[PATCH] TMS570: Add board reset code to bsp_reset
Gedare Bloom gedare at gwu.edu
Fri Mar 27 13:21:39 UTC 2015
It looks good to me I'll try to get to it if Sebastian doesn't. -Gedare
On Thu, Mar 26, 2015 at 4:16 PM, Martin Galvan
<martin.galvan at tallertechnologies.com> wrote:
>  c/src/lib/libbsp/arm/tms570/include/tms570.h   | 19 +++++++------
>  c/src/lib/libbsp/arm/tms570/startup/bspreset.c | 37 ++++++++++++++++----------
>  2 files changed, 34 insertions(+), 22 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/tms570/include/tms570.h b/c/src/lib/libbsp/arm/tms570/include/tms570.h
> index 2023a29..50f1315 100644
> --- a/c/src/lib/libbsp/arm/tms570/include/tms570.h
> +++ b/c/src/lib/libbsp/arm/tms570/include/tms570.h
> @@ -7,15 +7,9 @@
> - * Copyright (c) 2014 Premysl Houdek <kom541000 at gmail.com>
> + * Copyright (c) 2015 Taller Technologies.
> - * Google Summer of Code 2014 at
> - * Czech Technical University in Prague
> - * Zikova 1903/4
> - * 166 36 Praha 6
> - * Czech Republic
> - * Based on LPC24xx and LPC1768 BSP
> + * @author Martin Galvan <martin.galvan at tallertechnologies.com>
>   * The license and distribution terms for this file may be
>   * found in the file LICENSE in this distribution or at
> @@ -25,4 +19,13 @@
>  #ifndef LIBBSP_ARM_TMS570_H
>  #define LIBBSP_ARM_TMS570_H
> +#define SYSECR (*(uint32_t *)0xFFFFFFE0u) /* System Exception Control Register */
> +#define ESMIOFFHR (*(uint32_t *)0xFFFFF528) /* ESM Interrupt Offset High Register */
> +#define ESMSR1 (*(uint32_t *)0xFFFFF518u) /* ESM Status Register 1 */
> +#define ESMSR2 (*(uint32_t *)0xFFFFF51Cu) /* ESM Status Register 2 */
> +#define ESMSR3 (*(uint32_t *)0xFFFFF520u) /* ESM Status Register 3 */
> +#define ESMSR4 (*(uint32_t *)0xFFFFF558u) /* ESM Status Register 4 */
> +#define SYSECR_RESET 0x80000u
>  #endif /* LIBBSP_ARM_TMS570_H */
> diff --git a/c/src/lib/libbsp/arm/tms570/startup/bspreset.c b/c/src/lib/libbsp/arm/tms570/startup/bspreset.c
> index d47920c..a4b6647 100644
> --- a/c/src/lib/libbsp/arm/tms570/startup/bspreset.c
> +++ b/c/src/lib/libbsp/arm/tms570/startup/bspreset.c
> @@ -7,30 +7,39 @@
> - * Zikova 1903/4
> - * 166 36 Praha 6
> - * Czech Republic
>   * http://www.rtems.org/license/LICENSE.
> -#include <rtems.h>
> -#include <bsp/bootcard.h>
> +#include <bsp.h>
>  #include <bsp/tms570.h>
>  #include <bsp/start.h>
> -BSP_START_TEXT_SECTION __attribute__( ( flatten ) ) void bsp_reset( void )
> +static void handle_esm_errors(uint32_t esm_irq_channel)
> +  /* ESMR3 errors don't generate interrupts. */
> +  if (esm_irq_channel < 0x20u) {
> +    ESMSR1 = 1 << esm_irq_channel;
> +  } else if (esm_irq_channel < 0x40u) {
> +    ESMSR2 = 1 << (esm_irq_channel - 32u);
> +  } else if (esm_irq_channel < 0x60u) {
> +    ESMSR4 = 1 << (esm_irq_channel - 64u);
> +void bsp_reset(void)
> -  while ( true ) {
> -    /* Do nothing */
> +  uint32_t esm_irq_channel = ESMIOFFHR - 1;
> +  if (esm_irq_channel) {
> +    handle_esm_errors(esm_irq_channel);
> +  /* Reset the board */
> +  SYSECR = SYSECR_RESET;
> 2.3.4
> devel mailing list
> devel at rtems.org
