[PATCH] TMS570: Enable FPU in makefile.
Martin Galvan martin.galvan at tallertechnologies.com
Fri Mar 27 12:31:55 UTC 2015
On Thu, Mar 26, 2015 at 6:46 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
> Hello Martin,
> this is the right and planned change.
> What are your results of testing the BSP?
> Are there some stability issues or your combination
> with HALcogen code and FPU passes tests suites.
Thanks for the feedback. From what we saw this works fine as long as
you also use these patches:
https://git.rtems.org/rtems/commit?id=dc9aaf7ced34501d7647a86b4c626c9cc056db01
https://git.rtems.org/rtems/commit?id=991fdb330be81c5cfb47f67fd032569809db6c41
These enable the FPU and initialize the core and FP registers, which
is needed by the TMS570's CCM.
> On Thursday 26 of March 2015 21:21:26 Martin Galvan wrote:
>>  c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg | 2 +-
>>  1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
>> b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg index
>> e90414a..869cf71 100644
>> --- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
>> +++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
>> @@ -6,7 +6,7 @@ include $(RTEMS_ROOT)/make/custom/default.cfg
>>  RTEMS_CPU = arm
>> -CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian
>> +CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian -mfpu=vfpv3-d16
>> -mfloat-abi=hard
>>  CFLAGS_OPTIMIZE_V = -O2 -ggdb
>>  BINEXT?=.bin
Martin Galvan
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
