[PATCH 02/45] score: _Thread_queue_Extract()
Fri May 15 11:41:02 UTC 2015
Remove thread queue parameter from _Thread_queue_Extract() since the
current thread queue is stored in the thread control block.
 cpukit/rtems/src/msgmp.c                       |  2 +-
 cpukit/rtems/src/partmp.c                      |  2 +-
 cpukit/rtems/src/regionmp.c                    |  2 +-
 cpukit/rtems/src/regionprocessqueue.c          |  2 +-
 cpukit/rtems/src/semmp.c                       |  2 +-
 cpukit/score/include/rtems/score/threadqimpl.h | 16 +++++---------
 cpukit/score/src/corerwlockrelease.c           |  2 +-
 cpukit/score/src/mpci.c                        |  2 +-
 cpukit/score/src/threadqenqueue.c              | 14 ++++++-------
 cpukit/score/src/threadqextractwithproxy.c     |  7 +------
 cpukit/score/src/threadqprocesstimeout.c       |  1 -
 testsuites/sptests/spthreadq01/init.c          | 29 ++++----------------------
 12 files changed, 23 insertions(+), 58 deletions(-)
diff --git a/cpukit/rtems/src/msgmp.c b/cpukit/rtems/src/msgmp.c
index 7043138..ddad64a 100644
--- a/cpukit/rtems/src/msgmp.c
+++ b/cpukit/rtems/src/msgmp.c
@@ -291,7 +291,7 @@ void _Message_queue_MP_Process_packet (
       the_thread = _Thread_MP_Find_proxy( the_packet->proxy_id );
       if (! _Thread_Is_null( the_thread ) )
-         _Thread_queue_Extract( the_thread->Wait.queue, the_thread );
+         _Thread_queue_Extract( the_thread );
       _MPCI_Return_packet( the_packet_prefix );
       break;
diff --git a/cpukit/rtems/src/partmp.c b/cpukit/rtems/src/partmp.c
index 943c24a..f41fd22 100644
--- a/cpukit/rtems/src/partmp.c
+++ b/cpukit/rtems/src/partmp.c
@@ -209,7 +209,7 @@ void _Partition_MP_Process_packet (
       if ( ! _Thread_Is_null( the_thread ) )
       break;
diff --git a/cpukit/rtems/src/regionmp.c b/cpukit/rtems/src/regionmp.c
index 58dfa99..8bce822 100644
--- a/cpukit/rtems/src/regionmp.c
+++ b/cpukit/rtems/src/regionmp.c
@@ -195,7 +195,7 @@ void _Region_MP_Process_packet (
       break;
diff --git a/cpukit/rtems/src/regionprocessqueue.c b/cpukit/rtems/src/regionprocessqueue.c
index 54081af..a06a077 100644
--- a/cpukit/rtems/src/regionprocessqueue.c
+++ b/cpukit/rtems/src/regionprocessqueue.c
@@ -61,7 +61,7 @@ void _Region_Process_queue(
     *(void **)the_thread->Wait.return_argument = the_segment;
     the_region->number_of_used_blocks += 1;
-    _Thread_queue_Extract( &the_region->Wait_queue, the_thread );
     the_thread->Wait.return_code = RTEMS_SUCCESSFUL;
   _Thread_Enable_dispatch();
diff --git a/cpukit/rtems/src/semmp.c b/cpukit/rtems/src/semmp.c
index eabd1b7..d94d908 100644
--- a/cpukit/rtems/src/semmp.c
+++ b/cpukit/rtems/src/semmp.c
@@ -188,7 +188,7 @@ void _Semaphore_MP_Process_packet (
       break;
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 6eac364..6fc38cf 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -78,25 +78,20 @@ void _Thread_queue_Enqueue(
  *  @brief Extracts thread from thread queue.
- *  This routine removes @a the_thread from @a the_thread_queue
+ *  This routine removes @a the_thread its thread queue
  *  and cancels any timeouts associated with this blocking.
- *  @param[in] the_thread_queue is the pointer to the ThreadQ header
  *  @param[in] the_thread is the pointer to a thread control block that
  *      is to be removed
-void _Thread_queue_Extract(
-  Thread_queue_Control *the_thread_queue,
-  Thread_Control       *the_thread
+void _Thread_queue_Extract( Thread_Control *the_thread );
  *  @brief Extracts thread from thread queue (w/return code).
  *      is to be removed
  *  @param[in] return_code specifies the status to be returned.
@@ -105,9 +100,8 @@ void _Thread_queue_Extract(
  *    + single case
 void _Thread_queue_Extract_with_return_code(
-  Thread_Control       *the_thread,
-  uint32_t              return_code
+  Thread_Control *the_thread,
+  uint32_t        return_code
diff --git a/cpukit/score/src/corerwlockrelease.c b/cpukit/score/src/corerwlockrelease.c
index efaf67d..bd39213 100644
--- a/cpukit/score/src/corerwlockrelease.c
+++ b/cpukit/score/src/corerwlockrelease.c
@@ -87,7 +87,7 @@ CORE_RWLock_Status _CORE_RWLock_Release(
            next->Wait.option == CORE_RWLOCK_THREAD_WAITING_FOR_WRITE )
         return CORE_RWLOCK_SUCCESSFUL;
       the_rwlock->number_of_readers += 1;
-      _Thread_queue_Extract( &the_rwlock->Wait_queue, next );
+      _Thread_queue_Extract( next );
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index 9b623b2..424bcb4 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -262,7 +262,7 @@ Thread_Control *_MPCI_Process_response (
       the_thread = NULL;          /* IMPOSSIBLE */
       break;
     case OBJECTS_LOCAL:
-      _Thread_queue_Extract( &_MPCI_Remote_blocked_threads, the_thread );
       the_thread->Wait.return_code = the_packet->return_code;
       _Objects_Put_without_thread_dispatch( &the_thread->Object );
     break;
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 5c23756..0e16f59 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -185,11 +185,11 @@ void _Thread_queue_Enqueue(
+  Thread_queue_Control *the_thread_queue;
   ISR_lock_Context lock_context;
   _Thread_queue_Acquire( &lock_context );
@@ -199,6 +199,8 @@ void _Thread_queue_Extract_with_return_code(
     return;
+  the_thread_queue = the_thread->Wait.queue;
   if ( the_thread_queue->discipline == THREAD_QUEUE_DISCIPLINE_FIFO ) {
     _Chain_Extract_unprotected( &the_thread->Object.Node );
   } else { /* must be THREAD_QUEUE_DISCIPLINE_PRIORITY */
@@ -220,13 +222,9 @@ void _Thread_queue_Extract_with_return_code(
   _Thread_blocking_operation_Finalize( the_thread, &lock_context );
-    the_thread_queue,
     the_thread,
diff --git a/cpukit/score/src/threadqextractwithproxy.c b/cpukit/score/src/threadqextractwithproxy.c
index fb06526..72043a0 100644
--- a/cpukit/score/src/threadqextractwithproxy.c
+++ b/cpukit/score/src/threadqextractwithproxy.c
@@ -31,8 +31,6 @@ void _Thread_queue_Extract_with_proxy(
-  Thread_queue_Control *the_thread_queue;
   #if defined(RTEMS_MULTIPROCESSING)
     States_Control state;
@@ -50,8 +48,5 @@ void _Thread_queue_Extract_with_proxy(
   #endif
-  the_thread_queue = the_thread->Wait.queue;
-  if ( the_thread_queue != NULL ) {
-    _Thread_queue_Extract( the_thread_queue, the_thread );
diff --git a/cpukit/score/src/threadqprocesstimeout.c b/cpukit/score/src/threadqprocesstimeout.c
index 6169019..dbb8f5c 100644
--- a/cpukit/score/src/threadqprocesstimeout.c
+++ b/cpukit/score/src/threadqprocesstimeout.c
@@ -69,7 +69,6 @@ void _Thread_queue_Process_timeout(
        * queue initialization.
-        the_thread_queue,
         the_thread,
         the_thread_queue->timeout_status
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 240cd1a..5add92b 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -18,38 +18,17 @@
 const char rtems_test_name[] = "SPTHREADQ 1";
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-void threadq_first_empty(
-  const char               *discipline_string,
-  Thread_queue_Disciplines  discipline
+static rtems_task Init(
+  rtems_task_argument ignored
-  Thread_queue_Control tq;
-  printf( "Init - initialize thread queue for %s\n", discipline_string );
-  _Thread_queue_Initialize( &tq, discipline, 3 );
+  TEST_BEGIN();
   puts( "Init - _Thread_queue_Extract - thread not blocked on a thread queue" );
   _Thread_Disable_dispatch();
-  _Thread_queue_Extract( &tq, _Thread_Executing );
+  _Thread_queue_Extract( _Thread_Executing );
   /* is there more to check? */
-rtems_task Init(
-  rtems_task_argument ignored
-  TEST_BEGIN();
-  threadq_first_empty( "FIFO", THREAD_QUEUE_DISCIPLINE_FIFO );
-  threadq_first_empty( "Priority", THREAD_QUEUE_DISCIPLINE_PRIORITY );
   TEST_END();
   rtems_test_exit(0);
1.8.4.5
