GSoC 2015 - Clang support and Eclipse plugin work
Asiri Rathnayake asiri.rathnayake at gmail.com
Tue Mar 24 21:12:31 UTC 2015
Hi Gedare, Joel,
>> For clang support, I've made start by following the steps of [1]. I
> >> also have an industry contact (llvm/clang committer) who's willing to
> >> help me on that side of things. One question I have about this is, how
> > It would be most helpful if your contact would be willing to sign-up
> > in Google Melange as a mentor for RTEMS Project. Please have him/her
> > contact me directly for any clarifications.
> +1
I've sent a request on Melange. I'm mostly familiar with the llvm backend
work, but I think I know (or can find out) enough about Clang to help
Charith with his work (if he gets selected, of course).
Cheers,
- Asiri
> >> do we define a success measure for this project? I mean, RTEMS seem to
> >> already compile with Clang with some local patches [1], but how do we
> > Somewhat true, but I believe there are problems with using clang that
> > have to do with the pervasive use of gcc spec files. A pre-requisite
> > task may be to get the spec files completely eliminated, which there
> > is an ongoing effort to do with the "waf branch" of RTEMS [1ing tghe].
> I am suspicious that most of what is in the specs files is obsolete and
> already
> taken into account inside gcc by our rtems specific tweaks.  GCC spec way
> extension is a way to accomplish things that can be done inside GCC but
> without modifying GCC source.  The specs use predates us having many
> gcc tweaks.
> The short version is that a careful review may significantly reduce them.
> Also I have long had the idea that adding an option for an rtems bsp
> to gcc and clang could eliminate some needs also. The -B option is
> mostly to set an include and lib path to get the BSP.
> Random core dump of thoughts of unsure value.
> > I think it makes the most sense to work from the waf branch and try to
> > help push it forward.
> +1
> >> evaluate whether the resulting binary is in good shape? should I also
> >> be thinking of some test-plan as part of the project? Secondly, will
> > RTEMS has an extensive test-suite [2], and you should be prepared to
> > run it before/after. We have a tool that helps with automation [3].
> >> it be OK if I fork off clang in github and maintain the patches there?
> > Yes, we prefer for gsoc development to be done on github.
> >> I haven't yet tried out the RTEMS Eclipse plugin (on my TODO list),
> >> but I have an interest in learning Eclipse plugin development. I
> >> suppose the objectives of this project would be implement as much as
> >> possible in the TODO list of [2]?
> > Yes, but some of those may be obsolete. Perhaps users will chime in
> > about what they would like to see in it.
> Agreed. And suggesting Eclipse capabilities that are useful is welcomed.
> >> Many thanks for your comments.
> >> - Charith
> >> PS: "Hello World" exercise attached herewith.
> > Confirmed, thanks. Feel free to add yourself to the "Tracking Table" for
> 2015.
> > [1] https://git.rtems.org/amar/waf.git/
> > [2] https://git.rtems.org/rtems/tree/testsuites
> > [3] https://git.rtems.org/rtems-tools/tree/tester
> > Gedare
> >> [1] https://devel.rtems.org/wiki/Projects/CLANG
> >> [2] https://devel.rtems.org/wiki/Developer/Eclipse/Information
> >> [3] https://devel.rtems.org/wiki/GSoC/GettingStarted
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150324/f28a0f67/attachment-0002.html>
