lwIP for beaglebone black
    Marcos Díaz
    marcos.diaz at tallertechnologies.com
    Mon Mar 16 14:39:38 UTC 2015
Hi, here I will attach two repos with our work so far:
https://bitbucket.org/mdmarcosdiaz/lwip-bbb-rtems/  (Branch POSIX-API-LWIP)
 This is the LWIP with our drivers copied from TI's and modified to
support RTEMS tasks.
It has a makefile that generates a library.
To make it work we used the bbb bsp from Ben Gras, and we had to make
some changes to disable the cache, and to fix a problem from the main
rtems that it was fixed there but not in this local repository.
Perhaps it will be best to make it run in the bsp that is in the
mainline of RTEMS, but this repo will help you to see what changes we
had to make:
https://bitbucket.org/eduardo-sanchez/rtemsbbb
Please, let me know any help you need.
On Sat, Mar 14, 2015 at 10:12 AM, Daniel Gutson
<daniel.gutson at tallertechnologies.com> wrote:
> Marcos, please guide him so he can finish the remaining tasks to get lwip
> official support, specially the RSB part.
> Thanks,
>   Daniel.
> On March 13, 2015 6:30:40 PM CDT, "Marcos Díaz"
> <marcos.diaz at tallertechnologies.com> wrote:
>>Hi,
>>Indeed we have it working but we only can use it with the cache
>>disabled because the system crashes otherway.
> This could be an MMU setup issue. A region marked cacheable that shouldn't
> be.
>>About what's next, I think there should be a revision of the code and
>>debugging in order to make it work with the cache enabled. And also see
>>the way of submitting it to rtems. It was suggested to upload it in
>>rtems source builder and try to make it easier to configure
> He is looking at this as part of a gsoc project so could help take a work in
> progress and push it to completion.
>>El mar 13, 2015 6:52 PM, "Daniel Gutson"
>><daniel.gutson at tallertechnologies.com> escribió:
>>Hi Ragu.
>> We're successfully using it in production code. We had no time to
>>contribute it yet, AFAIK blocked in the source builder. Marcos,
>>details please?
>> Daniel.
>>On Fri, Mar 13, 2015 at 6:00 PM, ragu nath <ragunath3252 at gmail.com>
>>wrote:
>>> Hi,
>>> I would like to know what is the status of running lwIP on beaglebone
>>> black on RTEMS.  I understand that  there was some considerable
>>amount
>>> of work already done on running lwIP on BBB.  It would be really
>>> helpful if I can get the details on what has already been done and
>>> what are the remaining things to be done.
>>> Thanks,
>>> Ragunath
>>Daniel F. Gutson
>>Chief Engineering Officer, SPD
>>San Lorenzo 47, 3rd Floor, Office 5
>>Córdoba, Argentina
>>Phone:   +54 351 4217888 / +54 351 4218211
>>Skype:    dgutson
>>LinkedIn: http://ar.linkedin.com/in/danielgutson
> --joel
______________________________
Marcos Díaz
Software Engineer
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
