[PATCH 14/19] tests misc: Disable deprecated method usage warning when intentional
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Mar 16 20:29:31 UTC 2015
These tests intentionally use the deprecated method. Eventually
this code in the sections can be deleted.
testsuites/psxtests/psxconfig01/init.c | 14 +-
testsuites/sptests/spclockget/init.c | 2 +
testsuites/sptests/spnotepad01/init.c | 5 +
testsuites/sptests/sptask_err04/task1.c | 344 +++++++++++++++++---------------
testsuites/tmtests/tm08/task1.c | 62 +++---
5 files changed, 232 insertions(+), 195 deletions(-)
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 61beec3..ea8cd5d 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -438,10 +438,16 @@ static rtems_task Init(rtems_task_argument argument)
#if !defined(RTEMS_SMP)
#ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES
- for (i = 0; i < CONFIGURE_MAXIMUM_TASK_VARIABLES; ++i) {
- sc = rtems_task_variable_add(RTEMS_SELF, &task_var, task_var_dtor);
- directive_failed(sc, "rtems_task_variable_add");
+ * We know this is deprecated and don't want a warning on every BSP built.
+ #pragma GCC diagnostic push
+ #pragma GCC diagnostic ignored "-Wdeprecated-declarations"
+ for (i = 0; i < CONFIGURE_MAXIMUM_TASK_VARIABLES; ++i) {
+ sc = rtems_task_variable_add(RTEMS_SELF, &task_var, task_var_dtor);
+ directive_failed(sc, "rtems_task_variable_add");
+ #pragma GCC diagnostic pop
#endif
#endif
diff --git a/testsuites/sptests/spclockget/init.c b/testsuites/sptests/spclockget/init.c
index 145beed..8cdae21 100644
--- a/testsuites/sptests/spclockget/init.c
+++ b/testsuites/sptests/spclockget/init.c
@@ -14,6 +14,8 @@
#include <tmacros.h>
#include "pritime.h"
+#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
const char rtems_test_name[] = "SPCLOCKGET";
/* forward declarations to avoid warnings */
diff --git a/testsuites/sptests/spnotepad01/init.c b/testsuites/sptests/spnotepad01/init.c
index 9604c32..965d69d 100644
--- a/testsuites/sptests/spnotepad01/init.c
+++ b/testsuites/sptests/spnotepad01/init.c
@@ -15,6 +15,11 @@
const char rtems_test_name[] = "SPNOTEPAD 1";
rtems_task Init(rtems_task_argument argument);
diff --git a/testsuites/sptests/sptask_err04/task1.c b/testsuites/sptests/sptask_err04/task1.c
index 0d182e0..92ddb6d 100644
--- a/testsuites/sptests/sptask_err04/task1.c
+++ b/testsuites/sptests/sptask_err04/task1.c
@@ -50,191 +50,203 @@ rtems_task Task_1(
puts( "TA1 - rtems_task_delete - RTEMS_INVALID_ID" );
- /* NULL return */
- status = rtems_task_get_note( RTEMS_SELF, RTEMS_NOTEPAD_FIRST, NULL );
- fatal_directive_status(
- status,
- RTEMS_INVALID_ADDRESS,
- "rtems_task_get_note with NULL param"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS" );
+ /** START OF NOTEPAD TESTS **/
- /* note too high */
- status = rtems_task_get_note( RTEMS_SELF, 100, ¬epad_value );
- status,
- RTEMS_INVALID_NUMBER,
- "rtems_task_get_note with illegal notepad"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER" );
- /* bad Id */
- status = rtems_task_get_note( 100, RTEMS_NOTEPAD_LAST, ¬epad_value );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_get_note with illegal id"
- puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ID" );
+ /* NULL return */
+ status = rtems_task_get_note( RTEMS_SELF, RTEMS_NOTEPAD_FIRST, NULL );
+ fatal_directive_status(
+ status,
+ RTEMS_INVALID_ADDRESS,
+ "rtems_task_get_note with NULL param"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ADDRESS" );
- /* unused Id so invalid now */
- Task_id[ 0 ],
- RTEMS_NOTEPAD_LAST,
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
+ /* note too high */
+ status = rtems_task_get_note( RTEMS_SELF, 100, ¬epad_value );
+ status,
+ RTEMS_INVALID_NUMBER,
+ "rtems_task_get_note with illegal notepad"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_NUMBER" );
- _RTEMS_tasks_Information.minimum_id + (3L<<OBJECTS_API_START_BIT),
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
+ /* bad Id */
+ status = rtems_task_get_note( 100, RTEMS_NOTEPAD_LAST, ¬epad_value );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_get_note with illegal id"
+ puts( "TA1 - rtems_task_get_note - RTEMS_INVALID_ID" );
- rtems_build_id( OBJECTS_CLASSIC_API, 2, 1, 1 ),
- ¬epad_value
- status,
- RTEMS_INVALID_ID,
- "rtems_task_get_note with non-task ID"
+ /* unused Id so invalid now */
+ Task_id[ 0 ],
+ RTEMS_NOTEPAD_LAST,
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
- /* NULL param */
- status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, NULL );
- status,
- "rtems_task_ident NULL param"
- puts( "TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS" );
+ _RTEMS_tasks_Information.minimum_id + (3L<<OBJECTS_API_START_BIT),
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
- /* OK */
- status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &self_id );
- directive_failed( status, "rtems_task_ident of self" );
- if ( self_id != Task_id[ 1 ] ) {
- puts( "ERROR - rtems_task_ident - incorrect ID returned!" );
- puts( "TA1 - rtems_task_ident - current task RTEMS_SUCCESSFUL" );
+ rtems_build_id( OBJECTS_CLASSIC_API, 2, 1, 1 ),
+ ¬epad_value
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_get_note with non-task ID"
- status = rtems_task_ident( 100, RTEMS_SEARCH_ALL_NODES, &Junk_id );
- status,
- RTEMS_INVALID_NAME,
- "rtems_task_ident with illegal name (local)"
- puts( "TA1 - rtems_task_ident - global RTEMS_INVALID_NAME" );
+ /* NULL param */
+ status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, NULL );
+ status,
+ "rtems_task_ident NULL param"
+ puts( "TA1 - rtems_task_ident - RTEMS_INVALID_ADDRESS" );
- status = rtems_task_ident( 100, 1, &Junk_id );
- status,
- "rtems_task_ident with illegal name (global)"
- puts( "TA1 - rtems_task_ident - local RTEMS_INVALID_NAME" );
+ /* OK */
+ status = rtems_task_ident( RTEMS_SELF, RTEMS_SEARCH_ALL_NODES, &self_id );
+ directive_failed( status, "rtems_task_ident of self" );
+ if ( self_id != Task_id[ 1 ] ) {
+ puts( "ERROR - rtems_task_ident - incorrect ID returned!" );
+ puts( "TA1 - rtems_task_ident - current task RTEMS_SUCCESSFUL" );
- * This one case is different if MP is enabled/disabled.
+ status = rtems_task_ident( 100, RTEMS_SEARCH_ALL_NODES, &Junk_id );
+ status,
+ RTEMS_INVALID_NAME,
+ "rtems_task_ident with illegal name (local)"
+ puts( "TA1 - rtems_task_ident - global RTEMS_INVALID_NAME" );
- status = rtems_task_ident( 100, 2, &Junk_id );
-#if defined(RTEMS_MULTIPROCESSING)
- status,
- RTEMS_INVALID_NODE,
- "rtems_task_ident with illegal node"
-#else
- status,
-#endif
- puts( "TA1 - rtems_task_ident - RTEMS_INVALID_NODE" );
+ status = rtems_task_ident( 100, 1, &Junk_id );
+ status,
+ "rtems_task_ident with illegal name (global)"
+ puts( "TA1 - rtems_task_ident - local RTEMS_INVALID_NAME" );
- status = rtems_task_restart( 100, 0 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_restart with illegal id"
- puts( "TA1 - rtems_task_restart - RTEMS_INVALID_ID" );
+ * This one case is different if MP is enabled/disabled.
- status = rtems_task_resume( 100 );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_resume with illegal id"
- puts( "TA1 - rtems_task_resume - RTEMS_INVALID_ID" );
+ status = rtems_task_ident( 100, 2, &Junk_id );
+ #if defined(RTEMS_MULTIPROCESSING)
+ status,
+ RTEMS_INVALID_NODE,
+ "rtems_task_ident with illegal node"
+ #else
+ status,
+ #endif
+ puts( "TA1 - rtems_task_ident - RTEMS_INVALID_NODE" );
- status = rtems_task_resume( RTEMS_SELF );
- status,
- RTEMS_INCORRECT_STATE,
- "rtems_task_resume of ready task"
- puts( "TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE" );
+ status = rtems_task_restart( 100, 0 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_restart with illegal id"
+ puts( "TA1 - rtems_task_restart - RTEMS_INVALID_ID" );
- /* NULL param */
- status = rtems_task_set_priority( RTEMS_SELF, RTEMS_CURRENT_PRIORITY, NULL );
- status,
- "rtems_task_set_priority with NULL param"
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS" );
+ status = rtems_task_resume( 100 );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_resume with illegal id"
+ puts( "TA1 - rtems_task_resume - RTEMS_INVALID_ID" );
- /* bad priority */
- status = rtems_task_set_priority( RTEMS_SELF, 512, &previous_priority );
- status,
- RTEMS_INVALID_PRIORITY,
- "rtems_task_set_priority with illegal priority"
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY" );
+ status = rtems_task_resume( RTEMS_SELF );
+ status,
+ RTEMS_INCORRECT_STATE,
+ "rtems_task_resume of ready task"
+ puts( "TA1 - rtems_task_resume - RTEMS_INCORRECT_STATE" );
- /* bad Id */
- status = rtems_task_set_priority( 100, 8, &previous_priority );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_set_priority with illegal id"
- puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ID" );
+ /* NULL param */
+ status = rtems_task_set_priority( RTEMS_SELF, RTEMS_CURRENT_PRIORITY, NULL );
+ status,
+ "rtems_task_set_priority with NULL param"
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ADDRESS" );
- status = rtems_task_set_note(
- RTEMS_SELF,
- RTEMS_NOTEPAD_LAST+10,
- notepad_value
- status,
- "rtems_task_set_note with illegal notepad"
- puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER" );
+ /* bad priority */
+ status = rtems_task_set_priority( RTEMS_SELF, 512, &previous_priority );
+ status,
+ RTEMS_INVALID_PRIORITY,
+ "rtems_task_set_priority with illegal priority"
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_PRIORITY" );
- status = rtems_task_set_note( 100, RTEMS_NOTEPAD_LAST, notepad_value );
- status,
- RTEMS_INVALID_ID,
- "rtems_task_set_note with illegal id"
- puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_ID" );
+ /* bad Id */
+ status = rtems_task_set_priority( 100, 8, &previous_priority );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_set_priority with illegal id"
+ puts( "TA1 - rtems_task_set_priority - RTEMS_INVALID_ID" );
+ status = rtems_task_set_note(
+ RTEMS_SELF,
+ RTEMS_NOTEPAD_LAST+10,
+ notepad_value
+ status,
+ "rtems_task_set_note with illegal notepad"
+ puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_NUMBER" );
+ status = rtems_task_set_note( 100, RTEMS_NOTEPAD_LAST, notepad_value );
+ status,
+ RTEMS_INVALID_ID,
+ "rtems_task_set_note with illegal id"
+ puts( "TA1 - rtems_task_set_note - RTEMS_INVALID_ID" );
+ /** END OF NOTEPAD TESTS **/
status = rtems_task_start( 100, Task_1, 0 );
diff --git a/testsuites/tmtests/tm08/task1.c b/testsuites/tmtests/tm08/task1.c
index f26931f..6d42de9 100644
--- a/testsuites/tmtests/tm08/task1.c
+++ b/testsuites/tmtests/tm08/task1.c
@@ -186,31 +186,43 @@ rtems_task test_task(
benchmark_timer_initialize();
(void) rtems_task_mode( RTEMS_PREEMPT, RTEMS_PREEMPT_MASK, &old_mode );
- benchmark_timer_initialize();
- for ( index=1 ; index <= OPERATION_COUNT ; index++ )
- (void) rtems_task_set_note( Test_task_id, 8, 10 );
- end_time = benchmark_timer_read();
- put_time(
- "rtems_task_set_note: only case",
- end_time,
- OPERATION_COUNT,
- overhead,
- CALLING_OVERHEAD_TASK_SET_NOTE
- (void) rtems_task_get_note( Test_task_id, 8, &old_note );
- put_time(
- "rtems_task_get_note: only case",
- end_time,
- OPERATION_COUNT,
- overhead,
- CALLING_OVERHEAD_TASK_GET_NOTE
+ benchmark_timer_initialize();
+ for ( index=1 ; index <= OPERATION_COUNT ; index++ )
+ (void) rtems_task_set_note( Test_task_id, 8, 10 );
+ end_time = benchmark_timer_read();
+ put_time(
+ "rtems_task_set_note: only case",
+ end_time,
+ OPERATION_COUNT,
+ overhead,
+ CALLING_OVERHEAD_TASK_SET_NOTE
+ (void) rtems_task_get_note( Test_task_id, 8, &old_note );
+ put_time(
+ "rtems_task_get_note: only case",
+ end_time,
+ OPERATION_COUNT,
+ overhead,
+ CALLING_OVERHEAD_TASK_GET_NOTE
build_time( &time, 1, 1, 1988, 0, 0, 0, 0 );
1.9.3
