[rtems-graphic-toolkit] version problem with microwin
Mon Mar 30 00:31:59 UTC 2015
On March 29, 2015 7:21:08 PM CDT, QIAO YANG <yangqiao0505 at me.com> wrote:
>On Mar 30, 2015, at 06:54 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
>wrote:
>On 3/29/2015 5:38 PM, QIAO YANG wrote:
>Hi,
>I've tried to compile the rgt for pc386. But I can't get the right
>version of microwin , not from the upstream nor from the alex-sever's
>fork.
>>> Unable to checkout
>'6b5dae5cdbc334ac1c3210bc2c4918668cb42aa4' in submodule path 'microwin'
>Has anyone succeed to compile it recently ? Or maybe I've missed
>anything.
>I cloned the master when you were asking about it.
>Change the git clone as needed in the script to git (hehehe) to clone.
>I didn't noticed the file README.Microwindows  .
>While, I've just retried with the latest from git, and the latest
>release version,  but always end up with the same build error:
>>>...........  /microwin/src/engine/image_png.c:35:27: error:
>dereferencing pointer to incomplete type
>  GdImageBufferRead(pstruct->io_ptr, pointer, size);
>This error will produce since 01/2010
>With the earlier version, I've got error:
>     >> rmdir fail to remove freetype/internal, directory doesn't exist
>Which version have you used without error?  I doubt that if it's the
>microwins version problem. Can we see anything from it?
I haven't built this recently. The issues just need to be fixed.
I was only referring to issues obtaining the source.
>Joel Sherrill, Ph.D. Director of Research & Development
>joel.sherrill at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Support Available (256) 722-9985
--joel
