[PATCH] [RSB] Add support for building Epiphany tools
Hesham ALMatary heshamelmatary at gmail.com
Fri May 1 08:36:17 UTC 2015
On Fri, May 1, 2015 at 3:34 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 1/05/2015 7:31 am, Hesham ALMatary wrote:
>> +%source set binutils https://github.com/adapteva/epiphany-binutils-gdb/archive/epiphany-binutils-2.23-software-cache.zip
>> +%source set gcc https://github.com/adapteva/epiphany-gcc/archive/epiphany-gcc-4.9.zip
>> +%source set gdb https://github.com/adapteva/epiphany-binutils-gdb/archive/epiphany-gdb-7.8.zip
> Are these versions set or are they moving as the github repo moves ?
They are usually changing and modified, fixing bugs, add features,
etc. My pull requests got merged to these branches. That's why I think
hashes won't be practical.
About the error you got, I tested the patch and it's building fine on
my Fedora OS. I'll have to clone another vanilla RSB repo, apply the
patch, and test again.
> The reason I ask is no hashes are included and a warning is being generated.
> Chris
Hesham
