[PATCH 5/5] libcsupport: Delete superfluous _gettimeofday()
Mon Mar 9 12:18:36 UTC 2015
 cpukit/libcsupport/src/__gettod.c  | 16 ----------------
 testsuites/psxtests/psxtime/test.c |  7 -------
 2 files changed, 23 deletions(-)
diff --git a/cpukit/libcsupport/src/__gettod.c b/cpukit/libcsupport/src/__gettod.c
index 0b1ea97..b0b60de 100644
--- a/cpukit/libcsupport/src/__gettod.c
+++ b/cpukit/libcsupport/src/__gettod.c
@@ -80,20 +80,4 @@ int _gettimeofday_r(
 #endif
-#if defined(RTEMS_NEWLIB) && !defined(HAVE__GETTIMEOFDAY)
- *  "System call" version
-int _gettimeofday(
-  struct timeval *tp,
-  void           *__tz
-  struct timezone *tzp = __tz;
-  return gettimeofday( tp, tzp );
-#endif
 #endif /* defined(RTEMS_NEWLIB) */
diff --git a/testsuites/psxtests/psxtime/test.c b/testsuites/psxtests/psxtime/test.c
index 7620d56..8331bef 100644
--- a/testsuites/psxtests/psxtime/test.c
+++ b/testsuites/psxtests/psxtime/test.c
@@ -37,8 +37,6 @@ const char rtems_test_name[] = "PSXTIME";
 extern int adjtime(const struct timeval *delta, struct timeval *olddelta);
 #endif
-extern int _gettimeofday(struct timeval *__p, void *__tz);
 void test_adjtime(void);
 void check_a_tod(
   rtems_time_of_day *the_tod
@@ -221,11 +219,6 @@ int main(
   rtems_test_assert( sc == -1 );
   rtems_test_assert( errno == EFAULT );
-  puts( "_gettimeofday( NULL, NULL ) - EFAULT" );
-  sc = _gettimeofday( NULL, NULL );
-  rtems_test_assert( sc == -1 );
-  rtems_test_assert( errno == EFAULT );
   test_adjtime();
1.8.4.5
