realview_pbx_a9_qemu test results
Mon Mar 30 18:27:19 UTC 2015
----- Joel Sherrill <joel.sherrill at oarcorp.com> schrieb:
> Hi
> Test results for the arm/realview:
> sp69 runs by hand OK. Not sure why it reported failure.
sp69 is a very brittle test.  I depends on small timing margins and this is a problem on Qemu.
> Passed:   510
> Failed:     2
> Timeouts:   9
> Invalid:    0
> Total:    521
> Failures:
>   sp69.exe
>   heapwalk.exe
Is this with debugging enabled?  It should not fail if debugging is disabled.
> Timeouts:
>   spintrcritical06.exe
>   spintrcritical15.exe
>   spintrcritical12.exe
>   spintrcritical07.exe
>   spintrcritical20.exe
>   psxintrcritical01.exe
>   spintrcritical18.exe
>   spintrcritical14.exe
>   spintrcritical11.exe
This is a problem of the Qemu simulator.
> Average test time: 0:00:01.577968
> Testing time     : 0:13:42.121793
> devel mailing list
> devel at rtems.org
