[PATCH 1/2] cpukit: Add Epiphany architecture port v2
Hesham ALMatary heshamelmatary at gmail.com
Wed May 13 10:25:39 UTC 2015
On Wed, May 13, 2015 at 8:40 AM, Sebastian Huber
> On 09/05/15 16:45, Hesham ALMatary wrote:
>> diff --git a/cpukit/score/cpu/epiphany/cpu.c
>> b/cpukit/score/cpu/epiphany/cpu.c
>> new file mode 100644
>> index 0000000..9ec8f94
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/cpu.c
>> @@ -0,0 +1,114 @@
>> + * Epiphany CPU Dependent Source
>> + * Copyright (c) 2015 University of York.
>> + * Hesham ALMatary <hmka501 at york.ac.uk>
>> + * COPYRIGHT (c) 1989-1999.
>> + * On-Line Applications Research Corporation (OAR).
> I doubt that OAR has a copyright for contents of this new file, but if they
> have one, then the license change from the standard RTEMS license to BSD is
> a problem.
I left the OAR copyrights because the file is copied from other ports
which OAR has copyrights on. The change of the licence from for OAR
files licensed with RTEMS to BSD needs permission. I believe Joel is
OK with that and gave me the permission.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
>> LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>> GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
>> STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
>> WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#include <rtems/system.h>
>> +#include <rtems/score/isr.h>
>> +#include <rtems/score/wkspace.h>
>> +#include <bsp/linker-symbols.h>
>> +#include <rtems/score/cpu.h>
>> +void _init(void);
>> +void _fini(void);
>> +void _init(void)
>> +  /* Do nothing */
>> +void _fini(void)
>> +  /* Do nothing */
> If you need to define _init() and _fini() here, then something is wrong with
> the GCC configuration for this target.  For example:
> nm /opt/rtems-4.11/lib/gcc/sparc-rtems4.11/4.9.2/crti.o
> 00000000 T _fini
> 00000000 T _init
>> diff --git a/cpukit/score/cpu/epiphany/rtems/score/cpu.h
>> b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
>> index 0000000..9958599
>> --- /dev/null
>> +++ b/cpukit/score/cpu/epiphany/rtems/score/cpu.h
>> @@ -0,0 +1,1185 @@
>> +static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
>> +  /* TODO */
>> +static inline void _CPU_Context_validate( uintptr_t pattern )
>> +  while (1) {
>> +    /* TODO */
> It would be nice to have implementations of the above two functions at least
> for all new ports.  See test sptests/spcontext01.  It ensures that the
> context switch and interrupt code works now and later if some makes a
> modification.
OK, I will implement them for the next version of the patches.
> The Doxygen comment copy and paste in the cpu.h files is a real mess in
> general. It would be better to mention only the architectures specifics in
> this file, e.g. references to the ABI documents.
Should I delete all the copied comments and just add architecture
specific comments? Other ports just copied this file from no_cpu.h as
is and add minor changes like what I did.
Thanks for your feedback, next set of patches will account for your comments.
Hesham
