[PATCH 2/2] Epiphany: Add the first epiphany_sim BSP.
Hesham ALMatary heshamelmatary at gmail.com
Fri May 8 02:12:12 UTC 2015
This BSP in intended to run on the simulator that should be built
from RSB. When building RTEMS for Epiphany --disable-networking must
be provided part of the configure command.
 c/src/aclocal/rtems-cpu-subdirs.m4                 |   1 +
 c/src/lib/libbsp/epiphany/Makefile.am              |   8 +
 c/src/lib/libbsp/epiphany/acinclude.m4             |  10 +
 c/src/lib/libbsp/epiphany/configure.ac             |  20 ++
 c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am |  95 ++++++
 c/src/lib/libbsp/epiphany/epiphany_sim/README      |   6 +
 c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs   |  11 +
 .../lib/libbsp/epiphany/epiphany_sim/configure.ac  |  37 +++
 .../epiphany/epiphany_sim/console/console-io.c     |  87 +++++
 .../lib/libbsp/epiphany/epiphany_sim/include/bsp.h |  40 +++
 .../libbsp/epiphany/epiphany_sim/include/bspopts.h |  53 ++++
 .../lib/libbsp/epiphany/epiphany_sim/include/irq.h |  31 ++
 .../libbsp/epiphany/epiphany_sim/include/tm27.h    |  38 +++
 c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c   |  43 +++
 .../epiphany_sim/make/custom/epiphany_sim.cfg      |   7 +
 .../lib/libbsp/epiphany/epiphany_sim/preinstall.am | 104 ++++++
 .../lib/libbsp/epiphany/epiphany_sim/start/start.S | 152 +++++++++
 .../libbsp/epiphany/epiphany_sim/startup/linkcmds  | 351 +++++++++++++++++++++
 .../lib/libbsp/epiphany/epiphany_sim/timer/timer.c | 111 +++++++
 c/src/lib/libbsp/epiphany/preinstall.am            |   7 +
 .../epiphany/shared/include/linker-symbols.h       |  81 +++++
 21 files changed, 1293 insertions(+)
 create mode 100644 c/src/lib/libbsp/epiphany/Makefile.am
 create mode 100644 c/src/lib/libbsp/epiphany/acinclude.m4
 create mode 100644 c/src/lib/libbsp/epiphany/configure.ac
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/README
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds
 create mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c
 create mode 100644 c/src/lib/libbsp/epiphany/preinstall.am
 create mode 100644 c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h
diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
index 9593d34..524edac 100644
--- a/c/src/aclocal/rtems-cpu-subdirs.m4
+++ b/c/src/aclocal/rtems-cpu-subdirs.m4
@@ -12,6 +12,7 @@ AC_DEFUN([RTEMS_CPU_SUBDIRS],
 case $RTEMS_CPU in
 _RTEMS_CPU_SUBDIR([arm],[$1]);;
 _RTEMS_CPU_SUBDIR([bfin],[$1]);;
+_RTEMS_CPU_SUBDIR([epiphany],[$1]);;
 _RTEMS_CPU_SUBDIR([avr],[$1]);;
 _RTEMS_CPU_SUBDIR([h8300],[$1]);;
 _RTEMS_CPU_SUBDIR([i386],[$1]);;
diff --git a/c/src/lib/libbsp/epiphany/Makefile.am b/c/src/lib/libbsp/epiphany/Makefile.am
new file mode 100644
index 0000000..cdcc3fb
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/Makefile.am
@@ -0,0 +1,8 @@
+ACLOCAL_AMFLAGS = -I ../../../aclocal
+## Descend into the @RTEMS_BSP_FAMILY@ directory
+## Currently, the shared directory is not explicitly
+## added but it is present in the source tree.
+SUBDIRS = @RTEMS_BSP_FAMILY@
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/../../../automake/subdirs.am
+include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/epiphany/acinclude.m4 b/c/src/lib/libbsp/epiphany/acinclude.m4
index 0000000..0fe1e2e
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/acinclude.m4
@@ -0,0 +1,10 @@
+# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
+AC_DEFUN([RTEMS_CHECK_BSPDIR],
+  case "$1" in
+  epiphany_sim )
+    AC_CONFIG_SUBDIRS([epiphany_sim]);;
+    AC_MSG_ERROR([Invalid BSP]);;
+  esac
diff --git a/c/src/lib/libbsp/epiphany/configure.ac b/c/src/lib/libbsp/epiphany/configure.ac
index 0000000..899d4d7
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/configure.ac
@@ -0,0 +1,19 @@
+# Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-epiphany],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_CONFIG_SRCDIR([epiphany_sim])
+RTEMS_TOP(../../../../..)
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
+AM_MAINTAINER_MODE
+RTEMS_ENV_RTEMSBSP
+RTEMS_PROJECT_ROOT
+RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
index 0000000..0b84843
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
@@ -0,0 +1,95 @@
+# @brief Makefile of LibBSP for the Epiphany simulator.
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include_bspdir = $(includedir)/bsp
+include_libcpudir = $(includedir)/libcpu
+dist_project_lib_DATA = bsp_specs
+#                  Header                                                     #
+include_HEADERS = include/bsp.h
+include_HEADERS += include/tm27.h
+include_HEADERS += ../../shared/include/coverhd.h
+nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
+include_bsp_HEADERS = ../shared/include/linker-symbols.h
+include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
+include_bsp_HEADERS += ../../shared/include/utility.h
+include_bsp_HEADERS += ../../shared/include/irq-generic.h
+include_bsp_HEADERS += ../../shared/include/irq-info.h
+include_bsp_HEADERS += ../../shared/include/stackalloc.h
+include_bsp_HEADERS += ../../shared/include/console-polled.h
+include_bsp_HEADERS += include/irq.h
+nodist_include_HEADERS = include/bspopts.h
+#                  Data                                                       #
+noinst_LIBRARIES = libbspstart.a
+libbspstart_a_SOURCES = start/start.S
+project_lib_DATA = start/start.$(OBJEXT)
+project_lib_DATA += startup/linkcmds
+#                  LibBSP                                                     #
+noinst_LIBRARIES += libbsp.a
+# Startup
+libbsp_a_SOURCES = ../../shared/bspreset.c
+libbsp_a_SOURCES += ../../shared/bspstart.c
+# Shared
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
+libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += ../../shared/src/stackalloc.c
+libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
+# clock
+libbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
+# Timer
+libbsp_a_SOURCES += timer/timer.c
+# console
+libbsp_a_SOURCES += ../../shared/console-polled.c
+# IRQ
+libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
+libbsp_a_SOURCES += ../../shared/src/irq-generic.c
+libbsp_a_SOURCES += ../../shared/src/irq-info.c
+libbsp_a_SOURCES += irq/irq.c
+# Cache
+libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
+libbsp_a_SOURCES += ../../shared/include/cache_.h
+libbsp_a_CPPFLAGS = -I$(srcdir)/../../shared/include
+# debugio
+libbsp_a_SOURCES += console/console-io.c
+DISTCLEANFILES = include/bspopts.h
+include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/README b/c/src/lib/libbsp/epiphany/epiphany_sim/README
index 0000000..7127d91
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/README
@@ -0,0 +1,6 @@
+This BSP is intended to run on epiphany-*-run simulator.
+From command line type:
+$ epiphany-rtems4.11-run -e=on --memory-region 0x8e000000,0x2000000 \
+  $PATH_TO_RTEMS_EXE
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs b/c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs
index 0000000..0fcd2dc
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs
@@ -0,0 +1,11 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+%rename link old_link
+*startfile:
+%{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: \
+%{!qrtems_debug: start.o%s} \
+%{qrtems_debug: start_g.o%s}}}
+*link:
+%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N -e _start}
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac b/c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac
index 0000000..c3bed0d
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac
@@ -0,0 +1,36 @@
+# @file
+# @brief Configure script of LibBSP for epiphany_sim BSP.
+AC_PREREQ(2.69)
+AC_INIT([rtems-c-src-lib-libbsp-epiphany-sim],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
+AC_CONFIG_SRCDIR([bsp_specs])
+RTEMS_TOP(../../../../../..)
+AM_INIT_AUTOMAKE([no-define nostdinc foreign subdir-objects 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
+RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP
+start])
+RTEMS_BSPOPTS_SET([BSP_EPIPHANY_PERIPHCLK],[*],[100000000U])
+RTEMS_BSPOPTS_HELP([BSP_EPIPHANY_PERIPHCLK],[epiphany PERIPHCLK clock
+frequency in Hz])
+RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm])
+RTEMS_CANONICALIZE_TOOLS
+RTEMS_PROG_CCAS
+RTEMS_CHECK_SMP
+AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
+RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
+RTEMS_BSP_LINKCMDS
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c b/c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c
index 0000000..35b2ab9
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c
@@ -0,0 +1,87 @@
+ *  COPYRIGHT (c) 2015 University of York.
+ *  Hesham ALMatary <hmka501 at york.ac.uk>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#include <bsp.h>
+#include <bsp/console-polled.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <stdio.h>
+static void outbyte_console( char );
+static char inbyte_console( void );
+void console_initialize_hardware(void)
+  /* Do nothing */
+/* Epiphany simulator would handle this system call */
+static void outbyte_console(char c)
+  register int chan asm("r0") = STDOUT_FILENO;
+  register void* addr asm("r1") = &c;
+  register int len asm("r2") = 1;
+  /* Invoke write system call to be handled by Epiphany simulator */
+  asm volatile ("trap 0" : : "r" (chan), "r" (addr), "r" (len));
+static char inbyte_console(void)
+  char c;
+  register int chan asm("r0") = STDIN_FILENO;
+  /* Invoke read system call to be handled by Epiphany simulator */
+ asm ("trap 1" :: "r" (chan), "r" (addr), "r" (len));
+  return c;
+ *  console_outbyte_polled
+ *  This routine transmits a character using polling.
+void console_outbyte_polled(
+  int  port,
+  char ch
+  outbyte_console( ch );
+ *  console_inbyte_nonblocking
+ *  This routine polls for a character.
+int console_inbyte_nonblocking(int port)
+  char c;
+  c = inbyte_console();
+  if (!c)
+    return -1;
+  return (int) c;
+ *  To support printk
+#include <rtems/bspIo.h>
+static void Epiphany_output_char(char c) { console_outbyte_polled( 0, c ); }
+BSP_output_char_function_type BSP_output_char = Epiphany_output_char;
+BSP_polling_getchar_function_type BSP_poll_char =
+  (void *)console_inbyte_nonblocking;
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h b/c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h
index 0000000..b9549ac
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h
@@ -0,0 +1,40 @@
+ *  Epiphany CPU Dependent Source
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef LIBBSP_EPIPHANY_PARALLELLA_H
+#define LIBBSP_EPIPHANY_PARALLELLA_H
+#include <rtems.h>
+#include <rtems/clockdrv.h>
+#include <rtems/console.h>
+#include <bspopts.h>
+#include <bsp/default-initial-extension.h>
+#include <rtems/devnull.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Constants */
+Thread clock_driver_sim_idle_body(uintptr_t);
+#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_EPIPHANY_PARALLELLA_H */
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h b/c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h
index 0000000..cdba6d2
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h
@@ -0,0 +1,53 @@
+/* include/bspopts.h.in.  Generated from configure.ac by autoheader.  */
+/* If defined, then the BSP Framework will put a non-zero pattern into the
+   RTEMS Workspace and C program heap. This should assist in finding code that
+   assumes memory starts set to zero. */
+#undef BSP_DIRTY_MEMORY
+/* If defined, print a message and wait until pressed before resetting board
+   when application exits. */
+#undef BSP_PRESS_KEY_FOR_RESET
+/* If defined, prints the exception context when an unexpected exception
+   occurs. */
+#undef BSP_PRINT_EXCEPTION_CONTEXT
+/* If defined, reset the board when the application exits. */
+#undef BSP_RESET_BOARD_AT_EXIT
+/* reset vector address for BSP start */
+#undef BSP_START_RESET_VECTOR
+/* Define to the address where bug reports for this package should be sent. */
+#undef PACKAGE_BUGREPORT
+/* Define to the full name of this package. */
+#undef PACKAGE_NAME
+/* Define to the full name and version of this package. */
+#undef PACKAGE_STRING
+/* Define to the one symbol short name of this package. */
+#undef PACKAGE_TARNAME
+/* Define to the home page for this package. */
+#undef PACKAGE_URL
+/* Define to the version of this package. */
+#undef PACKAGE_VERSION
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h b/c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h
index 0000000..e7d01c3
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h
@@ -0,0 +1,31 @@
+ * @file
+ * @ingroup Epiphany_IRQ
+ * @brief Interrupt definitions.
+#ifndef LIBBSP_GENERIC_EPIPHANY_IRQ_H
+#define LIBBSP_GENERIC_EPIPHANY_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#define BSP_INTERRUPT_VECTOR_MIN  0x0
+#define BSP_INTERRUPT_VECTOR_MAX  0x24
+#endif /* ASM */
+#endif /* LIBBSP_GENEIRC_OR1K_IRQ_H */
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h b/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
index 0000000..181cca0
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
@@ -0,0 +1,38 @@
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+ * @name Interrupt mechanisms for Time Test 27
+#define MUST_WAIT_FOR_INTERRUPT 0
+#define Install_tm27_vector( handler ) /* empty */
+#define Cause_tm27_intr() /* empty */
+#define Clear_tm27_intr() /* empty */
+#define Lower_tm27_intr() /* empty */
+#endif
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
index 0000000..2be8df0
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c
@@ -0,0 +1,43 @@
+ * @file
+ * @ingroup epiphany_interrupt
+ * @brief Interrupt support.
+#include <bsp/irq.h>
+#include <bsp/irq-generic.h>
+/* Almost all of the jobs that the following functions should
+ * do are implemented in cpukit
+void bsp_interrupt_handler_default(rtems_vector_number vector)
+    printk("spurious interrupt: %u\n", vector);
+rtems_status_code bsp_interrupt_facility_initialize()
+  return 0;
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+  return 0;
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+  return 0;
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg b/c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg
index 0000000..9eea2a0
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg
@@ -0,0 +1,7 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = epiphany
+CPU_CFLAGS =
+CFLAGS_OPTIMIZE_V ?= -O0 -g
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am b/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
index 0000000..e53b646
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
@@ -0,0 +1,103 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+all-local: $(TMPINSTALL_FILES)
+TMPINSTALL_FILES =
+CLEANFILES += $(TMPINSTALL_FILES)
+$(PROJECT_LIB)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_LIB)
+	@: > $(PROJECT_LIB)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
+$(PROJECT_INCLUDE)/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)
+	@: > $(PROJECT_INCLUDE)/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/bsp/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
+	@: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+$(PROJECT_INCLUDE)/libcpu/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
+	@: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
+$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
+PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
+$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
+$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
+$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
+$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
+$(PROJECT_INCLUDE)/bsp/linker-symbols.h: ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
+$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
+$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
+$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
+$(PROJECT_INCLUDE)/bsp/console-polled.h: ../../shared/include/console-polled.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console-polled.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console-polled.h
+$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
+$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
+$(PROJECT_LIB)/start.$(OBJEXT): start/start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
+TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
+$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S b/c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S
index 0000000..3c4b24f
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S
@@ -0,0 +1,152 @@
+#include <bsp/linker-symbols.h>
+.extern bsp_section_bss_begin
+.extern bsp_section_bss_end
+.extern _ISR_Handler
+.extern  bsp_start_vector_table_end
+.extern  bsp_start_vector_table_size
+.extern  bsp_vector_table_size
+.extern  bsp_section_stack_begin
+.global  _EPIPHANY_Exception_default;
+.global  _bsp_start_vector_table_begin
+.section .vector, "ax";
+.global _start;
+.type   _start, %function;
+_start:
+  .balign 4 ;
+    b .normal_start
+  .balign 4 ; 0x4
+    b .sw_exception
+  .balign 4 ; 0x8
+    b .normal_start
+  .balign 4 ; 0xc
+    b .clock_isr
+  .balign 4 ; 0x10
+    b .timer1_isr
+  .balign 4 ; 0x14
+    b _EPIPHANY_Exception_default
+  .balign 4 ; 0x18
+  .balign 4 ; 0x1c
+  .balign 4 ; 0x20
+  .balign 4 ; 0x24
+_bsp_start_vector_table_begin:
+  .balign 4 ;
+    .word .normal_start /* Reset */
+  .balign 4 ;
+    .word _EPIPHANY_Exception_default /* SW exception */
+  .balign 4 ;
+    .word _EPIPHANY_Exception_default /* Data Page Fault */
+  .balign 4 ;
+    .word _EPIPHANY_Exception_default /* Timer 0 */
+  .balign 4 ;
+    .word _EPIPHANY_Exception_default /* Timer 1 */
+  .balign 4 ;
+   .word _EPIPHANY_Exception_default /* Message int */
+  .balign 4 ;
+   .word _EPIPHANY_Exception_default /* DMA0 int */
+  .balign 4 ;
+   .word _EPIPHANY_Exception_default /* DMA1 int */
+  .balign 4 ;
+   .word _EPIPHANY_Exception_default /* WAND */
+  .balign 4 ;
+   .word _EPIPHANY_Exception_default /* User interrupt */
+_bsp_start_vector_table_end:
+.size  _start, .-_start
+.section .start,"ax"
+.align  4
+.type   _external_start, %function
+.normal_start:
+  /* Initialize the stack and frame pointers */
+  mov  sp, %low(bsp_section_stack_begin)
+  movt sp, %high(bsp_section_stack_begin)
+  mov  fp, sp
+cpu0:
+  /* Zero .bss section */
+  mov  r0, %low(bsp_section_bss_begin)
+  movt r0, %high(bsp_section_bss_begin)
+  mov  r1, sp
+  mov  r2,#0
+  mov  r3,#0
+_bss_clear_loop:
+  strd  r2, [r0], +#1
+  sub   r5, r1, r0
+  bne   _bss_clear_loop
+  /* Clear the reset interrupt flag */
+  mov   r0, %low(_jump_to_c)
+  movt  r0, %high(_jump_to_c)
+  movts iret, r0
+  rti
+_jump_to_c:
+  /* Jump to bootcard */
+  mov  r3, %low(_boot_card)
+  movt r3, %high(_boot_card)
+  jalr r3
+ /* Should never reach here */
+ idle
+.size  .normal_start, .-.normal_start
+.balign 4
+.type   .sw_exception, %function
+.sw_exception:
+  idle
+.balign 4
+.type   .clock_isr, %function
+.clock_isr:
+  add  sp, sp, #-8;
+  str  r62, [sp, #4];
+  str  r63, [sp, #8];
+  mov  r62, 3;
+  mov  r63, %low(_ISR_Handler);
+  movt r63, %high(_ISR_Handler);
+  jr   r63
+.balign 4
+.type   .timer1_isr, %function
+.timer1_isr:
+  add  sp, sp, #-8;
+  mov  r62, 4;
+  jr  r63
+.balign 4
+.type   _EPIPHANY_Exception_default, %function
+_EPIPHANY_Exception_default:
+  idle
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds b/c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds
index 0000000..2f59982
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds
@@ -0,0 +1,351 @@
+ * @file
+ * @ingroup bsp_linker
+ * @brief Memory map
+OUTPUT_FORMAT("elf32-epiphany", "elf32-epiphany", "elf32-epiphany")
+OUTPUT_ARCH (epiphany)
+ENTRY (_start)
+MEMORY
+  VECTOR_RAM  (AIW) : ORIGIN = 0x00000000, LENGTH = 0xB0
+  LOCAL_MEM   (AIW) : ORIGIN = 0x000000B0, LENGTH = 0x00007FC0 /* 32KiB Local memory */
+  RAM               : ORIGIN = 0x8E000000, LENGTH = 0x01000000 /* 16MiB external RAM */
+REGION_ALIAS ("REGION_START", LOCAL_MEM);
+REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
+REGION_ALIAS ("REGION_TEXT", RAM);
+REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+REGION_ALIAS ("REGION_RODATA", RAM);
+REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+REGION_ALIAS ("REGION_DATA", RAM);
+REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+REGION_ALIAS ("REGION_FAST_DATA", RAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+REGION_ALIAS ("REGION_BSS", RAM);
+REGION_ALIAS ("REGION_WORK", RAM);
+REGION_ALIAS ("REGION_STACK", RAM);
+/* The following address is used for text output */
+bsp_section_outbut_buffer = 0x8F800000;
+bsp_section_vector_begin  = 0x00000000;
+ * Global symbols that may be defined externally
+bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size : 64;
+bsp_section_xbarrier_align  = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
+bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
+bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
+bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 1024;
+bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
+_bsp_processor_count = DEFINED (_bsp_processor_count) ? _bsp_processor_count : 1;
+SECTIONS {
+  .vector :
+    *(.vector)
+    . = ALIGN(bsp_vector_table_size);
+    bsp_section_vector_end = .;
+  } > REGION_VECTOR AT > REGION_VECTOR
+  bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
+  bsp_vector_table_begin = bsp_section_vector_begin;
+  bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
+  .start :
+    . = ALIGN(8);
+    bsp_section_start_begin = .;
+    KEEP (*(.bsp_start_text))
+    KEEP (*(.bsp_start_data))
+    bsp_section_start_end = .;
+  } > REGION_START AT > REGION_START
+  bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
+.xbarrier :   {
+    . = ALIGN (bsp_section_xbarrier_align);
+.text :   {
+    . = ALIGN(8);
+    bsp_section_text_begin = .;
+    *(.text.unlikely .text.*_unlikely)
+    *(.text .stub .text.* .gnu.linkonce.t.*)
+    /* .gnu.warning sections are handled specially by elf32.em.  */
+    *(.gnu.warning)
+    *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
+  } > REGION_TEXT AT > REGION_TEXT_LOAD
+  .init :   {
+    KEEP (*(.init))
+  .fini :   {
+    KEEP (*(.fini))
+    . = ALIGN(8);
+    bsp_section_text_end = .;
+  bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
+  bsp_section_text_load_begin = LOADADDR (.text);
+  bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
+.robarrier :   {
+    . = ALIGN (bsp_section_robarrier_align);
+  } > REGION_RODATA AT > REGION_RODATA
+.rodata :   {
+    . = ALIGN(8);
+    bsp_section_rodata_begin = .;
+    *(.rodata .rodata.* .gnu.linkonce.r.*)
+  } > REGION_RODATA AT > REGION_RODATA_LOAD
+.eh_frame :   {
+               KEEP (*(.eh_frame))
+       .gcc_except_table :   {
+               *(.gcc_except_table .gcc_except_table.*)
+       .tdata :   {
+               __TLS_Data_begin = .;
+               *(.tdata .tdata.* .gnu.linkonce.td.*)
+               __TLS_Data_end = .;
+       .tbss :   {
+               __TLS_BSS_begin = .;
+               *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+               __TLS_BSS_end = .;
+       __TLS_Data_size = __TLS_Data_end - __TLS_Data_begin;
+       __TLS_Data_begin = __TLS_Data_size != 0 ? __TLS_Data_begin : __TLS_BSS_begin;
+       __TLS_Data_end = __TLS_Data_size != 0 ? __TLS_Data_end : __TLS_BSS_begin;
+       __TLS_BSS_size = __TLS_BSS_end - __TLS_BSS_begin;
+       __TLS_Size = __TLS_BSS_end - __TLS_Data_begin;
+       __TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
+       .preinit_array :   {
+               PROVIDE_HIDDEN (__preinit_array_start = .);
+               KEEP (*(.preinit_array))
+               PROVIDE_HIDDEN (__preinit_array_end = .);
+       .init_array :   {
+               PROVIDE_HIDDEN (__init_array_start = .);
+               KEEP (*(SORT(.init_array.*)))
+               KEEP (*(.init_array))
+               PROVIDE_HIDDEN (__init_array_end = .);
+       .fini_array :   {
+               PROVIDE_HIDDEN (__fini_array_start = .);
+               KEEP (*(.fini_array))
+               KEEP (*(SORT(.fini_array.*)))
+               PROVIDE_HIDDEN (__fini_array_end = .);
+       .ctors :   {
+               /* gcc uses crtbegin.o to find the start of
+                  the constructors, so we make sure it is
+                  first.  Because this is a wildcard, it
+                  doesn't matter if the user does not
+                  actually link against crtbegin.o; the
+                  linker won't look for a file to match a
+                  wildcard.  The wildcard also means that it
+                  doesn't matter which directory crtbegin.o
+                  is in.  */
+               KEEP (*crtbegin.o(.ctors))
+               KEEP (*crtbegin?.o(.ctors))
+               /* We don't want to include the .ctor section from
+                  the crtend.o file until after the sorted ctors.
+                  The .ctor section from the crtend file contains the
+                  end of ctors marker and it must be last */
+               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
+               KEEP (*(SORT(.ctors.*)))
+               KEEP (*(.ctors))
+       .dtors :   {
+               KEEP (*crtbegin.o(.dtors))
+               KEEP (*crtbegin?.o(.dtors))
+               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
+               KEEP (*(SORT(.dtors.*)))
+               KEEP (*(.dtors))
+       .data.rel.ro :   {
+               *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
+               *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
+       .jcr :   {
+               KEEP (*(.jcr))
+       .interp :   {
+               *(.interp)
+       .note.gnu.build-id :   {
+               *(.note.gnu.build-id)
+       .hash :   {
+               *(.hash)
+       .gnu.hash :   {
+               *(.gnu.hash)
+       .dynsym :   {
+               *(.dynsym)
+       .dynstr :   {
+               *(.dynstr)
+       .gnu.version :   {
+               *(.gnu.version)
+       .gnu.version_d :   {
+               *(.gnu.version_d)
+       .gnu.version_r :   {
+               *(.gnu.version_r)
+       .rel.dyn :   {
+               *(.rel.init)
+               *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
+               *(.rel.fini)
+               *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
+               *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
+               *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
+               *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
+               *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
+               *(.rel.ctors)
+               *(.rel.dtors)
+               *(.rel.got)
+               *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
+               PROVIDE_HIDDEN (__rel_iplt_start = .);
+               *(.rel.iplt)
+               PROVIDE_HIDDEN (__rel_iplt_end = .);
+               PROVIDE_HIDDEN (__rela_iplt_start = .);
+               PROVIDE_HIDDEN (__rela_iplt_end = .);
+       .rela.dyn :   {
+               *(.rela.init)
+               *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
+               *(.rela.fini)
+               *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
+               *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
+               *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
+               *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
+               *(.rela.ctors)
+               *(.rela.dtors)
+               *(.rela.got)
+               *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
+               *(.rela.iplt)
+       .rel.plt :   {
+               *(.rel.plt)
+       .rela.plt :   {
+               *(.rela.plt)
+       .plt :   {
+               *(.plt)
+       .iplt :   {
+               *(.iplt)
+       .dynamic :   {
+               *(.dynamic)
+       .got :   {
+               *(.got.plt) *(.igot.plt) *(.got) *(.igot)
+       .rtemsroset :   {
+               /* Special FreeBSD linker set sections */
+               __start_set_sysctl_set = .;
+               *(set_sysctl_*);
+               __stop_set_sysctl_set = .;
+               *(set_domain_*);
+               *(set_pseudo_*);
+               KEEP (*(SORT(.rtemsroset.*)))
+               . = ALIGN(8);
+               bsp_section_rodata_end = .;
+  bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
+  bsp_section_rodata_load_begin = LOADADDR (.rodata);
+  bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
+.rwbarrier :   {
+    . = ALIGN(8);
+    . = ALIGN (bsp_section_rwbarrier_align);
+  } > REGION_DATA AT > REGION_DATA
+.data :   {
+    . = ALIGN(8);
+    bsp_section_data_begin = .;
+    *(.data .data.* .gnu.linkonce.d.*)
+    SORT(CONSTRUCTORS)
+  } > REGION_DATA AT > REGION_DATA_LOAD
+  .data1 :   {
+    *(.data1)
+  .rtemsrwset :   {
+    KEEP (*(SORT(.rtemsrwset.*)))
+    . = ALIGN(8);
+    bsp_section_data_end = .;
+  bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
+  bsp_section_data_load_begin = LOADADDR (.data);
+  bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
+  .bss :   {
+    . = ALIGN(8);
+    bsp_section_bss_begin = .;
+    *(.dynbss)
+    *(.bss .bss.* .gnu.linkonce.b.*)
+    *(COMMON)
+    . = ALIGN(8);
+    bsp_section_bss_end = .;
+  } > REGION_BSS AT > REGION_BSS
+  bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
+.work :   {
+     * The work section will occupy the remaining REGION_WORK region and
+     * contains the RTEMS work space and heap.
+    . = ALIGN(8);
+    bsp_section_work_begin = .;
+    . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
+    . = ALIGN(8);
+    bsp_section_work_end = .;
+  } > REGION_WORK AT > REGION_WORK
+  bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
+  .stack :   {
+    . = ALIGN(8);
+    bsp_section_stack_begin = .;
+    . += ORIGIN (REGION_STACK) + LENGTH (REGION_STACK) - ABSOLUTE (.);
+    . = ALIGN(8);
+    bsp_section_stack_end = .;
+  } > REGION_STACK AT > REGION_STACK
+  bsp_section_stack_size = bsp_section_stack_begin - bsp_section_stack_end;
+  _RamBase = ORIGIN (REGION_WORK);
+  _RamSize = LENGTH (REGION_WORK);
+  _WorkAreaBase = bsp_section_work_begin;
+  _HeapSize = 0;
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c b/c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c
index 0000000..7644939
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c
@@ -0,0 +1,111 @@
+#include <rtems.h>
+#include <bsp.h>
+#include <rtems/btimer.h>
+#include <rtems/score/epiphany-utility.h>
+extern char bsp_start_vector_table_begin[];
+bool benchmark_timer_find_average_overhead;
+static benchmark_timer1_interrupt_handler(void)
+  unsigned int val = 0xFFFFFFFF;
+  unsigned int event_type = 0x1;
+  /* Embed assembly code for setting timer1 */
+  asm volatile ("movts ctimer1, %[val] \t \n" :: [val] "r" (val));
+  asm volatile ("movfs r16, config; \t \n"
+                "mov   r17, %%low(0xfffff0ff);\t \n"
+                "movt  r17, %%high(0xffff0ff);\t \n"
+                "lsl   r18, %[event_type], 0x8; \t \n"
+                "and   r16, r16, r17; \t \n"
+                "movts config, r16; \t \n"
+                "orr   r16, r16, r18; \t \n"
+                :: [event_type] "r" (event_type));
+/* Start eCore tiemr 1 usef for profiling and timing analysis */
+void benchmark_timer_initialize( void )
+  /* Install interrupt handler for timer 1 */
+  proc_ptr *table =
+    (proc_ptr *) bsp_start_vector_table_begin;
+  table[TIMER1] = benchmark_timer1_interrupt_handler;
+  asm volatile ("mov r0, 0x0; \n \t"
+                "movts config, r0; \t \n"::);
+ *  The following controls the behavior of benchmark_timer_read().
+ *  AVG_OVEREHAD is the overhead for starting and stopping the timer.  It
+ *  is usually deducted from the number returned.
+ *  LEAST_VALID is the lowest number this routine should trust.  Numbers
+ *  below this are "noise" and zero is returned.
+#define AVG_OVERHEAD      0  /* It typically takes X.X microseconds */
+                             /* (Y countdowns) to start/stop the timer. */
+                             /* This value is in microseconds. */
+#define LEAST_VALID       1  /* Don't trust a clicks value lower than this */
+benchmark_timer_t benchmark_timer_read( void )
+  uint32_t timer_val = 0;
+  uint32_t total;
+  asm volatile ("movfs %[timer_val], ctimer1 \t \n"
+  :[timer_val] "=r" (timer_val):);
+  total = (0xFFFFFFFF - timer_val); /* Convert to uS */
+  if ( benchmark_timer_find_average_overhead == true )
+    return total;
+  else {
+    if ( total < LEAST_VALID )
+      return 0;            /* below timer resolution */
+   *  Somehow convert total into microseconds
+      return (total - AVG_OVERHEAD);
+void benchmark_timer_disable_subtracting_average_overhead(
+  bool find_flag
+  benchmark_timer_find_average_overhead = find_flag;
diff --git a/c/src/lib/libbsp/epiphany/preinstall.am b/c/src/lib/libbsp/epiphany/preinstall.am
index 0000000..dba6cc4
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/preinstall.am
@@ -0,0 +1,6 @@
+if AMPOLISH3
+endif
diff --git a/c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h b/c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h
index 0000000..c218b7f
--- /dev/null
+++ b/c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h
@@ -0,0 +1,81 @@
+#ifndef LIBBSP_EPIPHANY_SHARED_LINKER_SYMBOLS_H
+#define LIBBSP_EPIPHANY_SHARED_LINKER_SYMBOLS_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup epiphany_linker Linker Support
+ * @ingroup epiphany_shared
+ * @brief Linker support.
+#ifndef ASM
+  #define LINKER_SYMBOL(sym) extern char sym [];
+#else
+  #define LINKER_SYMBOL(sym) .extern sym
+#endif
+LINKER_SYMBOL(bsp_section_start_begin)
+LINKER_SYMBOL(bsp_section_start_end)
+LINKER_SYMBOL(bsp_section_start_size)
+LINKER_SYMBOL(bsp_section_vector_begin)
+LINKER_SYMBOL(bsp_section_vector_end)
+LINKER_SYMBOL(bsp_section_vector_size)
+LINKER_SYMBOL(bsp_section_text_begin)
+LINKER_SYMBOL(bsp_section_text_end)
+LINKER_SYMBOL(bsp_section_text_size)
+LINKER_SYMBOL(bsp_section_text_load_begin)
+LINKER_SYMBOL(bsp_section_text_load_end)
+LINKER_SYMBOL(bsp_section_rodata_begin)
+LINKER_SYMBOL(bsp_section_rodata_end)
+LINKER_SYMBOL(bsp_section_rodata_size)
+LINKER_SYMBOL(bsp_section_rodata_load_begin)
+LINKER_SYMBOL(bsp_section_rodata_load_end)
+LINKER_SYMBOL(bsp_section_data_begin)
+LINKER_SYMBOL(bsp_section_data_end)
+LINKER_SYMBOL(bsp_section_data_size)
+LINKER_SYMBOL(bsp_section_data_load_begin)
+LINKER_SYMBOL(bsp_section_data_load_end)
+LINKER_SYMBOL(bsp_section_bss_begin)
+LINKER_SYMBOL(bsp_section_bss_end)
+LINKER_SYMBOL(bsp_section_bss_size)
+LINKER_SYMBOL(bsp_section_work_begin)
+LINKER_SYMBOL(bsp_section_work_end)
+LINKER_SYMBOL(bsp_section_work_size)
+LINKER_SYMBOL(bsp_section_stack_begin)
+LINKER_SYMBOL(bsp_section_stack_end)
+LINKER_SYMBOL(bsp_section_stack_size)
+LINKER_SYMBOL(bsp_vector_table_begin)
+LINKER_SYMBOL(bsp_vector_table_end)
+LINKER_SYMBOL(bsp_vector_table_size)
+LINKER_SYMBOL(bsp_start_vector_table_begin)
+LINKER_SYMBOL(bsp_start_vector_table_end)
+LINKER_SYMBOL(bsp_start_vector_table_size)
+LINKER_SYMBOL(bsp_translation_table_base)
+LINKER_SYMBOL(bsp_translation_table_end)
+LINKER_SYMBOL(_bsp_processor_count)
+#ifdef __cplusplus
+#endif /* LIBBSP_EPIPHANY_SHARED_LINKER_SYMBOLS_H */
2.1.0
