[PATCH 35/45] score: Add static initializers for thread queues
Fri May 15 11:41:35 UTC 2015
 cpukit/score/include/rtems/score/threadqimpl.h | 34 ++++++++++++++++++++++++++
 testsuites/sptests/spthreadq01/init.c          | 14 +++++++++++
 2 files changed, 48 insertions(+)
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 7979986..2f5293b 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -20,6 +20,8 @@
 #define _RTEMS_SCORE_THREADQIMPL_H
 #include <rtems/score/threadq.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/rbtreeimpl.h>
 #ifdef __cplusplus
@@ -341,6 +343,38 @@ void _Thread_queue_Initialize(
   Thread_queue_Disciplines  the_discipline
+#if defined(RTEMS_SMP)
+  #define THREAD_QUEUE_FIFO_INITIALIZER( designator, name ) { \
+      .Queues = { \
+        .Fifo = CHAIN_INITIALIZER_EMPTY( designator.Queues.Fifo ) \
+      .operations = &_Thread_queue_Operations_FIFO, \
+      .Lock = ISR_LOCK_INITIALIZER( name ) \
+  #define THREAD_QUEUE_PRIORIY_INITIALIZER( designator, name ) { \
+      .Queues = { \
+        .Priority = RBTREE_INITIALIZER_EMPTY( designator.Queues.Priority ) \
+      .operations = &_Thread_queue_Operations_priority, \
+#else
+      .Queues = { \
+      .operations = &_Thread_queue_Operations_FIFO \
+      .Queues = { \
+      .operations = &_Thread_queue_Operations_priority \
+#endif
 RTEMS_INLINE_ROUTINE void _Thread_queue_Destory(
   Thread_queue_Control *the_thread_queue
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 5add92b..ce47760 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -18,6 +18,12 @@
 const char rtems_test_name[] = "SPTHREADQ 1";
+static Thread_queue_Control fifo_queue =
+  THREAD_QUEUE_FIFO_INITIALIZER( fifo_queue, "FIFO" );
+static Thread_queue_Control prio_queue =
+  THREAD_QUEUE_PRIORIY_INITIALIZER( prio_queue, "Prio" );
 static rtems_task Init(
   rtems_task_argument ignored
@@ -30,6 +36,14 @@ static rtems_task Init(
   _Thread_Enable_dispatch();
   /* is there more to check? */
+  rtems_test_assert( _Chain_Is_empty( &fifo_queue.Queues.Fifo ) );
+  rtems_test_assert( fifo_queue.operations == &_Thread_queue_Operations_FIFO );
+  rtems_test_assert( _RBTree_Is_empty( &fifo_queue.Queues.Priority ) );
+    prio_queue.operations == &_Thread_queue_Operations_priority
   TEST_END();
   rtems_test_exit(0);
1.8.4.5
