[PATCH 1/2] cpukit: Add Epiphany architecture port
Fri May 8 15:00:29 UTC 2015
You should aim to write doxygen for the port-specific headers at least.
On Thu, May 7, 2015 at 10:11 PM, Hesham ALMatary
<heshamelmatary at gmail.com> wrote:
>  cpukit/configure.ac                                |    1 +
>  cpukit/librpc/src/xdr/xdr_float.c                  |    1 +
>  cpukit/score/cpu/Makefile.am                       |    1 +
>  cpukit/score/cpu/epiphany/Makefile.am              |   33 +
>  cpukit/score/cpu/epiphany/cpu.c                    |   99 ++
>  .../cpu/epiphany/epiphany-context-initialize.c     |   49 +
>  .../score/cpu/epiphany/epiphany-context-switch.S   |  197 ++++
>  .../cpu/epiphany/epiphany-exception-handler.S      |  290 +++++
>  cpukit/score/cpu/epiphany/preinstall.am            |   53 +
>  cpukit/score/cpu/epiphany/rtems/asm.h              |   97 ++
>  cpukit/score/cpu/epiphany/rtems/score/cpu.h        | 1171 ++++++++++++++++++++
>  cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h    |   74 ++
>  cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h  |   14 +
>  .../cpu/epiphany/rtems/score/epiphany-utility.h    |  180 +++
>  cpukit/score/cpu/epiphany/rtems/score/epiphany.h   |   50 +
>  cpukit/score/cpu/epiphany/rtems/score/types.h      |   55 +
>  16 files changed, 2365 insertions(+)
>  create mode 100644 cpukit/score/cpu/epiphany/Makefile.am
>  create mode 100644 cpukit/score/cpu/epiphany/cpu.c
>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-context-initialize.c
>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-context-switch.S
>  create mode 100644 cpukit/score/cpu/epiphany/epiphany-exception-handler.S
>  create mode 100644 cpukit/score/cpu/epiphany/preinstall.am
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/asm.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpu.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/epiphany.h
>  create mode 100644 cpukit/score/cpu/epiphany/rtems/score/types.h
> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
> index 2b432f6..46942c9 100644
> --- a/cpukit/configure.ac
> +++ b/cpukit/configure.ac
> @@ -453,6 +453,7 @@ score/cpu/Makefile
>  score/cpu/arm/Makefile
>  score/cpu/bfin/Makefile
>  score/cpu/avr/Makefile
> +score/cpu/epiphany/Makefile
>  score/cpu/h8300/Makefile
>  score/cpu/i386/Makefile
>  score/cpu/lm32/Makefile
> diff --git a/cpukit/librpc/src/xdr/xdr_float.c b/cpukit/librpc/src/xdr/xdr_float.c
> index 925b294..ac8c46d 100644
> --- a/cpukit/librpc/src/xdr/xdr_float.c
> +++ b/cpukit/librpc/src/xdr/xdr_float.c
> @@ -61,6 +61,7 @@ static char *rcsid = "$FreeBSD: src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
>  #if defined(__alpha__) || \
>      defined(_AM29K) || \
>      defined(__arm__) || \
> +    defined(__epiphany__) ||  defined(__EPIPHANY__) || \
>      defined(__H8300__) || defined(__h8300__) || \
>      defined(__hppa__) || \
>      defined(__i386__) || \
> diff --git a/cpukit/score/cpu/Makefile.am b/cpukit/score/cpu/Makefile.am
> index 69abcd6..7279d38 100644
> --- a/cpukit/score/cpu/Makefile.am
> +++ b/cpukit/score/cpu/Makefile.am
> @@ -4,6 +4,7 @@ DIST_SUBDIRS =
>  DIST_SUBDIRS += arm
>  DIST_SUBDIRS += avr
>  DIST_SUBDIRS += bfin
> +DIST_SUBDIRS += epiphany
>  DIST_SUBDIRS += h8300
>  DIST_SUBDIRS += i386
>  DIST_SUBDIRS += lm32
> diff --git a/cpukit/score/cpu/epiphany/Makefile.am b/cpukit/score/cpu/epiphany/Makefile.am
> new file mode 100644
> index 0000000..0df3376
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/Makefile.am
> @@ -0,0 +1,33 @@
> +include $(top_srcdir)/automake/compile.am
> +CLEANFILES =
> +DISTCLEANFILES =
> +include_rtemsdir = $(includedir)/rtems
> +include_rtems_HEADERS = rtems/asm.h
> +include_rtems_scoredir = $(includedir)/rtems/score
> +include_rtems_score_HEADERS =
> +include_rtems_score_HEADERS += rtems/score/cpu.h
> +include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> +include_rtems_score_HEADERS += rtems/score/cpu_asm.h
> +include_rtems_score_HEADERS += rtems/score/types.h
> +include_rtems_score_HEADERS += rtems/score/epiphany.h
> +include_rtems_score_HEADERS += rtems/score/epiphany-utility.h
> +noinst_LIBRARIES = libscorecpu.a
> +libscorecpu_a_SOURCES  = cpu.c
> +libscorecpu_a_SOURCES += epiphany-exception-handler.S
> +libscorecpu_a_SOURCES += epiphany-context-switch.S
> +libscorecpu_a_SOURCES += epiphany-context-initialize.c
Remove extra blank line
> +libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> +all-local: $(PREINSTALL_FILES)
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/score/cpu/epiphany/cpu.c b/cpukit/score/cpu/epiphany/cpu.c
> index 0000000..0558dbb
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/cpu.c
> @@ -0,0 +1,99 @@
> + *  Epiphany CPU Dependent Source
> + *  COPYRIGHT (c) 2015 University of York.
> + *  Hesham ALMatary <hmka501 at york.ac.uk>
I'd prefer the Copyright on a single line, don't need all caps for
COPYRIGHT, even though the OAR one is like that.
> + *  COPYRIGHT (c) 1989-1999.
> + *  On-Line Applications Research Corporation (OAR).
I also question whether OAR actually holds a copyright on the contents
here but that is a different matter.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#include <rtems/system.h>
> +#include <rtems/score/isr.h>
> +#include <rtems/score/wkspace.h>
> +#include <bsp/linker-symbols.h>
> +#include <rtems/score/cpu.h>
> +void _init(void);
> +void _fini(void);
> +void _init(void)
> +  /* Do nothing */
> +void _fini(void)
> +  /* Do nothing */
> +void _CPU_Exception_frame_print (const CPU_Exception_frame *ctx)
> +  /* Do nothing */
> + * @brief Performs processor dependent initialization.
> +void _CPU_Initialize(void)
> +  /* Do nothing */
> +void _CPU_ISR_Set_level(uint32_t level)
> +  /* Do nothing */
> +uint32_t  _CPU_ISR_Get_level( void )
> +  /* Do nothing */
> +  return 0;
> +void _CPU_ISR_install_raw_handler(
> +  uint32_t   vector,
> +  proc_ptr    new_handler,
> +  proc_ptr   *old_handler
> +  /* Do nothing */
> +void _CPU_ISR_install_vector(
> +  uint32_t    vector,
> +  /* Do nothing */
> +void _CPU_Install_interrupt_stack( void )
> +  /* Do nothing */
> +CPU_Counter_ticks _CPU_Counter_read( void )
> +  static CPU_Counter_ticks counter;
> +  CPU_Counter_ticks snapshot;
> +  snapshot = counter;
> +  counter = snapshot + 1;
> +  return snapshot;
> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
> +  do {
> +    asm volatile ("idle");
Please use __asm__ __volatile__.
> +  } while (1);
> +  return (void *) 0;
A general comment, perhaps this function should be declared with the
'no return' attribute (likely on every port.)
> diff --git a/cpukit/score/cpu/epiphany/epiphany-context-initialize.c b/cpukit/score/cpu/epiphany/epiphany-context-initialize.c
> index 0000000..f92c46e
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/epiphany-context-initialize.c
> @@ -0,0 +1,49 @@
> + * COPYRIGHT (c) 1989-2006
> + * http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <string.h>
> +#include <rtems/score/interr.h>
> +void _CPU_Context_Initialize(
> +  Context_Control *context,
> +  void *stack_area_begin,
> +  size_t stack_area_size,
> +  uint32_t new_level,
> +  void (*entry_point)( void ),
> +  bool is_fp,
> +  void *tls_area
> +  uint32_t stack = ((uint32_t) stack_area_begin);
We should prefer to use uintptr_t when casting pointers into integer types.
> +  uint32_t sr, config, iret;
> +  /* Account for red-zone */
> +  uint32_t stack_high = stack + stack_area_size - 128;
A macro for the 128 would be nice eg RED_ZONE_SIZE.
> +  asm volatile ("movfs %0, status \n" : "=r" (sr):);
> +  asm volatile ("movfs %0, config \n" : "=r" (config):);
Is this config unused?
> +  asm volatile ("movfs %0, iret \n" : "=r" (iret):);
> +  memset(context, 0, sizeof(*context));
> +  context->r[13] = stack_high;
> +  context->r[11] = stack_high;
I'd prefer to see the stores sorted, e.g. r[13] then r[11], unless the
store order matters.
> +  context->r[14] = (uint32_t) entry_point;
Pointer cast.
> +  context->status = sr;
> +  context->iret = iret;
> diff --git a/cpukit/score/cpu/epiphany/epiphany-context-switch.S b/cpukit/score/cpu/epiphany/epiphany-context-switch.S
> index 0000000..3bb3bf3
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/epiphany-context-switch.S
> @@ -0,0 +1,197 @@
> +#endif
> +#include <rtems/asm.h>
> +.section .text,"ax";
Put space after comma. Is the ; needed here? It's not used elsewhere.
> +.align 4
> +PUBLIC(_CPU_Context_switch)
> +PUBLIC(_CPU_Context_restore)
> +PUBLIC(_CPU_Context_restore_fp)
> +PUBLIC(_CPU_Context_save_fp)
> +PUBLIC(restore)
> +SYM(_CPU_Context_switch):
> +  /* Disable interrupts and store all registers */
What does the ABI say about register use, what needs to be
saved/restored here, and in the ISR handler? Does it really all need
to be done, or is there room for optimization later?
> +  gid
> +  str r0,  [r0]
> +  str r1,  [r0,1]
> +  str r2,  [r0,2]
> +  str r3,  [r0,3]
> +  str r4,  [r0,4]
> +  str r5,  [r0,5]
> +  str r6,  [r0,6]
> +  str r7,  [r0,7]
> +  str r8,  [r0,8]
> +  str r9,  [r0,9]
> +  str r10, [r0,10]
> +  str fp,  [r0,11]
> +  str r12, [r0,12]
> +  str sp,  [r0,13]
> +  str lr,  [r0,14]
> +  str r15, [r0,15]
> +  str r16, [r0,16]
> +  str r17, [r0,17]
> +  str r18, [r0,18]
> +  str r19, [r0,19]
> +  str r20, [r0,20]
> +  str r21, [r0,21]
> +  str r22, [r0,22]
> +  str r23, [r0,23]
> +  str r24, [r0,24]
> +  str r25, [r0,25]
> +  str r26, [r0,26]
> +  str r27, [r0,27]
> +  str r28, [r0,28]
> +  str r29, [r0,29]
> +  str r30, [r0,30]
> +  str r31, [r0,31]
> +  str r32, [r0,32]
> +  str r33, [r0,33]
> +  str r34, [r0,34]
> +  str r35, [r0,35]
> +  str r36, [r0,36]
> +  str r37, [r0,37]
> +  str r38, [r0,38]
> +  str r39, [r0,39]
> +  str r40, [r0,40]
> +  str r41, [r0,41]
> +  str r42, [r0,42]
> +  str r43, [r0,43]
> +  str r44, [r0,44]
> +  str r45, [r0,45]
> +  str r46, [r0,46]
> +  str r47, [r0,47]
> +  str r48, [r0,48]
> +  str r49, [r0,49]
> +  str r50, [r0,50]
> +  str r51, [r0,51]
> +  str r52, [r0,52]
> +  str r53, [r0,53]
> +  str r54, [r0,54]
> +  str r55, [r0,55]
> +  str r56, [r0,56]
> +  str r57, [r0,57]
> +  str r58, [r0,58]
> +  str r59, [r0,59]
> +  str r60, [r0,60]
> +  str r61, [r0,61]
> +  str r62, [r0,62]
> +  str r63, [r0,63]
> +  /* Store status register */
> +  movfs r27, status
> +  str r27, [r0,64]
> +  /* Store config register */
> +  movfs r27, config
> +  str r27, [r0,65]
> +  /* Store interrupt return address register */
> +  movfs r27, iret
> +  str r27, [r0,66]
> +SYM(restore):
> +  /* r1 contains buffer address, skip it */
> +  ldr r2,  [r1,2]
> +  ldr r3,  [r1,3]
> +  ldr r4,  [r1,4]
> +  ldr r5,  [r1,5]
> +  ldr r6,  [r1,6]
> +  ldr r7,  [r1,7]
> +  ldr r8,  [r1,8]
> +  ldr r9,  [r1,9]
> +  ldr r10, [r1,10]
> +  ldr fp,  [r1,11]
> +  ldr r12, [r1,12]
> +  ldr sp,  [r1,13]
> +  ldr lr,  [r1,14]
> +  ldr r15, [r1,15]
> +  ldr r16, [r1,16]
> +  ldr r17, [r1,17]
> +  ldr r18, [r1,18]
> +  ldr r19, [r1,19]
> +  ldr r20, [r1,20]
> +  ldr r21, [r1,21]
> +  ldr r22, [r1,22]
> +  ldr r23, [r1,23]
> +  ldr r24, [r1,24]
> +  ldr r25, [r1,25]
> +  ldr r26, [r1,26]
> +  ldr r27, [r1,27]
> +  ldr r32, [r1,32]
> +  ldr r33, [r1,33]
> +  ldr r34, [r1,34]
> +  ldr r35, [r1,35]
> +  ldr r36, [r1,36]
> +  ldr r37, [r1,37]
> +  ldr r38, [r1,38]
> +  ldr r39, [r1,39]
> +  ldr r40, [r1,40]
> +  ldr r41, [r1,41]
> +  ldr r42, [r1,42]
> +  ldr r43, [r1,43]
> +  ldr r44, [r1,44]
> +  ldr r45, [r1,45]
> +  ldr r46, [r1,46]
> +  ldr r47, [r1,47]
> +  ldr r48, [r1,48]
> +  ldr r49, [r1,49]
> +  ldr r50, [r1,50]
> +  ldr r51, [r1,51]
> +  ldr r52, [r1,52]
> +  ldr r53, [r1,53]
> +  ldr r54, [r1,54]
> +  ldr r55, [r1,55]
> +  ldr r56, [r1,56]
> +  ldr r57, [r1,57]
> +  ldr r58, [r1,58]
> +  ldr r59, [r1,59]
> +  ldr r60, [r1,60]
> +  ldr r61, [r1,61]
> +  ldr r62, [r1,62]
> +  ldr r63, [r1,63]
> +  /* Load status register */
> +  ldr r0, [r1,64]
> +  movts status, r0
> +  /* Load config register */
> +  ldr r0, [r1,65]
> +  movts config, r0
> +  /* Load interrupt return address register */
> +  ldr r0,[r1,66]
> +  movts iret, r0
> +  ldr r0,[r1]
> +  ldr r1,[r1,1]
> +  /* Enable interrupts and return */
> +  gie
> +  jr lr
> +SYM(_CPU_Context_restore):
> +  mov     r1, r0
> +  b       _restore
> +  nop
> +/* No FP support for Epiphany yet */
> +SYM(_CPU_Context_restore_fp):
> +  nop
> + SYM(_CPU_Context_save_fp):
> +  nop
> diff --git a/cpukit/score/cpu/epiphany/epiphany-exception-handler.S b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
> index 0000000..169329f
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/epiphany-exception-handler.S
> @@ -0,0 +1,290 @@
> + * @file
> + * @ingroup ScoreCPU
> + * @brief Epiphany exception support implementation.
> +#include "config.h"
> +#endif
> +#include <rtems/score/percpu.h>
> +.extern _bsp_start_vector_table_begin
> +.extern __Thread_Dispatch
See below about EXTERN macro.
> +.section .text, "ax"
> +.align 4
> +.global _ISR_Handler;
> +.type _ISR_Handler, %function;
Again, it would be better to be consistent in using the terminating
semi-colon. Also, shouldn't these be using the PUBLIC and SYM macros?
Should you introduce a macro for this .type directive also?
> +_ISR_Handler:
> +  /* Reserve space for CPU_Exception_frame */
> +  add sp, sp, #-280
Define a macro for the size of the frame in the epiphany.h file.
> +  str r0,[sp]
> +  str r1,[sp,1]
> +  str r2,[sp,2]
> +  /* Save config register */
> +  movfs r1,config
> +  str r1, [sp,65]
Is there a reason this is done here instead of later?
> +  str r3,  [sp,3]
> +  str r4,  [sp,4]
> +  str r5,  [sp,5]
> +  str r6,  [sp,6]
> +  str r7,  [sp,7]
> +  str r8,  [sp,8]
> +  str r9,  [sp,9]
> +  str r10, [sp,10]
> +  str fp,  [sp,11]
> +  str r12, [sp,12]
You could probably save the sp here too instead of below.
> +  str lr,  [sp,14]
> +  str r15, [sp,15]
> +  str r16, [sp,16]
> +  str r17, [sp,17]
> +  str r18, [sp,18]
> +  str r19, [sp,19]
> +  str r20, [sp,20]
> +  str r21, [sp,21]
> +  str r22, [sp,22]
> +  str r23, [sp,23]
> +  str r24, [sp,24]
> +  str r25, [sp,25]
> +  str r26, [sp,26]
> +  str r27, [sp,27]
> +  str r28, [sp,28]
> +  str r29, [sp,29]
> +  str r30, [sp,30]
> +  str r31, [sp,31]
> +  str r32, [sp,32]
> +  str r33, [sp,33]
> +  str r34, [sp,34]
> +  str r35, [sp,35]
> +  str r36, [sp,36]
> +  str r37, [sp,37]
> +  str r38, [sp,38]
> +  str r39, [sp,39]
> +  str r40, [sp,40]
> +  str r41, [sp,41]
> +  str r42, [sp,42]
> +  str r43, [sp,43]
> +  str r44, [sp,44]
> +  str r45, [sp,45]
> +  str r46, [sp,46]
> +  str r47, [sp,47]
> +  str r48, [sp,48]
> +  str r49, [sp,49]
> +  str r50, [sp,50]
> +  str r51, [sp,51]
> +  str r52, [sp,52]
> +  str r53, [sp,53]
> +  str r54, [sp,54]
> +  str r55, [sp,55]
> +  str r56, [sp,56]
> +  str r57, [sp,57]
> +  str r58, [sp,58]
> +  str r59, [sp,59]
> +  str r60, [sp,60]
> +  str r61, [sp,61]
> +  str r62, [sp,62]
> +  str r63, [sp,63]
> +  /* Save status register */
> +  movfs r1,status
> +  str r1, [sp,64]
> +  /* Save interrupt return address register */
> +  movfs r1,iret
> +  str r1, [sp,66]
> +  /* Save interrupted task stack pointer */
> +  add r1, sp, #288
Why 288 and not 280? Use a macro.
> +  str r1,[sp,13]
> +  mov  r18, %low(__Per_CPU_Information)
> +  movt r18, %high(__Per_CPU_Information)
why not just use r33 here instead of r18 and then having to
save/restore from it?
> +       add  r6, r18, #(PER_CPU_ISR_NEST_LEVEL)
> +       add  r8, r18, #(PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)
> +  /* Increment nesting level and disable thread dispatch */
> +  ldr  r5, [r6]
> +  ldr  r7, [r8]
> +  add  r5, r5, #1
> +  add  r7, r7, #1
> +  str  r5, [r6]
> +  str  r7, [r8]
> +  /* Keep sp (Exception frame address) in r32 - Callee saved */
> +  mov  r32, sp
> +  /* Keep __Per_CPU_Information address in r33 - Callee saved */
> +  mov  r33, r18
> +  /* Call the exception handler from vector table.
> +   * First function arg for C handler is vector number,
> +   * and the second is a pointer to exception frame.
> +  mov  r0,  r62
> +  mov  r1,  sp
> +  mov  r27, r62
> +  lsl  r27, r27, #2
> +  mov  r26, %low(_bsp_start_vector_table_begin)
Don't need %high()?
> +  movt r15, #0
> +  add  r27, r27, r26
> +  ldr  r27, [r27]
> +  /* Do not switch stacks if we are in a nested interrupt. At
> +   * this point r5 should be holding ISR_NEST_LEVEL value.
> +  sub  r37, r5, #1
> +  bgtu jump_to_c_handler
> +  /* Switch to RTEMS dedicated interrupt stack */
> +  add     sp, r18, #(PER_CPU_INTERRUPT_STACK_HIGH)
> +  ldr     sp, [sp]
> +jump_to_c_handler:
> +  jalr r27
> +  /* Switch back to the interrupted task stack */
> +  mov  sp, r32
> +  /* Get the address of __Per_CPU_Information */
> +  mov r18, r33
> +  /* Decrement nesting level and enable multitasking */
> +  ldr     r5, [r6]
> +  ldr     r7, [r8]
> +  sub     r5, r5, #1
> +  sub     r7, r7, #1
> +  str     r5, [r6]
> +  str     r7, [r8]
> +  /* Check if _ISR_Nest_level > 0 */
> +  sub     r37, r5, #0
> +  bgtu    exception_frame_restore
> +  /* Check if _Thread_Dispatch_disable_level > 0 */
> +  sub     r37, r7, #0
> +  /* Check if dispatch needed */
> +  add     r31, r18, #(PER_CPU_DISPATCH_NEEDED)
> +  ldr     r31, [r31]
> +  sub     r35, r31, #0
> +  beq     exception_frame_restore
> +  mov     r35, %low(__Thread_Dispatch)
> +  movt    r35, %high(__Thread_Dispatch)
> +  jalr    r35
> +exception_frame_restore:
> +  ldr r1,  [sp,1]
> +  ldr r3,  [sp,3]
> +  ldr r4,  [sp,4]
> +  ldr r5,  [sp,5]
> +  ldr r6,  [sp,6]
> +  ldr r7,  [sp,7]
> +  ldr r8,  [sp,8]
> +  ldr r9,  [sp,9]
> +  ldr r10, [sp,10]
> +  ldr fp,  [sp,11]
> +  ldr r12, [sp,12]
> +  ldr lr,  [sp,14]
> +  ldr r15, [sp,15]
> +  ldr r16, [sp,16]
> +  ldr r17, [sp,17]
> +  ldr r18, [sp,18]
> +  ldr r19, [sp,19]
> +  ldr r20, [sp,20]
> +  ldr r21, [sp,21]
> +  ldr r22, [sp,22]
> +  ldr r23, [sp,23]
> +  ldr r24, [sp,24]
> +  ldr r25, [sp,25]
> +  ldr r26, [sp,26]
> +  ldr r27, [sp,27]
> +  ldr r28, [sp,28]
> +  ldr r29, [sp,29]
> +  ldr r30, [sp,30]
> +  ldr r31, [sp,31]
> +  ldr r32, [sp,32]
> +  ldr r34, [sp,34]
> +  ldr r36, [sp,36]
> +  ldr r38, [sp,38]
> +  ldr r39, [sp,39]
> +  ldr r40, [sp,40]
> +  ldr r41, [sp,41]
> +  ldr r42, [sp,42]
> +  ldr r43, [sp,43]
> +  ldr r44, [sp,44]
> +  ldr r45, [sp,45]
> +  ldr r46, [sp,46]
> +  ldr r47, [sp,47]
> +  ldr r48, [sp,48]
> +  ldr r49, [sp,49]
> +  ldr r50, [sp,50]
> +  ldr r51, [sp,51]
> +  ldr r52, [sp,52]
> +  ldr r53, [sp,53]
> +  ldr r54, [sp,54]
> +  ldr r55, [sp,55]
> +  ldr r56, [sp,56]
> +  ldr r57, [sp,57]
> +  ldr r58, [sp,58]
> +  ldr r59, [sp,59]
> +  ldr r60, [sp,60]
> +  ldr r61, [sp,61]
> +  ldr r62, [sp,62]
> +  ldr r63, [sp,63]
> +  /* Restore status register */
> +  ldr r0,[sp,64]
> +  movts status, r0
> +  /* Restore config register */
> +  ldr r0, [sp,65]
> +  movts config, r0
> +  /* Restore interrupt return address register */
> +  ldr   r0, [sp,66]
> +  movts iret, r0
> +  /* Now buffer address held on r0 can be overwritten */
> +  ldr r0,[sp]
> +  ldr r2,[sp,2]
> +  /* Unwind exception frame */
Why not restore the interrupted sp from [sp, 13] where it was previously stored?
> +  add sp, sp, #280
> +  ldr r62, [sp, #4]
> +  ldr r63, [sp, #8]
Why doing this here? Weren't these already restored?
> +  add sp, sp, #8
I still don't know why the extra 8 bytes.
> +  /* return from interrupt */
> +  rti
> diff --git a/cpukit/score/cpu/epiphany/preinstall.am b/cpukit/score/cpu/epiphany/preinstall.am
> index 0000000..0250d12
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/preinstall.am
> @@ -0,0 +1,52 @@
> +## Automatically generated by ampolish3 - Do not edit
> +if AMPOLISH3
> +$(srcdir)/preinstall.am: Makefile.am
> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> +endif
> +PREINSTALL_DIRS =
> +DISTCLEANFILES += $(PREINSTALL_DIRS)
> +all-am: $(PREINSTALL_FILES)
> +PREINSTALL_FILES =
> +CLEANFILES += $(PREINSTALL_FILES)
> +$(PROJECT_INCLUDE)/rtems/$(dirstamp):
> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
> +       @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
> +$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
> +       @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
> +$(PROJECT_INCLUDE)/rtems/score/cpuatomic.h: rtems/score/cpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpuatomic.h
> +$(PROJECT_INCLUDE)/rtems/score/cpu_asm.h: rtems/score/cpu_asm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu_asm.h
> +$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
> +$(PROJECT_INCLUDE)/rtems/score/epiphany.h: rtems/score/epiphany.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/epiphany.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/epiphany.h
> +$(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h: rtems/score/epiphany-utility.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/epiphany-utility.h
> diff --git a/cpukit/score/cpu/epiphany/rtems/asm.h b/cpukit/score/cpu/epiphany/rtems/asm.h
> index 0000000..4ded5d9
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/asm.h
> @@ -0,0 +1,97 @@
> + * @file rtems/asm.h
> + *  This include file attempts to address the problems
> + *  caused by incompatible flavors of assemblers and
> + *  toolsets.  It primarily addresses variations in the
> + *  use of leading underscores on symbols and the requirement
> + *  that register names be preceded by a %.
> + *  NOTE: The spacing in the use of these macros
> + *        is critical to them working as advertised.
> + *  COPYRIGHT:
> + *  This file is based on similar code found in newlib available
> + *  from ftp.cygnus.com.  The file which was used had no copyright
> + *  notice.  This file is freely distributable as long as the source
> + *  of the file is noted.  This file is:
> + *  COPYRIGHT (c) 1994-1997.
> +#ifndef __EPIPHANY_ASM_H
> +#define __EPIPHANY_ASM_H
> + *  Indicate we are in an assembly file and get the basic CPU definitions.
> +#ifndef ASM
> +#define ASM
> +#endif
> +#include <rtems/score/cpuopts.h>
> +#include <rtems/score/epiphany.h>
> + *  Recent versions of GNU cpp define variables which indicate the
> + *  need for underscores and percents.  If not using GNU cpp or
> + *  the version does not support this, then you will obviously
> + *  have to define these as appropriate.
> +#ifndef __USER_LABEL_PREFIX__
> +#define __USER_LABEL_PREFIX__ _
> +#endif
> +#ifndef __REGISTER_PREFIX__
> +#define __REGISTER_PREFIX__
> +#endif
> +/* ANSI concatenation macros.  */
> +#define CONCAT1(a, b) CONCAT2(a, b)
> +#define CONCAT2(a, b) a ## b
> +/* Use the right prefix for global labels.  */
> +#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> +/* Use the right prefix for registers.  */
> +#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> + *  define macros for all of the registers on this CPU
> + *  EXAMPLE:     #define d0 REG (d0)
> + *  Define macros to handle section beginning and ends.
> +#define BEGIN_CODE_DCL .text
> +#define END_CODE_DCL
> +#define BEGIN_DATA_DCL .data
> +#define END_DATA_DCL
> +#define BEGIN_CODE .text
> +#define END_CODE
> +#define BEGIN_DATA
> +#define END_DATA
> +#define BEGIN_BSS
> +#define END_BSS
> +#define END
> + *  Following must be tailor for a particular flavor of the C compiler.
> + *  They may need to put underscores in front of the symbols.
> +#define PUBLIC(sym) .global SYM (sym)
> +#define EXTERN(sym) .global SYM (sym)
Maybe you want to use '.extern SYM (sym)'? Then you can use this in
your assembly.
> +#endif
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> index 0000000..eb29b2a
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
> @@ -0,0 +1,1171 @@
> + * @file rtems/score/cpu.h
> + *  This include file contains macros pertaining to the Opencores
> + *  Epiphany processor family.
> + *  This file adapted from no_cpu example of the RTEMS distribution.
> + *  The body has been modified for the Opencores epiphany implementation by
> + *  Chris Ziomkowski. <chris at asics.ws>
> +#ifndef _EPIPHANY_CPU_H
> +#define _EPIPHANY_CPU_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <rtems/score/epiphany.h>            /* pick up machine definitions */
> +#include <rtems/score/types.h>
> +#ifndef ASM
> +#include <rtems/bspIo.h>
> +#include <stdint.h>
> +#include <stdio.h> /* for printk */
> +#endif
> +/* conditional compilation parameters */
> + *  Should the calls to _Thread_Enable_dispatch be inlined?
> + *  If TRUE, then they are inlined.
> + *  If FALSE, then a subroutine call is made.
> + *  Basically this is an example of the classic trade-off of size
> + *  versus speed.  Inlining the call (TRUE) typically increases the
> + *  size of RTEMS while speeding up the enabling of dispatching.
> + *  [NOTE: In general, the _Thread_Dispatch_disable_level will
> + *  only be 0 or 1 unless you are in an interrupt handler and that
> + *  interrupt handler invokes the executive.]  When not inlined
> + *  something calls _Thread_Enable_dispatch which in turns calls
> + *  _Thread_Dispatch.  If the enable dispatch is inlined, then
> + *  one subroutine call is avoided entirely.]
> +#define CPU_INLINE_ENABLE_DISPATCH       FALSE
> + *  Should the body of the search loops in _Thread_queue_Enqueue_priority
> + *  be unrolled one time?  In unrolled each iteration of the loop examines
> + *  two "nodes" on the chain being searched.  Otherwise, only one node
> + *  is examined per iteration.
> + *  If TRUE, then the loops are unrolled.
> + *  If FALSE, then the loops are not unrolled.
> + *  The primary factor in making this decision is the cost of disabling
> + *  and enabling interrupts (_ISR_Flash) versus the cost of rest of the
> + *  body of the loop.  On some CPUs, the flash is more expensive than
> + *  one iteration of the loop body.  In this case, it might be desirable
> + *  to unroll the loop.  It is important to note that on some CPUs, this
> + *  code is the longest interrupt disable period in RTEMS.  So it is
> + *  necessary to strike a balance when setting this parameter.
> +#define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
> + *  Does RTEMS manage a dedicated interrupt stack in software?
> + *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
> + *  If FALSE, nothing is done.
> + *  If the CPU supports a dedicated interrupt stack in hardware,
> + *  then it is generally the responsibility of the BSP to allocate it
> + *  and set it up.
> + *  If the CPU does not support a dedicated interrupt stack, then
> + *  the porter has two options: (1) execute interrupts on the
> + *  stack of the interrupted task, and (2) have RTEMS manage a dedicated
> + *  interrupt stack.
> + *  If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
> + *  Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
> + *  CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
> + *  possible that both are FALSE for a particular CPU.  Although it
> + *  is unclear what that would imply about the interrupt processing
> + *  procedure on that CPU.
> + *  Currently, for epiphany port, _ISR_Handler is responsible for switching to
> + *  RTEMS dedicated interrupt task.
> +#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
> + *  Does this CPU have hardware support for a dedicated interrupt stack?
> + *  If TRUE, then it must be installed during initialization.
> + *  If FALSE, then no installation is performed.
> +#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
> + *  Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
> + *  If TRUE, then the memory is allocated during initialization.
> + *  If FALSE, then the memory is allocated during initialization.
> + *  This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE
> + *  or CPU_INSTALL_HARDWARE_INTERRUPT_STACK is TRUE.
> +#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> + *  Does the RTEMS invoke the user's ISR with the vector number and
> + *  a pointer to the saved interrupt frame (1) or just the vector
> + *  number (0)?
> +#define CPU_ISR_PASSES_FRAME_POINTER 1
> + *  Does the CPU have hardware floating point?
> + *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
> + *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
> + *  If there is a FP coprocessor such as the i387 or mc68881, then
> + *  the answer is TRUE.
> + *  The macro name "epiphany_HAS_FPU" should be made CPU specific.
> + *  It indicates whether or not this CPU model has FP support.  For
> + *  example, it would be possible to have an i386_nofp CPU model
> + *  which set this to false to indicate that you have an i386 without
> + *  an i387 and wish to leave floating point support out of RTEMS.
> + *  The CPU_SOFTWARE_FP is used to indicate whether or not there
> + *  is software implemented floating point that must be context
> + *  switched.  The determination of whether or not this applies
> + *  is very tool specific and the state saved/restored is also
> + *  compiler specific.
> + *  epiphany Specific Information:
> + *  At this time there are no implementations of Epiphany that are
> + *  expected to implement floating point.
> +#define CPU_HARDWARE_FP     FALSE
> +#define CPU_SOFTWARE_FP     FALSE
> + *  Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
> + *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
> + *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
> + *  If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
> +#define CPU_ALL_TASKS_ARE_FP     FALSE
> + *  Should the IDLE task have a floating point context?
> + *  If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
> + *  and it has a floating point context which is switched in and out.
> + *  If FALSE, then the IDLE task does not have a floating point context.
> + *  Setting this to TRUE negatively impacts the time required to preempt
> + *  the IDLE task from an interrupt because the floating point context
> + *  must be saved as part of the preemption.
> +#define CPU_IDLE_TASK_IS_FP      FALSE
> + *  Should the saving of the floating point registers be deferred
> + *  until a context switch is made to another different floating point
> + *  task?
> + *  If TRUE, then the floating point context will not be stored until
> + *  necessary.  It will remain in the floating point registers and not
> + *  disturned until another floating point task is switched to.
> + *  If FALSE, then the floating point context is saved when a floating
> + *  point task is switched out and restored when the next floating point
> + *  task is restored.  The state of the floating point registers between
> + *  those two operations is not specified.
> + *  If the floating point context does NOT have to be saved as part of
> + *  interrupt dispatching, then it should be safe to set this to TRUE.
> + *  Setting this flag to TRUE results in using a different algorithm
> + *  for deciding when to save and restore the floating point context.
> + *  The deferred FP switch algorithm minimizes the number of times
> + *  the FP context is saved and restored.  The FP context is not saved
> + *  until a context switch is made to another, different FP task.
> + *  Thus in a system with only one FP task, the FP context will never
> + *  be saved or restored.
> +#define CPU_USE_DEFERRED_FP_SWITCH       FALSE
> + *  Does this port provide a CPU dependent IDLE task implementation?
> + *  If TRUE, then the routine _CPU_Thread_Idle_body
> + *  must be provided and is the default IDLE thread body instead of
> + *  _CPU_Thread_Idle_body.
> + *  If FALSE, then use the generic IDLE thread body if the BSP does
> + *  not provide one.
> + *  This is intended to allow for supporting processors which have
> + *  a low power or idle mode.  When the IDLE thread is executed, then
> + *  the CPU can be powered down.
> + *  The order of precedence for selecting the IDLE thread body is:
> + *    1.  BSP provided
> + *    2.  CPU dependent (if provided)
> + *    3.  generic (if no BSP and no CPU dependent)
> +#define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
> + *  Does the stack grow up (toward higher addresses) or down
> + *  (toward lower addresses)?
> + *  If TRUE, then the grows upward.
> + *  If FALSE, then the grows toward smaller addresses.
> +#define CPU_STACK_GROWS_UP               FALSE
> + *  The following is the variable attribute used to force alignment
> + *  of critical RTEMS structures.  On some processors it may make
> + *  sense to have these aligned on tighter boundaries than
> + *  the minimum requirements of the compiler in order to have as
> + *  much of the critical data area as possible in a cache line.
> + *  The placement of this macro in the declaration of the variables
> + *  is based on the syntactically requirements of the GNU C
> + *  "__attribute__" extension.  For example with GNU C, use
> + *  the following to force a structures to a 32 byte boundary.
> + *      __attribute__ ((aligned (32)))
> + *  NOTE:  Currently only the Priority Bit Map table uses this feature.
> + *         To benefit from using this, the data must be heavily
> + *         used so it will stay in the cache and used frequently enough
> + *         in the executive to justify turning this on.
> +#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
> + *  Define what is required to specify how the network to host conversion
> + *  routines are handled.
> + *  This version of RTEMS is designed specifically to run with
> + *  big endian architectures. If you want little endian, you'll
> + *  have to make the appropriate adjustments here and write
> + *  efficient routines for byte swapping. The epiphany architecture
> + *  doesn't do this very well.
> +#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES     FALSE
> +#define CPU_BIG_ENDIAN                           FALSE
> +#define CPU_LITTLE_ENDIAN                        TRUE
> + *  The following defines the number of bits actually used in the
> + *  interrupt field of the task mode.  How those bits map to the
> + *  CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
> +#define CPU_MODES_INTERRUPT_MASK   0x00000001
> + *  Processor defined structures required for cpukit/score.
> + * Contexts
> + *  Generally there are 2 types of context to save.
> + *     1. Interrupt registers to save
> + *     2. Task level registers to save
> + *  This means we have the following 3 context items:
> + *     1. task level context stuff::  Context_Control
> + *     2. floating point task stuff:: Context_Control_fp
> + *     3. special interrupt level context :: Context_Control_interrupt
> + *  On some processors, it is cost-effective to save only the callee
> + *  preserved registers during a task context switch.  This means
> + *  that the ISR code needs to save those registers which do not
> + *  persist across function calls.  It is not mandatory to make this
> + *  distinctions between the caller/callee saves registers for the
> + *  purpose of minimizing context saved during task switch and on interrupts.
> + *  If the cost of saving extra registers is minimal, simplicity is the
> + *  choice.  Save the same context on interrupt entry as for tasks in
> + *  this case.
> + *  Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
> + *  care should be used in designing the context area.
> + *  On some CPUs with hardware floating point support, the Context_Control_fp
> + *  structure will not be used or it simply consist of an array of a
> + *  fixed number of bytes.   This is done when the floating point context
> + *  is dumped by a "FP save context" type instruction and the format
> + *  is not really defined by the CPU.  In this case, there is no need
> + *  to figure out the exact format -- only the size.  Of course, although
> + *  this is enough information for RTEMS, it is probably not enough for
> + *  a debugger such as gdb.  But that is another problem.
> +#ifndef ASM
> +typedef struct {
> +  uint32_t  r[64];
> +  uint32_t status;
> +  uint32_t config;
> +  uint32_t iret;
> +#ifdef RTEMS_SMP
> +     * @brief On SMP configurations the thread context must contain a boolean
> +     * indicator to signal if this context is executing on a processor.
> +     * This field must be updated during a context switch.  The context switch
> +     * to the heir must wait until the heir context indicates that it is no
> +     * longer executing on a processor.  The context switch must also check if
> +     * a thread dispatch is necessary to honor updates of the heir thread for
> +     * this processor.  This indicator must be updated using an atomic test and
> +     * set operation to ensure that at most one processor uses the heir
> +     * context at the same time.
> +     * @code
> +     * void _CPU_Context_switch(
> +     *   Context_Control *executing,
> +     *   Context_Control *heir
> +     *   save( executing );
> +     *   executing->is_executing = false;
> +     *   memory_barrier();
> +     *   if ( test_and_set( &heir->is_executing ) ) {
> +     *     do {
> +     *       Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
> +     *       if ( cpu_self->dispatch_necessary ) {
> +     *         heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
> +     *     } while ( test_and_set( &heir->is_executing ) );
> +     *   restore( heir );
> +     * @endcode
> +    volatile bool is_executing;
> +#endif
> +} Context_Control;
> +#define _CPU_Context_Get_SP( _context ) \
> +  (_context)->r[13]
> +typedef struct {
> +  /** FPU registers are listed here */
> +  double  some_float_register;
> +} Context_Control_fp;
> +typedef Context_Control CPU_Interrupt_frame;
> + *  The size of the floating point context area.  On some CPUs this
> + *  will not be a "sizeof" because the format of the floating point
> + *  area is not defined -- only the size is.  This is usually on
> + *  CPUs with a "floating point save context" instruction.
> +#define CPU_CONTEXT_FP_SIZE  0
> +SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
> + *  Amount of extra stack (above minimum stack size) required by
> + *  MPCI receive server thread.  Remember that in a multiprocessor
> + *  system this thread must exist and be able to process all directives.
> +#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> + *  Should be large enough to run all RTEMS tests.  This insures
> + *  that a "reasonable" small application should not have any problems.
> +#define CPU_STACK_MINIMUM_SIZE  4096
> + *  CPU's worst alignment requirement for data types on a byte boundary.  This
> + *  alignment does not take into account the requirements for the stack.
> +#define CPU_ALIGNMENT 8
> + *  This is defined if the port has a special way to report the ISR nesting
> + *  level.  Most ports maintain the variable _ISR_Nest_level.
> +#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> + *  This number corresponds to the byte alignment requirement for the
> + *  heap handler.  This alignment requirement may be stricter than that
> + *  for the data types alignment specified by CPU_ALIGNMENT.  It is
> + *  common for the heap to follow the same alignment requirement as
> + *  CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict enough for the heap,
> + *  then this should be set to CPU_ALIGNMENT.
> + *  NOTE:  This does not have to be a power of 2 although it should be
> + *         a multiple of 2 greater than or equal to 2.  The requirement
> + *         to be a multiple of 2 is because the heap uses the least
> + *         significant field of the front and back flags to indicate
> + *         that a block is in use or free.  So you do not want any odd
> + *         length blocks really putting length data in that bit.
> + *         On byte oriented architectures, CPU_HEAP_ALIGNMENT normally will
> + *         have to be greater or equal to than CPU_ALIGNMENT to ensure that
> + *         elements allocated from the heap meet all restrictions.
> +#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
> + *  This number corresponds to the byte alignment requirement for memory
> + *  buffers allocated by the partition manager.  This alignment requirement
> + *  may be stricter than that for the data types alignment specified by
> + *  CPU_ALIGNMENT.  It is common for the partition to follow the same
> + *  alignment requirement as CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict
> + *  enough for the partition, then this should be set to CPU_ALIGNMENT.
> + *  NOTE:  This does not have to be a power of 2.  It does have to
> + *         be greater or equal to than CPU_ALIGNMENT.
> +#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
> + *  stack.  This alignment requirement may be stricter than that for the
> + *  data types alignment specified by CPU_ALIGNMENT.  If the CPU_ALIGNMENT
> + *  is strict enough for the stack, then this should be set to 0.
> + *  NOTE:  This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
> +#define CPU_STACK_ALIGNMENT        8
> +/* ISR handler macros */
> + *  Support routine to initialize the RTEMS vector table after it is allocated.
> + *  NO_CPU Specific Information:
> + *  XXX document implementation including references if appropriate
> +#define _CPU_Initialize_vectors()
> + *  Disable all interrupts for an RTEMS critical section.  The previous
> + *  level is returned in _level.
> +static inline uint32_t epiphany_interrupt_disable( void )
> +  uint32_t sr;
> +  asm volatile ("movfs %[sr], status \n" : [sr] "=r" (sr):);
__asm__
> +  asm volatile("gid \n");
> +  return sr;
> +static inline void epiphany_interrupt_enable(uint32_t level)
> +  asm volatile("gie \n");
> +  asm volatile ("movts status, %[level] \n" :: [level] "r" (level):);
> +#define _CPU_ISR_Disable( _level ) \
> +    _level = epiphany_interrupt_disable()
> + *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
> + *  This indicates the end of an RTEMS critical section.  The parameter
> + *  _level is not modified.
> +#define _CPU_ISR_Enable( _level )  \
> +  epiphany_interrupt_enable( _level )
> + *  This temporarily restores the interrupt to _level before immediately
> + *  disabling them again.  This is used to divide long RTEMS critical
> + *  sections into two or more parts.  The parameter _level is not
> + *  modified.
> +#define _CPU_ISR_Flash( _level ) \
> +  do{ \
> +      if ( (_level & 0x2) != 0 ) \
> +        _CPU_ISR_Enable( _level ); \
> +      asm volatile("gid \n"); \
Is it guaranteed the _level is correct still, or should you also use
CPU_ISR_DISABLE()?
> +    } while(0)
> + *  Map interrupt level in task mode onto the hardware that the CPU
> + *  actually provides.  Currently, interrupt levels which do not
> + *  map onto the CPU in a generic fashion are undefined.  Someday,
> + *  it would be nice if these were "mapped" by the application
> + *  via a callout.  For example, m68k has 8 levels 0 - 7, levels
> + *  8 - 255 would be available for bsp/application specific meaning.
> + *  This could be used to manage a programmable interrupt controller
> + *  via the rtems_task_mode directive.
> + *  The get routine usually must be implemented as a subroutine.
> +void _CPU_ISR_Set_level( uint32_t level );
> +uint32_t _CPU_ISR_Get_level( void );
> +/* end of ISR handler macros */
> +/* Context handler macros */
> + *  Initialize the context to a state suitable for starting a
> + *  task after a context restore operation.  Generally, this
> + *  involves:
> + *     - setting a starting address
> + *     - preparing the stack
> + *     - preparing the stack and frame pointers
> + *     - setting the proper interrupt level in the context
> + *     - initializing the floating point context
> + *  This routine generally does not set any unnecessary register
> + *  in the context.  The state of the "general data" registers is
> + *  undefined at task start time.
> + *  NOTE: This is_fp parameter is TRUE if the thread is to be a floating
> + *        point thread.  This is typically only used on CPUs where the
> + *        FPU may be easily disabled by software such as on the SPARC
> + *        where the PSR contains an enable FPU bit.
> + * @brief Initializes the CPU context.
> + * The following steps are performed:
> + * @param[in] context points to the context area
> + * @param[in] stack_area_begin is the low address of the allocated stack area
> + * @param[in] stack_area_size is the size of the stack area in bytes
> + * @param[in] new_level is the interrupt level for the task
> + * @param[in] entry_point is the task's entry point
> + * @param[in] is_fp is set to @c true if the task is a floating point task
> + * @param[in] tls_area is the thread-local storage (TLS) area
> +  bool is_fp,
> +  void *tls_area
> + *  This routine is responsible for somehow restarting the currently
> + *  executing task.  If you are lucky, then all that is necessary
> + *  is restoring the context.  Otherwise, there will need to be
> + *  a special assembly routine which does something special in this
> + *  case.  Context_Restore should work most of the time.  It will
> + *  not work if restarting self conflicts with the stack frame
> + *  assumptions of restoring a context.
> +#define _CPU_Context_Restart_self( _the_context ) \
> +   _CPU_Context_restore( (_the_context) );
> + *  The purpose of this macro is to allow the initial pointer into
> + *  a floating point context area (used to save the floating point
> + *  context) to be at an arbitrary place in the floating point
> + *  context area.
> + *  This is necessary because some FP units are designed to have
> + *  their context saved as a stack which grows into lower addresses.
> + *  Other FP units can be saved by simply moving registers into offsets
> + *  from the base of the context area.  Finally some FP units provide
> + *  a "dump context" instruction which could fill in from high to low
> + *  or low to high based on the whim of the CPU designers.
> +#define _CPU_Context_Fp_start( _base, _offset ) \
> +   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
> + *  This routine initializes the FP context area passed to it to.
> + *  There are a few standard ways in which to initialize the
> + *  floating point context.  The code included for this macro assumes
> + *  that this is a CPU in which a "initial" FP context was saved into
> + *  _CPU_Null_fp_context and it simply copies it to the destination
> + *  context passed to it.
> + *  Other models include (1) not doing anything, and (2) putting
> + *  a "null FP status word" in the correct place in the FP context.
> +#define _CPU_Context_Initialize_fp( _destination ) \
> +   *(*(_destination)) = _CPU_Null_fp_context; \
> +/* end of Context handler macros */
> +/* Fatal Error manager macros */
> + *  This routine copies _error into a known place -- typically a stack
> + *  location or a register, optionally disables interrupts, and
> + *  halts/stops the CPU.
> +#define _CPU_Fatal_halt(_source, _error ) \
> +        if(_error == RTEMS_FATAL_SOURCE_EXIT) { \
> +          printk("\nApplication exits normally.!\n"); \
Do we want to print here? I think it is up to an application developer
to decide this.
> +          asm volatile("": : :"memory"); \
> +          asm volatile("gid; halt"); \
> +        else {\
> +          printk("Fatal Error %d.%d Halted\n",_source, _error); \
> +          asm("trap 3" :: "r" (_error)); \
> +/* end of Fatal Error manager macros */
> +/* Bitfield handler macros */
> + *  This routine sets _output to the bit number of the first bit
> + *  set in _value.  _value is of CPU dependent type Priority_Bit_map_control.
> + *  This type may be either 16 or 32 bits wide although only the 16
> + *  least significant bits will be used.
> + *  There are a number of variables in using a "find first bit" type
> + *  instruction.
> + *    (1) What happens when run on a value of zero?
> + *    (2) Bits may be numbered from MSB to LSB or vice-versa.
> + *    (3) The numbering may be zero or one based.
> + *    (4) The "find first bit" instruction may search from MSB or LSB.
> + *  RTEMS guarantees that (1) will never happen so it is not a concern.
> + *  (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
> + *  _CPU_Priority_bits_index().  These three form a set of routines
> + *  which must logically operate together.  Bits in the _value are
> + *  set and cleared based on masks built by _CPU_Priority_mask().
> + *  The basic major and minor values calculated by _Priority_Major()
> + *  and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
> + *  to properly range between the values returned by the "find first bit"
> + *  instruction.  This makes it possible for _Priority_Get_highest() to
> + *  calculate the major and directly index into the minor table.
> + *  This mapping is necessary to ensure that 0 (a high priority major/minor)
> + *  is the first bit found.
> + *  This entire "find first bit" and mapping process depends heavily
> + *  on the manner in which a priority is broken into a major and minor
> + *  components with the major being the 4 MSB of a priority and minor
> + *  the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
> + *  priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
> + *  to the lowest priority.
> + *  If your CPU does not have a "find first bit" instruction, then
> + *  there are ways to make do without it.  Here are a handful of ways
> + *  to implement this in software:
> + *    - a series of 16 bit test instructions
> + *    - a "binary search using if's"
> + *    - _number = 0
> + *      if _value > 0x00ff
> + *        _value >>=8
> + *        _number = 8;
> + *      if _value > 0x0000f
> + *        _value >=8
> + *        _number += 4
> + *      _number += bit_set_table[ _value ]
> + *    where bit_set_table[ 16 ] has values which indicate the first
> + *      bit set
> +  /* #define CPU_USE_GENERIC_BITFIELD_CODE FALSE */
> +#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> +#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> +#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> +#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> +    (_output) = 0;   /* do something to prevent warnings */ \
> +#endif
> +/* end of Bitfield handler macros */
> + *  This routine builds the mask which corresponds to the bit fields
> + *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
> + *  for that routine.
> +#define _CPU_Priority_Mask( _bit_number ) \
> +    (1 << _bit_number)
> +#endif
> + *  This routine translates the bit numbers returned by
> + *  _CPU_Bitfield_Find_first_bit() into something suitable for use as
> + *  a major or minor component of a priority.  See the discussion
> +#define _CPU_Priority_bits_index( _priority ) \
> +  (_priority)
> +#endif
> +#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
> +#define CPU_TIMESTAMP_USE_INT64 TRUE
> +#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
> +typedef struct {
> +/* There is no CPU specific per-CPU state */
> +} CPU_Per_CPU_control;
> +#endif /* ASM */
> + * Size of a pointer.
> + * This must be an integer literal that can be used by the assembler.  This
> + * value will be used to calculate offsets of structure members.  These
> + * offsets will be used in assembler code.
> +#define CPU_SIZEOF_POINTER 4
> +#define CPU_PER_CPU_CONTROL_SIZE 0
> +#ifndef ASM
> +typedef uint16_t Priority_bit_map_Word;
> +typedef struct {
> +  uint32_t r[64];
> +  uint32_t status;
> +  uint32_t config;
> +  uint32_t iret;
> +} CPU_Exception_frame;
> + * @brief Prints the exception frame via printk().
> + * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> +/* end of Priority handler macros */
> +/* functions */
> + *  _CPU_Initialize
> + *  This routine performs CPU dependent initialization.
> +  void
> + *  _CPU_ISR_install_raw_handler
> + *  This routine installs a "raw" interrupt handler directly into the
> + *  processor's vector table.
> +  uint32_t    vector,
> + *  _CPU_ISR_install_vector
> + *  This routine installs an interrupt vector.
> +  uint32_t    vector,
> + *  _CPU_Install_interrupt_stack
> + *  This routine installs the hardware interrupt stack pointer.
> + *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
> + *         is TRUE.
> +void _CPU_Install_interrupt_stack( void );
> + *  This routine is the CPU dependent IDLE thread body.
> + *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
> + *         is TRUE.
> +void *_CPU_Thread_Idle_body( uintptr_t ignored );
> + *  _CPU_Context_switch
> + *  This routine switches from the run context to the heir context.
> + *  Please see the comments in the .c file for a description of how
> + *  this function works. There are several things to be aware of.
> +void _CPU_Context_switch(
> +  Context_Control  *run,
> +  Context_Control  *heir
> + *  _CPU_Context_restore
> + *  This routine is generally used only to restart self in an
> + *  efficient manner.  It may simply be a label in _CPU_Context_switch.
> + *  NOTE: May be unnecessary to reload some registers.
> +void _CPU_Context_restore(
> +  Context_Control *new_context
> + *  _CPU_Context_save_fp
> + *  This routine saves the floating point context passed to it.
> +void _CPU_Context_save_fp(
> +  void **fp_context_ptr
> + *  _CPU_Context_restore_fp
> + *  This routine restores the floating point context passed to it.
> +void _CPU_Context_restore_fp(
> +/*  The following routine swaps the endian format of an unsigned int.
> + *  It must be static because it is referenced indirectly.
> + *  This version will work on any processor, but if there is a better
> + *  way for your CPU PLEASE use it.  The most common way to do this is to:
> + *     swap least significant two bytes with 16-bit rotate
> + *     swap upper and lower 16-bits
> + *     swap most significant two bytes with 16-bit rotate
> + *  Some CPUs have special instructions which swap a 32-bit quantity in
> + *  a single instruction (e.g. i486).  It is probably best to avoid
> + *  an "endian swapping control bit" in the CPU.  One good reason is
> + *  that interrupts would probably have to be disabled to insure that
> + *  an interrupt does not try to access the same "chunk" with the wrong
> + *  endian.  Another good reason is that on some CPUs, the endian bit
> + *  endianness for ALL fetches -- both code and data -- so the code
> + *  will be fetched incorrectly.
> +static inline unsigned int CPU_swap_u32(
> +  unsigned int value
> +  uint32_t   byte1, byte2, byte3, byte4, swapped;
> +  byte4 = (value >> 24) & 0xff;
> +  byte3 = (value >> 16) & 0xff;
> +  byte2 = (value >> 8)  & 0xff;
> +  byte1 =  value        & 0xff;
> +  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> +  return( swapped );
> +#define CPU_swap_u16( value ) \
> +  (((value&0xff) << 8) | ((value >> 8)&0xff))
> +static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
> +  /* TODO */
> +static inline void _CPU_Context_validate( uintptr_t pattern )
> +  while (1) {
> +    /* TODO */
> +typedef uint32_t CPU_Counter_ticks;
> +CPU_Counter_ticks _CPU_Counter_read( void );
> +static inline CPU_Counter_ticks _CPU_Counter_difference(
> +  CPU_Counter_ticks second,
> +  CPU_Counter_ticks first
> +  return second - first;
> +#ifdef RTEMS_SMP
> +   * @brief Performs CPU specific SMP initialization in the context of the boot
> +   * processor.
> +   * This function is invoked on the boot processor during system
> +   * initialization.  All interrupt stacks are allocated at this point in case
> +   * the CPU port allocates the interrupt stacks.  This function is called
> +   * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
> +   * used.
> +   * @return The count of physically or virtually available processors.
> +   * Depending on the configuration the application may use not all processors.
> +  uint32_t _CPU_SMP_Initialize( void );
> +   * @brief Starts a processor specified by its index.
> +   * initialization.
> +   * This function will be called after _CPU_SMP_Initialize().
> +   * @param[in] cpu_index The processor index.
> +   * @retval true Successful operation.
> +   * @retval false Unable to start this processor.
> +  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
> +   * @brief Performs final steps of CPU specific SMP initialization in the
> +   * context of the boot processor.
> +   * initialization.
> +   * This function will be called after all processors requested by the
> +   * application have been started.
> +   * @param[in] cpu_count The minimum value of the count of processors
> +   * requested by the application configuration and the count of physically or
> +   * virtually available processors.
> +  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
> +   * @brief Returns the index of the current processor.
> +   * An architecture specific method must be used to obtain the index of the
> +   * current processor in the system.  The set of processor indices is the
> +   * range of integers starting with zero up to the processor count minus one.
> +   uint32_t _CPU_SMP_Get_current_processor( void );
> +   * @brief Sends an inter-processor interrupt to the specified target
> +   * processor.
> +   * This operation is undefined for target processor indices out of range.
> +   * @param[in] target_processor_index The target processor index.
> +  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
> +   * @brief Broadcasts a processor event.
> +   * Some architectures provide a low-level synchronization primitive for
> +   * processors in a multi-processor environment.  Processors waiting for this
> +   * event may go into a low-power state and stop generating system bus
> +   * transactions.  This function must ensure that preceding store operations
> +   * can be observed by other processors.
> +   * @see _CPU_SMP_Processor_event_receive().
> +  void _CPU_SMP_Processor_event_broadcast( void );
> +   * @brief Receives a processor event.
> +   * This function will wait for the processor event and may wait forever if no
> +   * such event arrives.
> +   * @see _CPU_SMP_Processor_event_broadcast().
> +  static inline void _CPU_SMP_Processor_event_receive( void )
> +    __asm__ volatile ( "" : : : "memory" );
> +   * @brief Gets the is executing indicator of the thread context.
> +   * @param[in] context The context.
> +  static inline bool _CPU_Context_Get_is_executing(
> +    const Context_Control *context
> +    return context->is_executing;
> +   * @brief Sets the is executing indicator of the thread context.
> +   * @param[in] is_executing The new value for the is executing indicator.
> +  static inline void _CPU_Context_Set_is_executing(
> +    bool is_executing
> +    context->is_executing = is_executing;
> +#endif /* RTEMS_SMP */
> +#endif /* ASM */
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h b/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
> index 0000000..cc091fa
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h
> @@ -0,0 +1,74 @@
> + * @file
> + * @brief Epiphany Assembly File
> + * Very loose template for an include file for the cpu_asm.? file
> + * if it is implemented as a ".S" file (preprocessed by cpp) instead
> + * of a ".s" file (preprocessed by gm4 or gasp).
> +#ifndef _RTEMS_SCORE_CPU_ASM_H
> +#define _RTEMS_SCORE_CPU_ASM_H
> +/* pull in the generated offsets */
> +#include <rtems/score/offsets.h>
> + * Hardware General Registers
> +/* put something here */
> + * Hardware Floating Point Registers
> + * Hardware Control Registers
> + * Calling Convention
> + * Temporary registers
> + * Floating Point Registers - SW Conventions
> + * Temporary floating point registers
> +#endif
> +/* end of file */
What's the point of this file?
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h b/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
> index 0000000..598ee76
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h
> @@ -0,0 +1,14 @@
> + * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> +#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
> +#define _RTEMS_SCORE_ATOMIC_CPU_H
> +#include <rtems/score/cpustdatomic.h>
> +#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h b/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
> index 0000000..53ebe87
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h
> @@ -0,0 +1,180 @@
> +#ifndef _EPIPHANY_UTILITY_H
> +#define _EPIPHANY_UTILITY_H
> +/* eCore IRQs */
> +typedef enum
> +  START,
> +  SW_EXCEPTION,
> +  MEM_FAULT,
> +  TIMER0,
> +  TIMER1,
> +  SMP_MESSAGE,
> +  DMA0,
> +  DMA1,
> +  SER,
> +} IRQ_PER_CORE_T;
This should be prefixed for EPIPHANY or Epiphany.
> +/*  Per-core IO mapped register addresses
> + *  @see Epiphany architecture reference.
It might be nicer to define the base address (0xF0000) and then add to
it each offset.
> +#define EPIPHANY_PER_CORE_REG_CONFIG      0xF0400
> +#define EPIPHANY_PER_CORE_REG_STATUS      0xF0404
> +#define EPIPHANY_PER_CORE_REG_PC          0xF0408
> +#define EPIPHANY_PER_CORE_REG_DEBUGSTATUS 0xF040C
> +#define EPIPHANY_PER_CORE_REG_LC          0xF0414
> +#define EPIPHANY_PER_CORE_REG_LS          0xF0418
> +#define EPIPHANY_PER_CORE_REG_LE          0xF041C
> +#define EPIPHANY_PER_CORE_REG_IRET        0xF0420
> +#define EPIPHANY_PER_CORE_REG_IMASK       0xF0424
> +#define EPIPHANY_PER_CORE_REG_ILAT        0xF0428
> +#define EPIPHANY_PER_CORE_REG_ILATST      0xF042C
> +#define EPIPHANY_PER_CORE_REG_ILATCL      0xF0430
> +#define EPIPHANY_PER_CORE_REG_IPEND       0xF0434
> +#define EPIPHANY_PER_CORE_REG_FSTATUS     0xF0440
> +#define EPIPHANY_PER_CORE_REG_DEBUGCMD    0xF0448
> +#define EPIPHANY_PER_CORE_REG_RESETCORE   0xF070C
> +/* Event timer registers */
> +#define EPIPHANY_PER_CORE_REG_CTIMER0     0xF0438
> +#define EPIPHANY_PER_CORE_REG_CTIMER1     0xF043C
> +/* Processor control registers */
> +#define EPIPHANY_PER_CORE_REG_MEMSTATUS   0xF0604
> +#define EPIPHANY_PER_CORE_REG_MEMPROTECT  0xF0608
> +/* DMA Registers */
> +#define EPIPHANY_PER_CORE_REG_DMA0CONFIG  0xF0500
> +#define EPIPHANY_PER_CORE_REG_DMA0STRIDE  0xF0504
> +#define EPIPHANY_PER_CORE_REG_DMA0COUNT   0xF0508
> +#define EPIPHANY_PER_CORE_REG_DMA0SRCADDR 0xF050C
> +#define EPIPHANY_PER_CORE_REG_DMA0DSTADDR 0xF0510
> +#define EPIPHANY_PER_CORE_REG_DMA0AUTO0   0xF0514
> +#define EPIPHANY_PER_CORE_REG_DMA0AUTO1   0xF0518
> +#define EPIPHANY_PER_CORE_REG_DMA0STATUS  0xF051C
> +#define EPIPHANY_PER_CORE_REG_DMA1CONFIG  0xF0520
> +#define EPIPHANY_PER_CORE_REG_DMA1STRIDE  0xF0524
> +#define EPIPHANY_PER_CORE_REG_DMA1COUNT   0xF0528
> +#define EPIPHANY_PER_CORE_REG_DMA1SRCADDR 0xF052C
> +#define EPIPHANY_PER_CORE_REG_DMA1DSTADDR 0xF0530
> +#define EPIPHANY_PER_CORE_REG_DMA1AUTO0   0xF0534
> +#define EPIPHANY_PER_CORE_REG_DMA1AUTO1   0xF0538
> +#define EPIPHANY_PER_CORE_REG_DMA1STATUS  0xF053C
> +/* Mesh Node Control Registers */
> +#define EPIPHANY_PER_CORE_REG_MESHCONFIG  0xF0700
> +#define EPIPHANY_PER_CORE_REG_COREID      0xF0704
> +#define EPIPHANY_PER_CORE_REG_MULTICAST   0xF0708
> +#define EPIPHANY_PER_CORE_REG_CMESHROUTE  0xF0710
> +#define EPIPHANY_PER_CORE_REG_XMESHROUTE  0xF0714
> +#define EPIPHANY_PER_CORE_REG_RMESHROUTE  0xF0718
> +/*  This macros constructs an address space of epiphany cores
> + *  from their IDs.
> +#define EPIPHANY_COREID_TO_MSB_ADDR(id) (id) << 20
So each core gets a 1MB address space? Is this part of the architecture's TRM?
> +/*  Construct a complete/absolute IO mapped address register from
> + *  core ID and register name
> +#define EPIPHANY_GET_REG_ABSOLUTE_ADDR(coreid, reg) \
> +        (EPIPHANY_COREID_TO_MSB_ADDR(coreid) | (reg))
> +#define EPIPHANY_REG(reg) (uint32_t *) (reg)
> +static inline uint32_t epiphany_coreid_to_rtems_map(uint32_t coreid);
No need to forward declare this.
> +/* Read register with its absolute address */
> +static inline uint32_t read_epiphany_reg(volatile uint32_t reg_addr)
> +  return *(EPIPHANY_REG(reg_addr));
> +/* Write register with its abolute address */
> +static inline void write_epiphany_reg(volatile uint32_t reg_addr, uint32_t val)
> +  *(EPIPHANY_REG(reg_addr)) = val;
> +/*  Epiphany uses 12 bits for defining core IDs, while RTEMS uses
> + *  linear IDs. The following function converts RTEMS linear IDs to
> + *  Epiphany correspodning ones
typo: corresponding
> +static inline uint32_t rtems_coreid_to_epiphany_map(uint32_t rtems_id)
> +  switch(rtems_id)
> +    case (0) : return 0x808;  /* (32, 8) */
> +    case (1) : return 0x809;  /* (32, 9) */
> +    case (2) : return 0x80A;  /* (32,10) */
> +    case (3) : return 0x80B;  /* (32,11) */
> +    case (4) : return 0x848;  /* (33, 8) */
> +    case (5) : return 0x849;  /* (33, 9) */
> +    case (6) : return 0x84A;  /* (33,10) */
> +    case (7) : return 0x84B;  /* (33,11) */
> +    case (8) : return 0x888;  /* (34, 8) */
> +    case (9) : return 0x889;  /* (34, 9) */
> +    case (10): return 0x88A;  /* (34,10) */
> +    case (11): return 0x88B;  /* (34,11) */
> +    case (12): return 0x8C8;  /* (35, 8) */
> +    case (13): return 0x8C9;  /* (35, 9) */
> +    case (14): return 0x8CA;  /* (35,10) */
> +    case (15): return 0x8CB;  /* (35,11) */
> +    default: return 0x1000;   /* Error */
> +  return 0x1000; /* Error */
This is dead code. I'd remove the return from default and let it
fall-through to here.
Also, the translation here is trivial to implement as a lookup in an array:
uint32_t map[16] = {0x808, 0x809, 0x80A, 0x80B, 0x848 ...};
return map[rtems_id];
> + * linear IDs. The following function is used to map Epiphany IDs to
> + * RTEMS linear IDs.
> +inline uint32_t epiphany_coreid_to_rtems_map(uint32_t epiphany_id)
static?
> +  switch(epiphany_id)
> +    case (0x808): return 0;  /* (32, 8) */
> +    case (0x809): return 1;  /* (32, 9) */
> +    case (0x80A): return 2;  /* (32,10) */
> +    case (0x80B): return 3;  /* (32,11) */
> +    case (0x848): return 4;  /* (33, 8) */
> +    case (0x849): return 5;  /* (33, 9) */
> +    case (0x84A): return 6;  /* (33,10) */
> +    case (0x84B): return 7;  /* (33,11) */
> +    case (0x888): return 8;  /* (34, 8) */
> +    case (0x889): return 9;  /* (34, 9) */
> +    case (0x88A): return 10; /* (34,10) */
> +    case (0x88B): return 11; /* (34,11) */
> +    case (0x8C8): return 12; /* (35, 8) */
> +    case (0x8C9): return 13; /* (35, 9) */
> +    case (0x8CA): return 14; /* (35,10) */
> +    case (0x8CB): return 15; /* (35,11) */
Ditto on the dead code.
Since there are holes in the translation here, an array won't work
nicely, but it might be more efficient to use arithmetic to calculate
this translation, e.g.
((epiphany_id & 0xf0) >> 4) + ((epiphany_id & 0xf) - 8)
This especially may produce smaller code, and probably makes a
difference if # of cores increases. (assuming the math is right).
> +static inline uint32_t _Epiphany_Get_Current_coreid()
Should this be Epiphany_Get_current_processor()? Anyway, shouldn't
have Current capitalized here.
> +  uint32_t coreid;
> +  asm volatile ("movfs %0, coreid" : "=r" (coreid): );
> +  return epiphany_coreid_to_rtems_map(coreid);
> +#endif  /* _EPIPHANY_UTILITY_H */
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/epiphany.h b/cpukit/score/cpu/epiphany/rtems/score/epiphany.h
> new file mode 100644
> index 0000000..3aeb6d9
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/epiphany.h
> @@ -0,0 +1,50 @@
> + * @file rtems/score/epiphany.h
> + *  This file contains information pertaining to the Epiphany processor.
> + *  Based on code with the following copyright...
> + *  COPYRIGHT (c) 1989-1999, 2010.
> +#ifndef _RTEMS_SCORE_EPIPHANY_H
> +#define _RTEMS_SCORE_EPIPHANY_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + *  This file contains the information required to build
> + *  RTEMS for a particular member of the Epiphany family.
> + *  It does this by setting variables to indicate which
> + *  implementation dependent features are present in a particular
> + *  member of the family.
> + *  This is a good place to list all the known CPU models
> + *  that this port supports and which RTEMS CPU model they correspond
> + *  to.
> + *  Define the name of the CPU family and specific model.
> +#define CPU_NAME "EPIPHANY"
> +#define CPU_MODEL_NAME "EPIPHANY"
> +#ifdef __cplusplus
> +#endif
> +#endif /* _RTEMS_SCORE_EPIPHANY_H */
> diff --git a/cpukit/score/cpu/epiphany/rtems/score/types.h b/cpukit/score/cpu/epiphany/rtems/score/types.h
> index 0000000..21c82a0
> --- /dev/null
> +++ b/cpukit/score/cpu/epiphany/rtems/score/types.h
> @@ -0,0 +1,55 @@
> + * @file
> + * @brief Epiphany Architecture Types API
> + *  This include file contains type definitions pertaining to the
> + *  COPYRIGHT (c) 2015 University of York.
> + *  Hesham ALMatary <hmka501 at york.ac.uk>
> + #ifndef _RTEMS_SCORE_TYPES_H
> +#define _RTEMS_SCORE_TYPES_H
> +#include <rtems/score/basedefs.h>
> +#ifndef ASM
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup ScoreCPU
> + *  This section defines the basic types for this processor.
> +/** Type that can store a 32-bit integer or a pointer. */
> +typedef uintptr_t CPU_Uint32ptr;
> +typedef void epiphany_isr;
> +typedef void ( *epiphany_isr_entry )( void );
> +#ifdef __cplusplus
> +#endif
> +#endif  /* !ASM */
> +#endif
> 2.1.0
> devel mailing list
> devel at rtems.org
