Detecting Tests Which Don't Have Enough Workspace
    Sebastian Huber
    Fri Mar 13 08:29:40 UTC 2015
On 12/03/15 18:41, Joel Sherrill wrote:
> Hi
> Many BSPs can link a test but don't actually have enough memory
> to run the test. They will fail in the first few lines when the requested
> memory for the RTEMS work area is not available. I hacked together
> a script which adds together the code, data, bss, work space and
> stack space requested. If this exceeds physical memory on the board,
> then the test will fail.  It is possible to come close and still run out of
> memory during initialization (e.g. malloc, etc) but this approach could
> detect some tests which will fail by inspecting them on the host.
> This is a shell script but would be better built into the rtems-tools
> and using the gdb/mi. Combined with information on the
> available memory on the target, we could throw out some obvious
> failure cases without touching hardware.
> Thoughts?
I would address this with better test output, so that you can get a
summery and see "X tests failed due to not enough memory for the workspace".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
