Tracing task id.
Fri Mar 27 05:41:10 UTC 2015
On 27/03/2015 12:47 am, Joel Sherrill wrote:
> On 03/26/2015 08:41 AM, Gedare Bloom wrote:
>> There are unused fields in the (32-bit) Objects_Id, but none are
>> "reserved". Currently only 2-bits of the API are used, although 4 bits
>> are available. Also, if you're not using RTEMS_MULTIPROCESSING, I
>> guess none of the node bits are used.
> Look at _Objects_Get. The way an ID is converted to a pointer
> assumes the ID is within a certain numeric range. The node
> number could be repurposed but we would have to be careful
> not to break this and would also have to be careful for
> calls like rtems_task_self() and pthread_self().
> You want this to work in all configurations. I would propose
> considering cutting the node number down to a smaller
> number of bits and masking those out in _Thread_Get()
> and the methods that return the current ID. We would
> really have to be careful about fetching a thread ID though
> to ensure that the variable field doesn't get in the way
> of the constant use.
This is just for the trace data and not for use in the target. It might
not be that useful after all. In the latest trace buffer generator I
pushed I need record the current/real priority and task state (not sure
about this one) which is a bunch more bits I need anyway so I can use
some available ones there.
