[PATCH 1/2] Add rtems-tester configurations for simsh family of BSPs
Gedare Bloom gedare at gwu.edu
Thu Mar 26 18:24:16 UTC 2015
I guess you ran it? Could you post your results when you commit it. :)
On Thu, Mar 26, 2015 at 2:22 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  tester/rtems/testing/bsps/simsh1-run.mc  | 54 ++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh1.mc      | 56 ++++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh2-run.mc  | 54 ++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh2.mc      | 56 ++++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh2e-run.mc | 54 ++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh2e.mc     | 56 ++++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh4-run.mc  | 54 ++++++++++++++++++++++++++++++
>  tester/rtems/testing/bsps/simsh4.mc      | 56 ++++++++++++++++++++++++++++++++
>  8 files changed, 440 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/simsh1-run.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh1.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh2-run.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh2.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh2e-run.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh2e.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh4-run.mc
>  create mode 100644 tester/rtems/testing/bsps/simsh4.mc
> diff --git a/tester/rtems/testing/bsps/simsh1-run.mc b/tester/rtems/testing/bsps/simsh1-run.mc
> new file mode 100644
> index 0000000..2defb72
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh1-run.mc
> @@ -0,0 +1,54 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2015 On-Line Applications Research Corporation (OAR).
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# All paths in defaults must be Unix format. Do not store any Windows format
> +# paths in the defaults.
> +# Every entry must describe the type of checking a host must pass.
> +# Records:
> +#  key: type, attribute, value
> +#   type     : none, dir, exe, triplet
> +#   attribute: none, required, optional
> +#   value    : 'single line', '''multi line'''
> +# The simsh1 BSP
> +[global]
> +bsp:              none,    none,     'simsh1'
> +[simsh1]
> +simsh1:              none,    none,     '%{_rtscripts}/run.cfg'
> +simsh1_arch:         none,    none,     'sh'
> +bsp_run_cmd:      none,    none,     '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
> +bsp_run_opts:     none,    none,     '-a -nouartrx'
> diff --git a/tester/rtems/testing/bsps/simsh1.mc b/tester/rtems/testing/bsps/simsh1.mc
> index 0000000..5c6bdaf
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh1.mc
> @@ -0,0 +1,56 @@
> +# Records:
> +# The simsh1 BSP
> +[global]
> +[simsh1]
> +simsh1:                 none,    none,     '%{_rtscripts}/gdb.cfg'
> +gdb_script:          none,    none,     'simsh1_gdb_script'
> +simsh1_gdb_script:      none,    none,     '''target sim
> +                                           load
> +                                           run'''
> diff --git a/tester/rtems/testing/bsps/simsh2-run.mc b/tester/rtems/testing/bsps/simsh2-run.mc
> index 0000000..1b42af9
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh2-run.mc
> @@ -0,0 +1,54 @@
> +# Records:
> +# The simsh2 BSP
> +[global]
> +bsp:              none,    none,     'simsh2'
> +[simsh2]
> +simsh2:              none,    none,     '%{_rtscripts}/run.cfg'
> +simsh2_arch:         none,    none,     'sh'
> diff --git a/tester/rtems/testing/bsps/simsh2.mc b/tester/rtems/testing/bsps/simsh2.mc
> index 0000000..3ad164d
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh2.mc
> @@ -0,0 +1,56 @@
> +# Records:
> +# The simsh2 BSP
> +[global]
> +[simsh2]
> +simsh2:                 none,    none,     '%{_rtscripts}/gdb.cfg'
> +gdb_script:          none,    none,     'simsh2_gdb_script'
> +simsh2_gdb_script:      none,    none,     '''target sim
> +                                           load
> +                                           run'''
> diff --git a/tester/rtems/testing/bsps/simsh2e-run.mc b/tester/rtems/testing/bsps/simsh2e-run.mc
> index 0000000..e04181a
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh2e-run.mc
> @@ -0,0 +1,54 @@
> +# Records:
> +# The simsh2e BSP
> +[global]
> +bsp:              none,    none,     'simsh2e'
> +[simsh2e]
> +simsh2e:              none,    none,     '%{_rtscripts}/run.cfg'
> +simsh2e_arch:         none,    none,     'sh'
> diff --git a/tester/rtems/testing/bsps/simsh2e.mc b/tester/rtems/testing/bsps/simsh2e.mc
> index 0000000..e9e0c8b
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh2e.mc
> @@ -0,0 +1,56 @@
> +# Records:
> +# The simsh2e BSP
> +[global]
> +[simsh2e]
> +simsh2e:                 none,    none,     '%{_rtscripts}/gdb.cfg'
> +gdb_script:          none,    none,     'simsh2e_gdb_script'
> +simsh2e_gdb_script:      none,    none,     '''target sim
> +                                           load
> +                                           run'''
> diff --git a/tester/rtems/testing/bsps/simsh4-run.mc b/tester/rtems/testing/bsps/simsh4-run.mc
> index 0000000..832dabd
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh4-run.mc
> @@ -0,0 +1,54 @@
> +# Records:
> +# The simsh4 BSP
> +[global]
> +bsp:              none,    none,     'simsh4'
> +[simsh4]
> +simsh4:              none,    none,     '%{_rtscripts}/run.cfg'
> +simsh4_arch:         none,    none,     'sh'
> diff --git a/tester/rtems/testing/bsps/simsh4.mc b/tester/rtems/testing/bsps/simsh4.mc
> index 0000000..fdaae81
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/simsh4.mc
> @@ -0,0 +1,56 @@
> +# Records:
> +# The simsh4 BSP
> +[global]
> +[simsh4]
> +simsh4:                 none,    none,     '%{_rtscripts}/gdb.cfg'
> +gdb_script:          none,    none,     'simsh4_gdb_script'
> +simsh4_gdb_script:      none,    none,     '''target sim
> +                                           load
> +                                           run'''
> 1.9.3
> devel mailing list
> devel at rtems.org
