rtems tester all fails on xilinx_zynq_a9_qemu
Mon Mar 30 00:16:19 UTC 2015
On 30/03/2015 11:09 am, Joel Sherrill wrote:
> On 03/29/2015 07:00 PM, Chris Johns wrote:
>> On 30/03/2015 7:56 am, Joel Sherrill wrote:
>>> Hi
>>> Even hello fails with both.exe and .ralf files. Something
>>> is fundamentally wrong here. I assume it is the rtems-tester
>>> configuration since it runs with the sim-script. And
>>> it runs with the same qemu command by hand.
>>> Ideas?
>> What is the sim-script command line ?
> qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none
> -nographic -M xilinx-zynq-a9 -m 256M -kernel
> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.exe
Who's qemu are you using ?
Does '-serial mon:stdio' also work with rtems-tester ?
If it does which is the "standard" and documented version ? This stuff
in qemu has not been 100% consistent.
>> Chris
>>> ~/rtems-4.11-work/rtems-tools/tester/rtems-test
>>> --rtems-tools=/users/joel/rtems-4.11-work/tools/
>>> --rtems-bsp=xilinx_zynq_a9_qemu `find . -name hello.ralf`
>>> RTEMS Testing - Tester, v0.2.0
>>>   Command Line:
>>> /users/joel/rtems-4.11-work/rtems-tools/tester/rtems-test
>>> ./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.ralf
>>>   Python: 2.7.5 (default, Nov  3 2014, 14:26:24) [GCC 4.8.3 20140911
>>> (Red
>>> Hat 4.8.3-7)]
>>> [1/1] p:0 f:0 t:0 i:0 | arm/xilinx_zynq_a9_qemu: hello.ralf
>>>> run: qemu-system-arm -no-reboot -monitor none -serial stdio -nographic
>>> -net none -M xilinx-zynq-a9 -m 256M -kernel
>>> ] Warning: nic cadence_gem.0 has no peer
>>> ] Warning: nic cadence_gem.1 has no peer
>>> Result: invalid    Time: 0:00:01.008064
>>> Passed:   0
>>> Failed:   0
>>> Timeouts: 0
>>> Invalid:  1
>>> Total:    1
>>> Invalid:
>>>   hello.ralf
>>> Average test time: 0:00:01.503241
>>> Testing time     : 0:00:01.503241
>>> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ xilinx_zynq_a9_qemu^C
>>> [joel at rtbf64a b-xilinx_zynq_a9_qemu]$ type qemu-system-arm
>>> qemu-system-arm is /users/joel/rtems-4.11-work/tools/bin/qemu-system-arm
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
