rtems tester all fails on xilinx_zynq_a9_qemu
Mon Mar 30 00:09:30 UTC 2015
On 03/29/2015 07:00 PM, Chris Johns wrote:
> On 30/03/2015 7:56 am, Joel Sherrill wrote:
>> Hi
>> Even hello fails with both.exe and .ralf files. Something
>> is fundamentally wrong here. I assume it is the rtems-tester
>> configuration since it runs with the sim-script. And
>> it runs with the same qemu command by hand.
>> Ideas?
> What is the sim-script command line ?
qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none
-nographic -M xilinx-zynq-a9 -m 256M -kernel
./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
> Chris
>> ~/rtems-4.11-work/rtems-tools/tester/rtems-test
>> --rtems-tools=/users/joel/rtems-4.11-work/tools/
>> --rtems-bsp=xilinx_zynq_a9_qemu `find . -name hello.ralf`
>> RTEMS Testing - Tester, v0.2.0
>>   Command Line: /users/joel/rtems-4.11-work/rtems-tools/tester/rtems-test
>> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.ralf
>>   Python: 2.7.5 (default, Nov  3 2014, 14:26:24) [GCC 4.8.3 20140911 (Red
>> Hat 4.8.3-7)]
>> [1/1] p:0 f:0 t:0 i:0 | arm/xilinx_zynq_a9_qemu: hello.ralf
>>> run: qemu-system-arm -no-reboot -monitor none -serial stdio -nographic
>> -net none -M xilinx-zynq-a9 -m 256M -kernel
>> ] Warning: nic cadence_gem.0 has no peer
>> ] Warning: nic cadence_gem.1 has no peer
>> Result: invalid    Time: 0:00:01.008064
>> Passed:   0
>> Failed:   0
>> Timeouts: 0
>> Invalid:  1
>> Total:    1
>> Invalid:
>>   hello.ralf
>> Average test time: 0:00:01.503241
>> Testing time     : 0:00:01.503241
>> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ xilinx_zynq_a9_qemu^C
>> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ type qemu-system-arm
>> qemu-system-arm is /users/joel/rtems-4.11-work/tools/bin/qemu-system-arm
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
-- Joel Sherrill
Ask me about RTEMS: a free RTOS
Support and Training Available
