[rtems-graphic-toolkit] version problem with microwin
QIAO YANG yangqiao0505 at me.com
Mon Mar 30 00:21:08 UTC 2015
On Mar 30, 2015, at 06:54 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 3/29/2015 5:38 PM, QIAO YANG wrote:
>> Hi,
>> I've tried to compile the rgt for pc386. But I can't get the right
>> version of microwin , not from the upstream nor from the alex-sever's
>> fork.
>> >> Unable to checkout
>> '6b5dae5cdbc334ac1c3210bc2c4918668cb42aa4' in submodule path 'microwin'
>> Has anyone succeed to compile it recently ? Or maybe I've missed
>> anything.
> I cloned the master when you were asking about it.
> Change the git clone as needed in the script to git (hehehe) to clone.
I didn't noticed the file README.Microwindows  .
While, I've just retried with the latest from git, and the latest release version,  but always end up with the same build error:
    >>...........  /microwin/src/engine/image_png.c:35:27: error: dereferencing pointer to incomplete type
  GdImageBufferRead(pstruct->io_ptr, pointer, size);
This error will produce since 01/2010
With the earlier version, I've got error:
     >> rmdir fail to remove freetype/internal, directory doesn't exist
Which version have you used without error?  I doubt that if it's the microwins version problem. Can we see anything from it?
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150330/64b64b06/attachment-0002.html>
