[PATCH 1/2] Add rtems-tester configurations for simsh family of BSPs
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Mar 26 18:22:02 UTC 2015
tester/rtems/testing/bsps/simsh1-run.mc | 54 ++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh1.mc | 56 ++++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh2-run.mc | 54 ++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh2.mc | 56 ++++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh2e-run.mc | 54 ++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh2e.mc | 56 ++++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh4-run.mc | 54 ++++++++++++++++++++++++++++++
tester/rtems/testing/bsps/simsh4.mc | 56 ++++++++++++++++++++++++++++++++
8 files changed, 440 insertions(+)
create mode 100644 tester/rtems/testing/bsps/simsh1-run.mc
create mode 100644 tester/rtems/testing/bsps/simsh1.mc
create mode 100644 tester/rtems/testing/bsps/simsh2-run.mc
create mode 100644 tester/rtems/testing/bsps/simsh2.mc
create mode 100644 tester/rtems/testing/bsps/simsh2e-run.mc
create mode 100644 tester/rtems/testing/bsps/simsh2e.mc
create mode 100644 tester/rtems/testing/bsps/simsh4-run.mc
create mode 100644 tester/rtems/testing/bsps/simsh4.mc
diff --git a/tester/rtems/testing/bsps/simsh1-run.mc b/tester/rtems/testing/bsps/simsh1-run.mc
new file mode 100644
index 0000000..2defb72
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh1-run.mc
@@ -0,0 +1,54 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2015 On-Line Applications Research Corporation (OAR).
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# All paths in defaults must be Unix format. Do not store any Windows format
+# paths in the defaults.
+# Every entry must describe the type of checking a host must pass.
+# Records:
+# key: type, attribute, value
+# type : none, dir, exe, triplet
+# attribute: none, required, optional
+# value : 'single line', '''multi line'''
+# The simsh1 BSP
+[global]
+bsp: none, none, 'simsh1'
+[simsh1]
+simsh1: none, none, '%{_rtscripts}/run.cfg'
+simsh1_arch: none, none, 'sh'
+bsp_run_cmd: none, none, '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
+bsp_run_opts: none, none, '-a -nouartrx'
diff --git a/tester/rtems/testing/bsps/simsh1.mc b/tester/rtems/testing/bsps/simsh1.mc
index 0000000..5c6bdaf
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh1.mc
@@ -0,0 +1,56 @@
+# Records:
+# The simsh1 BSP
+[global]
+[simsh1]
+simsh1: none, none, '%{_rtscripts}/gdb.cfg'
+gdb_script: none, none, 'simsh1_gdb_script'
+simsh1_gdb_script: none, none, '''target sim
+ load
+ run'''
diff --git a/tester/rtems/testing/bsps/simsh2-run.mc b/tester/rtems/testing/bsps/simsh2-run.mc
index 0000000..1b42af9
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh2-run.mc
@@ -0,0 +1,54 @@
+# Records:
+# The simsh2 BSP
+[global]
+bsp: none, none, 'simsh2'
+[simsh2]
+simsh2: none, none, '%{_rtscripts}/run.cfg'
+simsh2_arch: none, none, 'sh'
diff --git a/tester/rtems/testing/bsps/simsh2.mc b/tester/rtems/testing/bsps/simsh2.mc
index 0000000..3ad164d
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh2.mc
@@ -0,0 +1,56 @@
+# Records:
+# The simsh2 BSP
+[global]
+[simsh2]
+simsh2: none, none, '%{_rtscripts}/gdb.cfg'
+gdb_script: none, none, 'simsh2_gdb_script'
+simsh2_gdb_script: none, none, '''target sim
+ load
+ run'''
diff --git a/tester/rtems/testing/bsps/simsh2e-run.mc b/tester/rtems/testing/bsps/simsh2e-run.mc
index 0000000..e04181a
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh2e-run.mc
@@ -0,0 +1,54 @@
+# Records:
+# The simsh2e BSP
+[global]
+bsp: none, none, 'simsh2e'
+[simsh2e]
+simsh2e: none, none, '%{_rtscripts}/run.cfg'
+simsh2e_arch: none, none, 'sh'
diff --git a/tester/rtems/testing/bsps/simsh2e.mc b/tester/rtems/testing/bsps/simsh2e.mc
index 0000000..e9e0c8b
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh2e.mc
@@ -0,0 +1,56 @@
+# Records:
+# The simsh2e BSP
+[global]
+[simsh2e]
+simsh2e: none, none, '%{_rtscripts}/gdb.cfg'
+gdb_script: none, none, 'simsh2e_gdb_script'
+simsh2e_gdb_script: none, none, '''target sim
+ load
+ run'''
diff --git a/tester/rtems/testing/bsps/simsh4-run.mc b/tester/rtems/testing/bsps/simsh4-run.mc
index 0000000..832dabd
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh4-run.mc
@@ -0,0 +1,54 @@
+# Records:
+# The simsh4 BSP
+[global]
+bsp: none, none, 'simsh4'
+[simsh4]
+simsh4: none, none, '%{_rtscripts}/run.cfg'
+simsh4_arch: none, none, 'sh'
diff --git a/tester/rtems/testing/bsps/simsh4.mc b/tester/rtems/testing/bsps/simsh4.mc
index 0000000..fdaae81
--- /dev/null
+++ b/tester/rtems/testing/bsps/simsh4.mc
@@ -0,0 +1,56 @@
+# Records:
+# The simsh4 BSP
+[global]
+[simsh4]
+simsh4: none, none, '%{_rtscripts}/gdb.cfg'
+gdb_script: none, none, 'simsh4_gdb_script'
+simsh4_gdb_script: none, none, '''target sim
+ load
+ run'''
1.9.3
