rtems tester all fails on xilinx_zynq_a9_qemu
Mon Mar 30 00:00:33 UTC 2015
On 30/03/2015 7:56 am, Joel Sherrill wrote:
> Hi
> Even hello fails with both.exe and .ralf files. Something
> is fundamentally wrong here. I assume it is the rtems-tester
> configuration since it runs with the sim-script. And
> it runs with the same qemu command by hand.
> Ideas?
What is the sim-script command line ?
> ~/rtems-4.11-work/rtems-tools/tester/rtems-test
> --rtems-tools=/users/joel/rtems-4.11-work/tools/
> --rtems-bsp=xilinx_zynq_a9_qemu `find . -name hello.ralf`
> RTEMS Testing - Tester, v0.2.0
>  Command Line: /users/joel/rtems-4.11-work/rtems-tools/tester/rtems-test
> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.ralf
>  Python: 2.7.5 (default, Nov  3 2014, 14:26:24) [GCC 4.8.3 20140911 (Red
> Hat 4.8.3-7)]
> [1/1] p:0 f:0 t:0 i:0 | arm/xilinx_zynq_a9_qemu: hello.ralf
>> run: qemu-system-arm -no-reboot -monitor none -serial stdio -nographic
> -net none -M xilinx-zynq-a9 -m 256M -kernel
> ] Warning: nic cadence_gem.0 has no peer
> ] Warning: nic cadence_gem.1 has no peer
> Result: invalid    Time: 0:00:01.008064
> Passed:   0
> Failed:   0
> Timeouts: 0
> Invalid:  1
> Total:    1
> Invalid:
>  hello.ralf
> Average test time: 0:00:01.503241
> Testing time     : 0:00:01.503241
> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ xilinx_zynq_a9_qemu^C
> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ type qemu-system-arm
> qemu-system-arm is /users/joel/rtems-4.11-work/tools/bin/qemu-system-arm
> devel mailing list
> devel at rtems.org
