[PATCH 5/5] score: Use _Thread_Clear_state() for _Thread_Ready
Tue Mar 31 06:00:07 UTC 2015
 cpukit/score/Makefile.am                      |  2 +-
 cpukit/score/include/rtems/score/statesimpl.h |  3 +++
 cpukit/score/include/rtems/score/threadimpl.h | 31 ++++++++++++----------
 cpukit/score/src/threadready.c                | 38 ---------------------------
 4 files changed, 21 insertions(+), 53 deletions(-)
 delete mode 100644 cpukit/score/src/threadready.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 090f7f6..53b5cbf 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -284,7 +284,7 @@ libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
     src/threaddelayended.c src/threaddispatch.c \
     src/threadenabledispatch.c src/threaddisabledispatch.c \
     src/threadget.c src/threadhandler.c src/threadinitialize.c \
-    src/threadloadenv.c src/threadready.c \
+    src/threadloadenv.c \
     src/threadrestart.c src/threadsetpriority.c \
     src/threadsetstate.c \
     src/threadstackallocate.c src/threadstackfree.c src/threadstart.c \
diff --git a/cpukit/score/include/rtems/score/statesimpl.h b/cpukit/score/include/rtems/score/statesimpl.h
index 4251b3c..074b352 100644
--- a/cpukit/score/include/rtems/score/statesimpl.h
+++ b/cpukit/score/include/rtems/score/statesimpl.h
@@ -118,6 +118,9 @@ extern "C" {
                                  STATES_WAITING_ON_THREAD_QUEUE | \
                                  STATES_INTERRUPTIBLE_BY_SIGNAL )
+/** All state bits set to one (provided for _Thread_Ready()) */
+#define STATES_ALL_SET 0xffffffff
  * This function sets the given states_to_set into the current_state
  * passed in.  The result is returned to the user in current_state.
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index fa4e434..94a19f5 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -227,37 +227,40 @@ void _Thread_Kill_zombies( void );
 void _Thread_Close( Thread_Control *the_thread, Thread_Control *executing );
- *  @brief Removes any set states for @a the_thread.
+ *  @brief Clears the indicated STATES for @a the_thread.
- *  This routine removes any set states for @a the_thread.  It performs
+ *  This routine clears the indicated STATES for @a the_thread.  It performs
  *  any necessary scheduling operations including the selection of
  *  a new heir thread.
+ *  @return The previous state.
  *  - INTERRUPT LATENCY:
- *    + ready chain
+ *    + priority map
  *    + select heir
-void _Thread_Ready(
-  Thread_Control *the_thread
+States_Control _Thread_Clear_state(
+  Thread_Control *the_thread,
+  States_Control  state
- *  @brief Clears the indicated STATES for @a the_thread.
+ *  @brief Removes any set states for @a the_thread.
- *  This routine clears the indicated STATES for @a the_thread.  It performs
+ *  This routine removes any set states for @a the_thread.  It performs
- *  @return The previous state.
- *    + priority map
+ *    + ready chain
  *    + select heir
-States_Control _Thread_Clear_state(
-  Thread_Control *the_thread,
-  States_Control  state
+RTEMS_INLINE_ROUTINE void _Thread_Ready(
+  _Thread_Clear_state( the_thread, STATES_ALL_SET );
  *  @brief Sets the indicated @a state for @a the_thread.
diff --git a/cpukit/score/src/threadready.c b/cpukit/score/src/threadready.c
deleted file mode 100644
index 5375294..0000000
--- a/cpukit/score/src/threadready.c
+++ /dev/null
@@ -1,38 +0,0 @@
- *  @file
- *  @brief Thread Ready
- *  @ingroup ScoreThread
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/score/threadimpl.h>
-#include <rtems/score/isrlevel.h>
-#include <rtems/score/schedulerimpl.h>
-  ISR_lock_Context lock_context;
-  _Scheduler_Acquire( the_thread, &lock_context );
-  the_thread->current_state = STATES_READY;
-  _Scheduler_Unblock( the_thread );
-  _Scheduler_Release( the_thread, &lock_context );
1.8.4.5
