[PATCH v3] SPCONTEXT01: checks correct switching on and off of the Floating Point Unit
Alexander Krutwig alexander.krutwig at embedded-brains.de
Wed May 6 11:48:48 UTC 2015
 testsuites/sptests/spcontext01/init.c          | 42 +++++++++++++++++++-------
 testsuites/sptests/spcontext01/spcontext01.scn |  5 ++-
 2 files changed, 35 insertions(+), 12 deletions(-)
diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
index 039dd63..47d7398 100644
--- a/testsuites/sptests/spcontext01/init.c
+++ b/testsuites/sptests/spcontext01/init.c
@@ -31,6 +31,7 @@ const char rtems_test_name[] = "SPCONTEXT 1";
 typedef struct {
   rtems_id control_task;
   rtems_id validate_tasks[2];
+  rtems_id timer;
   size_t task_index;
   int iteration_counter;
 } test_context;
@@ -46,17 +47,21 @@ static void validate_task(rtems_task_argument arg)
 static void start_validate_task(
   rtems_id *id,
   uintptr_t pattern,
-  rtems_task_priority priority
+  rtems_task_priority priority,
+  bool fp_unit
   rtems_status_code sc;
+  rtems_attribute fpu_state;
+  fpu_state = fp_unit ? RTEMS_FLOATING_POINT : RTEMS_DEFAULT_ATTRIBUTES;
   sc = rtems_task_create(
     rtems_build_name('V', 'A', 'L', 'I'),
     priority,
     RTEMS_MINIMUM_STACK_SIZE,
     RTEMS_DEFAULT_MODES,
-    RTEMS_DEFAULT_ATTRIBUTES,
+    FPU_state,
     id
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
@@ -112,7 +117,7 @@ static void clobber_and_switch_timer(rtems_id timer, void *arg)
   uintptr_t pattern = (uintptr_t) 0xffffffffffffffffU;
   test_context *self = arg;
-  reset_timer_or_finish(self, timer);
+  reset_timer_or_finish(self, self->timer);
   switch_priorities(self);
   _CPU_Context_volatile_clobber(pattern);
@@ -121,12 +126,11 @@ static void clobber_and_switch_timer(rtems_id timer, void *arg)
 static void start_timer(test_context *self)
-  rtems_id timer;
-  sc = rtems_timer_create(rtems_build_name('C', 'L', 'S', 'W'), &timer);
+  sc = rtems_timer_create(rtems_build_name('C', 'L', 'S', 'W'), &self->timer);
-  sc = rtems_timer_fire_after(timer, 2, clobber_and_switch_timer, self);
+  sc = rtems_timer_fire_after(self->timer, 2, clobber_and_switch_timer, self);
@@ -145,19 +149,30 @@ static void wait_for_finish(void)
   rtems_test_assert(out == FINISH_EVENT);
-static void test(test_context *self)
+static void test(test_context *self, bool task_0_fpu, bool task_1_fpu)
+  rtems_status_code sc;
   uintptr_t pattern_0 = (uintptr_t) 0xaaaaaaaaaaaaaaaaU;
   uintptr_t pattern_1 = (uintptr_t) 0x5555555555555555U;
   memset(self, 0, sizeof(*self));
   self->control_task = rtems_task_self();
-  start_validate_task(&self->validate_tasks[0], pattern_0, PRIORITY_LOW);
-  start_validate_task(&self->validate_tasks[1], pattern_1, PRIORITY_HIGH);
+  start_validate_task(&self->validate_tasks[0], pattern_0, PRIORITY_LOW,
+                     task_0_fpu);
+  start_validate_task(&self->validate_tasks[1], pattern_1, PRIORITY_HIGH,
+                     task_1_fpu);
   start_timer(self);
   wait_for_finish();
+  sc = rtems_task_delete(self->validate_tasks[0]);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_delete(self->validate_tasks[1]);
+  sc = rtems_timer_delete(self->timer);
 static void test_context_is_executing(void)
@@ -207,7 +222,12 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
   test_context_is_executing();
-  test(self);
+  test(self, false, false);
+  printf("Both tasks did not use FPU: done\n");
+  test(self, false, true);
+  printf("One task used the FPU: done\n");
+  test(self, true, true);
+  printf("Both tasks used the FPU: done\n");
   TEST_END();
diff --git a/testsuites/sptests/spcontext01/spcontext01.scn b/testsuites/sptests/spcontext01/spcontext01.scn
index b7b823b..a76e00b 100644
--- a/testsuites/sptests/spcontext01/spcontext01.scn
+++ b/testsuites/sptests/spcontext01/spcontext01.scn
@@ -1,2 +1,5 @@
-*** TEST SPCONTEXT 1 ***
+*** BEGIN OF TEST SPCONTEXT 1 ***
+Both tasks did not use FPU: done
+One task used the FPU: done
+Both tasks used the FPU: done
 *** END OF TEST SPCONTEXT 1 ***
1.8.4.5
