const char *pw, const char *salt,
> > l = (final[ 3]<<16) | (final[ 9]<<8) | final[15];
> > l = (final[ 4]<<16) | (final[10]<<8) | final[ 5];
> >+#endif
> > l = final[11];
> > _crypt_to64(p, l, 2); p += 2;
> >1.9.3
> >_______________________________________________
> >devel mailing list
> >devel at rtems.org
> >http://lists.rtems.org/mailman/listinfo/devel
> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150326/21afbade/attachment.html>
