[rtems commit] Remove obsolete rtems_clock_major/minor
Thu May 14 12:39:55 UTC 2015
Is this all of them again?
I have made this sweep at least twice in the code but clearly missed the docs.
On May 14, 2015 4:18:24 AM CDT, Sebastian Huber <sebh at rtems.org> wrote:
>Module:    rtems
>Branch:    master
>Commit:    a0001d64fea2619a76fd117967756089e5305f09
>Changeset:
>http://git.rtems.org/rtems/commit/?id=a0001d64fea2619a76fd117967756089e5305f09
>Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>Date:      Thu May 14 11:17:00 2015 +0200
>These global variables are obsolete since
>65f71f8472fa904ca48b816301ed0810def47001.
> c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c | 14 --------------
>doc/bsp_howto/clock.t                             | 17
> 2 files changed, 31 deletions(-)
>diff --git a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
>b/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
>index 9b6c2d1..50b858f 100644
>--- a/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
>+++ b/c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c
>@@ -53,13 +53,6 @@ void Clock_exit(void);
> void Clock_isr(void *arg_unused);
>- *  Major and minor number.
>-rtems_device_major_number rtems_clock_major = UINT32_MAX;
>-rtems_device_minor_number rtems_clock_minor;
>  *  Clock_isr
>  *  This is the clock tick interrupt handler.
>@@ -259,13 +252,6 @@ rtems_device_driver Clock_initialize(
>   atexit( Clock_exit );
>-   * make major/minor avail to others such as shared memory driver
>-  rtems_clock_major = major;
>-  rtems_clock_minor = minor;
>    *  If we are counting ISRs per tick, then initialize the counter.
>diff --git a/doc/bsp_howto/clock.t b/doc/bsp_howto/clock.t
>index 6c00c5d..396634b 100644
>--- a/doc/bsp_howto/clock.t
>+++ b/doc/bsp_howto/clock.t
>@@ -19,23 +19,6 @@ The clock driver is located in the @code{clock}
>directory of the BSP.
> This section describes the global variables expected to be provided by
> this driver.
>- at subsection Major and Minor Number
>-The major and minor numbers of the clock driver are made available via
>-the following variables.
>- at itemize @bullet
>- at item rtems_device_major_number rtems_clock_major;
>- at item rtems_device_minor_number rtems_clock_minor;
>- at end itemize
>-The clock device driver is responsible for declaring and
>-initializing these variables.  These variables are used
>-by other RTEMS components -- notably the Shared Memory Driver.
>- at b{NOTE:} In a future RTEMS version, these variables may be replaced
>-with the clock device driver registering @b{/dev/clock}.
> @subsection Ticks Counter
> Most of the clock device drivers provide a global variable
>_______________________________________________
>vc mailing list
>vc at rtems.org
>http://lists.rtems.org/mailman/listinfo/vc
--joel
