[PATCH] [RSB] Add support for building Epiphany tools
Hesham ALMatary heshamelmatary at gmail.com
Tue May 5 08:28:51 UTC 2015
Hi Chris,
On Mon, May 4, 2015 at 11:53 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 4/05/2015 9:00 pm, Hesham ALMatary wrote:
>> On Mon, May 4, 2015 at 1:39 AM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 4/05/2015 12:10 am, Hesham ALMatary wrote:
>>>> On Fri, May 1, 2015 at 3:29 PM, Gedare Bloom <gedare at gwu.edu> wrote:
>>>>> On Fri, May 1, 2015 at 4:36 AM, Hesham ALMatary
>>>>> <heshamelmatary at gmail.com> wrote:
>>>>>> On Fri, May 1, 2015 at 3:34 AM, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>> On 1/05/2015 7:31 am, Hesham ALMatary wrote:
>>>>>>>> +%source set binutils https://github.com/adapteva/epiphany-binutils-gdb/archive/epiphany-binutils-2.23-software-cache.zip
>>>>>>>> +%source set gcc https://github.com/adapteva/epiphany-gcc/archive/epiphany-gcc-4.9.zip
>>>>>>>> +%source set gdb https://github.com/adapteva/epiphany-binutils-gdb/archive/epiphany-gdb-7.8.zip
>>>>>>> Are these versions set or are they moving as the github repo moves ?
>>>>>> They are usually changing and modified, fixing bugs, add features,
>>>>>> etc. My pull requests got merged to these branches. That's why I think
>>>>>> hashes won't be practical.
>>>>> Would it be better to pull the git repo itself to a certain commit
>>>>> then?
>>> From a commit id, sure. If you can pull a zip file from a specific
>>> commit id that would be better.
>> That's possible.
>>> The reason we lock this down is to not changing anything on the user
>>> until it is known to be stable. There are ways using user macros to
>>> override the default and pick up the master branch for your testing so
>>> you can test using the master branch and users pick up the last know
>>> stable version. Contact me and I can explain if this is what you want.
>>>> For building tools we aim to have a reliable, reproducible tool
>>>>> set. Dealing with "moving targets" makes it harder to support.
>>>> That's possible. The problem is that the current RSB doesn't support
>>>> cloning from GitHub URLs like [1] or even [2]. [1] produce "malforned
>>>> URL (no protocol prefix)", and [2] assumes that it's a .tar file, and
>>>> doesn't even clone it.
>>>> [1] git at github.com:adapteva/epiphany-binutils-gdb.git
>>> Does git://git@github.com/adapteva/epiphany-binutils-gdb.git work ?
>> Doesn't work.
> Ok.
>>>> [2] https://github.com/adapteva/epiphany-binutils-gdb.git
>>> The doco in this section https://docs.rtems.org/rsb/#_http_https_and_ftp
>>> shows how to get a git version. Does this still work ?
>> The problem with cloning from github is that the URL should be
>> prefixed with "git://", and this is not the case for github repos. I
>> think download.py should be hacked to enable it.
> Yes I tend to agree.
>> Anyway, I'll submit a patch that downloads from specific commits.
> Thanks.
I case you didn't notice, I submitted 2 patches: 1/2 is sent
separately, and 2/2 got merged with this e-mail thread (don't know
why), it's two replies above this reply.
> Chris
Hesham
