[PATCH] libmisc/shell: Add the rtrace command for buffered tracing support.
Chris Johns
chrisj at rtems.org
Sun Mar 29 07:54:57 UTC 2015
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
cpukit/Makefile.am | 5 +
cpukit/libmisc/Makefile.am | 5 +-
cpukit/libmisc/capture/rtems-trace-buffer-vars.c | 178 ++++++
cpukit/libmisc/capture/rtems-trace-buffer-vars.h | 147 +++++
cpukit/libmisc/shell/main_rtrace.c | 676 +++++++++++++++++++++++
cpukit/libmisc/shell/shellconfig.h | 10 +
cpukit/preinstall.am | 9 +
7 files changed, 1028 insertions(+), 2 deletions(-)
create mode 100644 cpukit/libmisc/capture/rtems-trace-buffer-vars.c
create mode 100644 cpukit/libmisc/capture/rtems-trace-buffer-vars.h
create mode 100644 cpukit/libmisc/shell/main_rtrace.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 10b59db..7df116c 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -172,6 +172,11 @@ include_rtems_HEADERS += libmisc/capture/capture.h
include_rtems_HEADERS += libmisc/capture/capture-cli.h
include_rtems_HEADERS += libmisc/capture/captureimpl.h
+# tracing headers
+include_rtems_tracedir = $(include_rtemsdir)/trace
+include_rtems_trace_HEADERS =
+include_rtems_trace_HEADERS += libmisc/capture/rtems-trace-buffer-vars.h
## cpuuse
include_rtems_HEADERS += libmisc/cpuuse/cpuuse.h
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index f09b69d..ac703ad 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -21,7 +21,8 @@ libcapture_a_SOURCES = capture/capture.c capture/capture-cli.c \
capture/capture_user_extension.c capture/capture_buffer.c \
capture/capture_support.c \
capture/capture.h capture/captureimpl.h capture/capture-cli.h \
- capture/capture_buffer.h
+ capture/capture_buffer.h \
+ capture/rtems-trace-buffer-vars.c capture/rtems-trace-buffer-vars.h
## cpuuse
EXTRA_DIST += cpuuse/README
@@ -108,7 +109,7 @@ libshell_a_SOURCES = shell/cat_file.c shell/cmds.c shell/internal.h \
shell/main_setenv.c shell/main_getenv.c shell/main_unsetenv.c \
shell/main_mkrfs.c shell/main_debugrfs.c shell/main_df.c \
shell/main_lsof.c shell/main_edit.c \
- shell/main_blkstats.c \
+ shell/main_blkstats.c shell/main_rtrace.c \
shell/shell-wait-for-input.c
libshell_a_SOURCES += shell/main_cmdls.c
libshell_a_SOURCES += shell/main_cmdchown.c
diff --git a/cpukit/libmisc/capture/rtems-trace-buffer-vars.c b/cpukit/libmisc/capture/rtems-trace-buffer-vars.c
new file mode 100644
index 0000000..92054bf
--- /dev/null
+++ b/cpukit/libmisc/capture/rtems-trace-buffer-vars.c
@@ -0,0 +1,178 @@
+ * Copyright (c) 2015 Chris Johns <chrisj at rtems.org>
+#include <rtems.h>
+#include <rtems/trace/rtems-trace-buffer-vars.h>
+ * External Trace Linker and TBG data. We provide weak versions to allow us to
+ * link and be present in an application that has not been trace linked.
+ * Trace linker data.
+uint32_t __rtld_trace_names_size __attribute__ ((weak));
+const char const* __rtld_trace_names[1] __attribute__ ((weak));
+uint32_t __rtld_trace_enables_size __attribute__ ((weak));
+const uint32_t __rtld_trace_enables[1] __attribute__ ((weak));
+uint32_t __rtld_trace_triggers_size __attribute__ ((weak));
+const uint32_t __rtld_trace_triggers[1] __attribute__ ((weak));
+const __rtld_trace_sig __rtld_trace_signatures[1] __attribute__ ((weak));
+ * Trace buffer generator data.
+const bool __rtld_tbg_present __attribute__ ((weak));
+const uint32_t __rtld_tbg_mode __attribute__ ((weak));
+const uint32_t __rtld_tbg_buffer_size __attribute__ ((weak));
+uint32_t __rtld_tbg_buffer[1] __attribute__ ((weak));
+volatile uint32_t __rtld_tbg_buffer_in __attribute__ ((weak));
+volatile bool __rtld_tbg_finished __attribute__ ((weak));
+volatile bool __rtld_tbg_triggered __attribute__ ((weak));
+uint32_t
+rtems_trace_names_size (void)
+ return __rtld_trace_names_size;
+const char*
+rtems_trace_names (const uint32_t index)
+ return __rtld_trace_names[index];
+uint32_t
+rtems_trace_enables_size (void)
+ return __rtld_trace_enables_size;
+uint32_t
+rtems_trace_enables (const uint32_t index)
+ return __rtld_trace_enables[index];
+uint32_t
+rtems_trace_triggers_size (void)
+ return __rtld_trace_triggers_size;
+uint32_t
+rtems_trace_triggers (const uint32_t index)
+ return __rtld_trace_triggers[index];
+const rtems_trace_sig*
+rtems_trace_signatures (const uint32_t index)
+ return &__rtld_trace_signatures[index];
+bool
+rtems_trace_enable_set(const uint32_t index)
+ return (__rtld_trace_enables[index / 32] & (1 << (index & (32 - 1)))) != 0 ? true : false;
+bool
+rtems_trace_trigger_set(const uint32_t index)
+ return (__rtld_trace_triggers[index / 32] & (1 << (index & (32 - 1)))) != 0 ? true : false;
+bool
+rtems_trace_tbg_present (void)
+ return __rtld_tbg_present;
+uint32_t
+rtems_trace_tbg_mode (void)
+ return __rtld_tbg_mode;
+uint32_t
+rtems_trace_tbg_buffer_size (void)
+ return __rtld_tbg_buffer_size;
+uint32_t*
+rtems_trace_tbg_buffer (void)
+ return &__rtld_tbg_buffer[0];
+uint32_t
+rtems_trace_tbg_buffer_in (void)
+ rtems_interrupt_lock_context lcontext;
+ uint32_t in;
+ rtems_interrupt_lock_acquire(&__rtld_tbg_lock, &lcontext);
+ in = __rtld_tbg_buffer_in;
+ rtems_interrupt_lock_release(&__rtld_tbg_lock, &lcontext);
+ return in;
+bool
+rtems_trace_tbg_finished (void)
+ bool finished;
+ finished = __rtld_tbg_finished;
+ return finished;
+bool
+rtems_trace_tbg_triggered (void)
+ bool triggered;
+ triggered = __rtld_tbg_triggered;
+ return triggered;
+void
+rtems_trace_tbg_start (void)
+ __rtld_tbg_triggered = false;
+ __rtld_tbg_buffer_in = 0;
+ __rtld_tbg_finished = false;
+void
+rtems_trace_tbg_stop (void)
+ __rtld_tbg_finished = true;
+void
+rtems_trace_tbg_resume (void)
diff --git a/cpukit/libmisc/capture/rtems-trace-buffer-vars.h b/cpukit/libmisc/capture/rtems-trace-buffer-vars.h
index 0000000..eab19ee
--- /dev/null
+++ b/cpukit/libmisc/capture/rtems-trace-buffer-vars.h
@@ -0,0 +1,147 @@
+ * @file
+ * @ingroup Shell
+ * @brief Access to the RTEMS Trace Buffer Generator.
+#if !defined (_RTEMS_TRACE_BUFFER_VARS_H_)
+#define _RTEMS_TRACE_BUFFER_VARS_H_
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * These functions are provided as a separated interface to the TBG data are
+ * not really designed for any real-time performance type interface.
+ * Separating the data from the codes stops the compiler incorrectly loop
+ * optimising.
+typedef struct
+ uint32_t size;
+ const char* const type;
+} __rtld_trace_sig_arg;
+ typedef struct {
+ uint32_t argc;
+ const __rtld_trace_sig_arg* args;
+} __rtld_trace_sig;
+typedef __rtld_trace_sig_arg rtems_trace_sig_arg;
+typedef __rtld_trace_sig rtems_trace_sig;
+ * Returns the number of trace functions.
+uint32_t rtems_trace_names_size (void);
+ * Return the name given an index. No range checking.
+const char* rtems_trace_names (const uint32_t index);
+ * Returns the number of words in the enables array.
+uint32_t rtems_trace_enables_size (void);
+ * Return the enable 32bit bitmap indexed into the enables array. No range
+ * checking.
+uint32_t rtems_trace_enables (const uint32_t index);
+ * Returns the number of words in the triggers array.
+uint32_t rtems_trace_triggers_size (void);
+ * Return the trigger 32bit bitmap indexed into the triggers array. No range
+ * checking.
+uint32_t rtems_trace_triggers (const uint32_t index);
+ * Return the trace function signature.
+const rtems_trace_sig* rtems_trace_signatures (const uint32_t index);
+ * Return true is the enable bit is set for the trace function index.
+bool rtems_trace_enable_set(const uint32_t index);
+ * Return true is the trigger bit is set for the trace function index.
+bool rtems_trace_trigger_set(const uint32_t index);
+ * The application has been linked with Trace Buffering generated code.
+bool rtems_trace_tbg_present (void);
+ * Return the TBG mode flags.
+uint32_t rtems_trace_tbg_mode (void);
+ * Return the size of the TBG buffer in words.
+uint32_t rtems_trace_tbg_buffer_size (void);
+ * Return the base of the TBG buffer.
+uint32_t* rtems_trace_tbg_buffer (void);
+ * Return the buffer level. This is only stable if tracing has finished.
+uint32_t rtems_trace_tbg_buffer_in (void);
+ * The tracing has finished.
+bool rtems_trace_tbg_finished (void);
+ * Trace has been triggered and enable trace functions are being recorded.
+bool rtems_trace_tbg_triggered (void);
+ * Start tracing by clearing the triggered flag, setting to 0 and clearing the
+ * finished flag.
+void rtems_trace_tbg_start (void);
+ * Stop tracing by setting the finished flag.
+void rtems_trace_tbg_stop (void);
+ * Resume tracing by setting the finished flag.
+void rtems_trace_tbg_resume (void);
+#ifdef __cplusplus
+#endif
diff --git a/cpukit/libmisc/shell/main_rtrace.c b/cpukit/libmisc/shell/main_rtrace.c
index 0000000..2410398
--- /dev/null
+++ b/cpukit/libmisc/shell/main_rtrace.c
@@ -0,0 +1,676 @@
+#include <ctype.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <inttypes.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <sys/types.h>
+#include <time.h>
+#include <unistd.h>
+#include <rtems/shell.h>
+ * The type of the shell handlers we have.
+typedef int (*rtems_tbg_shell_handler_t) (int argc, char *argv[]);
+ * Table of handlers we parse to invoke the command.
+typedef struct
+ const char* name; /**< The sub-command's name. */
+ rtems_tbg_shell_handler_t handler; /**< The sub-command's handler. */
+ const char* help; /**< The sub-command's help. */
+} rtems_tbg_shell_cmd_t;
+static int
+rtems_tbg_wrong_number_of_args (void)
+ printf ("error: wrong number of arguments\n");
+ return 1;
+static int
+rtems_tbg_invalid_args (const char* arg)
+ printf ("error: invalid argument: %s\n", arg);
+ return 1;
+static int
+rtems_tbg_no_trace_buffer_code (void)
+ printf("No trace buffer generated code in the application; see rtems-tld\n");
+ return 1;
+static void
+rtems_tbg_banner (const char* label)
+ printf("RTEMS Trace Bufferring: %s\n", label);
+static void
+rtems_tbg_print_timestamp (uint64_t uptime)
+ uint32_t hours;
+ uint32_t minutes;
+ uint32_t seconds;
+ uint32_t nanosecs;
+ uint64_t up_secs;
+ up_secs = uptime / 1000000000LLU;
+ minutes = up_secs / 60;
+ hours = minutes / 60;
+ minutes = minutes % 60;
+ seconds = up_secs % 60;
+ nanosecs = uptime % 1000000000;
+ printf ("%5" PRIu32 ":%02" PRIu32 ":%02" PRIu32".%09" PRIu32,
+ hours, minutes, seconds, nanosecs);
+static int
+rtems_tbg_shell_status (int argc, char *argv[])
+ uint32_t buffer_size;
+ uint32_t buffer_in;
+ bool finished;
+ bool triggered;
+ uint32_t names;
+ if (argc != 1)
+ return rtems_tbg_wrong_number_of_args ();
+ if (!rtems_trace_tbg_present ())
+ return rtems_tbg_no_trace_buffer_code ();
+ buffer_size = rtems_trace_tbg_buffer_size ();
+ buffer_in = rtems_trace_tbg_buffer_in ();
+ finished = rtems_trace_tbg_finished ();
+ triggered = rtems_trace_tbg_triggered ();
+ names = rtems_trace_names_size ();
+ rtems_tbg_banner ("status");
+ printf(" Running: %s\n", finished ? "no" : "yes");
+ printf(" Triggered: %s\n", triggered ? "yes" : "no");
+ printf(" Level: %3lu%%\n", (buffer_in * 100) / buffer_size);
+ printf(" Traces: %4lu\n", names);
+ return 0;
+static int
+rtems_tbg_shell_funcs (int argc, char *argv[])
+ size_t traces = rtems_trace_names_size ();
+ size_t t;
+ size_t max = 0;
+ if (argc != 1)
+ rtems_tbg_banner ("trace functions");
+ printf(" Total: %4zu\n", traces);
+ for (t = 0; t < traces; ++t)
+ size_t l = strlen (rtems_trace_names (t));
+ if (l > max)
+ max = l;
+ printf(" %4zu: %c%c %-*s\n", t,
+ rtems_trace_enable_set(t) ? 'E' : '-',
+ rtems_trace_trigger_set(t) ? 'T' : '-',
+ max, rtems_trace_names (t));
+ return 0;
+static int
+rtems_tbg_shell_start (int argc, char *argv[])
+ if (argc != 1)
+ rtems_tbg_banner ("resume");
+ if (!rtems_trace_tbg_finished ())
+ printf("already running\n");
+ return 0;
+ rtems_trace_tbg_start ();
+ return 0;
+static int
+rtems_tbg_shell_stop (int argc, char *argv[])
+ if (argc != 1)
+ rtems_tbg_banner ("stop");
+ if (rtems_trace_tbg_finished ())
+ printf("already stopped\n");
+ return 0;
+ rtems_trace_tbg_stop ();
+ return 0;
+static int
+rtems_tbg_shell_resume (int argc, char *argv[])
+ if (argc != 1)
+ return 0;
+ return 0;
+static void rtems_tbg_print_arg (const rtems_trace_sig_arg* arg,
+ const uint8_t* argv)
+ if (arg->size)
+ union
+ uint8_t bytes[sizeof (uint64_t)];
+ uint16_t u16;
+ uint32_t u32;
+ uint64_t u64;
+ void* pointer;
+ } variable;
+ if (arg->size <= sizeof(uint64_t))
+ memcpy (&variable.bytes[0], argv, arg->size);
+ printf ("(%s) ", arg->type);
+ if (strchr (arg->type, '*') != NULL)
+ printf ("%p", variable.pointer);
+ else
+ size_t b;
+ switch (arg->size)
+ case 2:
+ printf ("%04x", variable.u16);
+ break;
+ case 4:
+ printf ("%08lx", variable.u32);
+ break;
+ case 8:
+ printf ("%016llx", variable.u64);
+ break;
+ default:
+ for (b = 0; b < arg->size; ++b)
+ printf ("%02x", (unsigned int) *argv++);
+ break;
+static int
+rtems_tbg_shell_trace (int argc, char *argv[])
+ uint32_t* trace_buffer;
+ uint32_t records;
+ uint32_t traces;
+ uint32_t r = 0;
+ size_t lines = 40;
+ size_t count = 0;
+ uint64_t last_sample = 0;
+ trace_buffer = rtems_trace_tbg_buffer ();
+ records = rtems_trace_tbg_buffer_in ();
+ traces = rtems_trace_names_size ();
+ if (argc > 1)
+ if (argc > 3)
+ if (argv[1][0] == '+')
+ if (argc > 2)
+ lines = strtoul (argv[1] + 1, 0, 0);
+ if (lines == 0)
+ printf("error: invalid number of lines\n");
+ return 1;
+ else
+ r = strtoul (argv[1], 0, 0);
+ if (r >= records)
+ printf ("error: start record out of range (max %lu)\n", records);
+ return 1;
+ if (argc == 3)
+ if (argv[2][0] == '+')
+ lines = strtoul (argv[2] + 1, 0, 0);
+ if (lines == 0)
+ return 1;
+ else
+ lines = strtoul (argv[2], 0, 0);
+ if (lines < r)
+ printf ("error: end record before start\n");
+ return 1;
+ else if (lines > records)
+ printf ("error: end record out of range (max %lu)\n", records);
+ lines = lines - r;
+ rtems_tbg_banner ("trace");
+ printf("tracing still running\n");
+ return 0;
+ if (argc > 1)
+ lines = strtoul (argv[1], 0, 0);
+ if (lines == 0)
+ return rtems_tbg_invalid_args (argv[1]);
+ printf(" Trace buffer: %p\n", trace_buffer);
+ printf(" Words traced: %lu\n", records);
+ printf(" Traces: %lu\n", traces);
+ r = 0;
+ while ((r < records) && ((lines == 0) || (count < lines)))
+ const uint32_t header = trace_buffer[r];
+ const uint32_t func_index = header & 0xffff;
+ const uint32_t len = (header >> 16) & 0x0fff;
+ const uint32_t task_id = trace_buffer[r + 1];
+ const uint32_t task_status = trace_buffer[r + 2];
+ const uint64_t when = (((uint64_t) trace_buffer[r + 4]) << 32) | trace_buffer[r + 5];
+ const uint8_t* argv = (uint8_t*) &trace_buffer[r + 6];
+ const bool ret = (header & (1 << 30)) == 0 ? false : true;
+ const bool irq = (header & (1 << 31)) == 0 ? false : true;
+ const rtems_trace_sig* sig = rtems_trace_signatures (func_index);
+ rtems_tbg_print_timestamp (when);
+ printf (" %10lu %c%08lx [%3lu/%3lu] %c %s",
+ (uint32_t) (when - last_sample),
+ irq ? '*' : ' ', task_id, (task_status >> 8) & 0xff, task_status & 0xff,
+ ret ? '<' : '>', rtems_trace_names (func_index));
+ if (sig->argc)
+ if (ret)
+ if (sig->args[0].size)
+ printf(" => ");
+ rtems_tbg_print_arg (&sig->args[0], argv);
+ else
+ size_t a;
+ printf("(");
+ for (a = 1; a < sig->argc; ++a)
+ if (a > 1)
+ printf (", ");
+ rtems_tbg_print_arg (&sig->args[a], argv);
+ argv += sig->args[a].size;
+ printf(")");
+ printf("\n");
+ r += ((len - 1) / sizeof (uint32_t)) + 1;
+ last_sample = when;
+ ++count;
+ return 0;
+static ssize_t
+rtems_tbg_file_write (int out, const void* vbuffer, ssize_t length)
+ const uint8_t* buffer = vbuffer;
+ while (length)
+ ssize_t w = write (out, buffer, length);
+ if (w < 0)
+ printf ("error: write failed: %s\n", strerror(errno));
+ return false;
+ if (w == 0)
+ printf ("error: write failed: EOF\n");
+ return false;
+ length -= w;
+ buffer += w;
+ return true;
+static int
+rtems_tbg_shell_save (int argc, char *argv[])
+ uint32_t records;
+ uint32_t traces;
+ uint8_t* buffer;
+ size_t length;
+ uint32_t r;
+ int out;
+ uint8_t* buf;
+ uint8_t* in;
+ if (argc != 2)
+ return 0;
+ printf(" Trace File: %s\n", argv[1]);
+ out = open (argv[1], O_WRONLY | O_TRUNC | O_CREAT,
+ S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH | S_IWOTH);
+ if (out < 0)
+ printf ("error: opening file: %s: %s\n", argv[1], strerror(errno));
+ return 1;
+ #define SAVE_BUF_SIZE (1024)
+ buf = malloc(SAVE_BUF_SIZE);
+ if (!buf)
+ close (out);
+ printf ("error: no memory\n");
+ memset (buf, 0, SAVE_BUF_SIZE);
+ in = buf;
+ * Header label.
+ memcpy (in, "RTEMS-TRACE", sizeof("RTEMS-TRACE"));
+ in += 12;
+ * Endian detection.
+ *((uint32_t*) in) = 0x11223344;
+ in += sizeof(uint32_t);
+ * Number of traces.
+ *((uint32_t*) in) = traces;
+ * Write it.
+ if (!rtems_tbg_file_write (out, buf, in - buf))
+ free (buf);
+ close (out);
+ return 1;
+ * The trace names.
+ for (r = 0; r < traces; ++r)
+ const char* name = rtems_trace_names (r);
+ if (!rtems_tbg_file_write (out, name, strlen (name) + 1))
+ free (buf);
+ close (out);
+ return 1;
+ * The trace signatures.
+ const rtems_trace_sig* sig = rtems_trace_signatures (r);
+ size_t s;
+ in = buf;
+ *((uint32_t*) in) = sig->argc;
+ for (s = 0; s < sig->argc; ++s)
+ const rtems_trace_sig_arg* arg = &sig->args[s];
+ size_t arg_len = strlen (arg->type) + 1;
+ if ((in - buf) > SAVE_BUF_SIZE)
+ printf ("error: save temp buffer to small\n");
+ free (buf);
+ close (out);
+ return 1;
+ *((uint32_t*) in) = arg->size;
+ memcpy (in, arg->type, arg_len);
+ in += arg_len;
+ free (buf);
+ close (out);
+ return 1;
+ free (buf);
+ buffer = (uint8_t*) trace_buffer;
+ length = records * sizeof (uint32_t);
+ while (length)
+ if (w < 0)
+ close (out);
+ return 1;
+ if (w == 0)
+ close (out);
+ return 1;
+ length -= w;
+ buffer += w;
+ close (out);
+ return 0;
+void
+rtems_tbg_shell_usage (const char* arg)
+ printf ("%s: Trace Buffer Help\n", arg);
+ printf (" %s [-hl] <command>\n", arg);
+ printf (" where:\n");
+ printf (" command: The TBG subcommand. See -l for a list plus help.\n");
+ printf (" -h: This help\n");
+ printf (" -l: The command list.\n");
+static const rtems_tbg_shell_cmd_t table[] =
+ { "status", rtems_tbg_shell_status, " : Show the current status" },
+ { "funcs", rtems_tbg_shell_funcs, " : List the trace functions" },
+ { "start", rtems_tbg_shell_start, " : Start or restart tracing" },
+ { "stop", rtems_tbg_shell_stop, " : Stop tracing" },
+ { "resume", rtems_tbg_shell_resume, " : Resume tracing." },
+ { "trace", rtems_tbg_shell_trace, " [start] [end/+length] : List the current trace records" },
+ { "save", rtems_tbg_shell_save, " file : Save the trace buffer to a file" },
+#define RTEMS_TBG_COMMANDS (sizeof (table) / sizeof (const rtems_tbg_shell_cmd_t))
+static int
+rtems_shell_main_rtrace (int argc, char* argv[])
+ int arg;
+ size_t t;
+ for (arg = 1; arg < argc; arg++)
+ if (argv[arg][0] != '-')
+ break;
+ switch (argv[arg][1])
+ case 'h':
+ rtems_tbg_shell_usage (argv[0]);
+ return 0;
+ case 'l':
+ printf ("%s: commands are:\n", argv[0]);
+ for (t = 0; t < RTEMS_TBG_COMMANDS; ++t)
+ printf (" %-7s %s\n", table[t].name, table[t].help);
+ return 0;
+ default:
+ printf ("error: unknown option: %s\n", argv[arg]);
+ return 1;
+ if ((argc - arg) < 1)
+ printf ("error: you need to provide a command, try %s -h\n", argv[0]);
+ else
+ if (strncmp (argv[arg], table[t].name, strlen (argv[arg])) == 0)
+ int r = table[t].handler (argc - arg, argv + 1);
+ return r;
+ printf ("error: command not found: %s (try -h)\n", argv[arg]);
+ return 1;
+rtems_shell_cmd_t rtems_shell_RTRACE_Command = {
+ "rtrace", /* name */
+ "rtrace [-l]", /* usage */
+ "misc", /* topic */
+ rtems_shell_main_rtrace, /* command */
+ NULL, /* alias */
+ NULL /* next */
diff --git a/cpukit/libmisc/shell/shellconfig.h b/cpukit/libmisc/shell/shellconfig.h
index 2e52a92..9023a60 100644
--- a/cpukit/libmisc/shell/shellconfig.h
+++ b/cpukit/libmisc/shell/shellconfig.h
@@ -87,6 +87,7 @@ extern rtems_shell_cmd_t rtems_shell_PERIODUSE_Command;
extern rtems_shell_cmd_t rtems_shell_PROFREPORT_Command;
extern rtems_shell_cmd_t rtems_shell_WKSPACE_INFO_Command;
extern rtems_shell_cmd_t rtems_shell_MALLOC_INFO_Command;
+extern rtems_shell_cmd_t rtems_shell_RTRACE_Command;
#if RTEMS_NETWORKING
extern rtems_shell_cmd_t rtems_shell_IFCONFIG_Command;
extern rtems_shell_cmd_t rtems_shell_ROUTE_Command;
@@ -464,6 +465,15 @@ extern rtems_shell_alias_t * const rtems_shell_Initial_aliases[];
#endif
+ * Tracing family commands
+ #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
+ !defined(CONFIGURE_SHELL_NO_COMMAND_RTRACE)) || \
+ defined(CONFIGURE_SHELL_COMMAND_RTRACE)
+ &rtems_shell_RTRACE_Command,
+ #endif
* Network related commands
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 63e3903..40273bb 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -423,6 +423,15 @@ $(PROJECT_INCLUDE)/rtems/captureimpl.h: libmisc/capture/captureimpl.h $(PROJECT_
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/captureimpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/captureimpl.h
+$(PROJECT_INCLUDE)/rtems/trace/$(dirstamp):
+ @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/trace
+ @: > $(PROJECT_INCLUDE)/rtems/trace/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/trace/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/trace/rtems-trace-buffer-vars.h: libmisc/capture/rtems-trace-buffer-vars.h $(PROJECT_INCLUDE)/rtems/trace/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/trace/rtems-trace-buffer-vars.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/trace/rtems-trace-buffer-vars.h
$(PROJECT_INCLUDE)/rtems/cpuuse.h: libmisc/cpuuse/cpuuse.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/cpuuse.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/cpuuse.h
2.3.0
