[PATCH 41/45] timecounter: Use uint32_t instead of u_int
Fri May 15 11:47:50 UTC 2015
From: Alexander Krutwig <alexander.krutwig at embedded-brains.de>
FreeBSD assumes that u_int is a 32-bit integer type.  This is wrong for
some 16-bit targets supported by RTEMS.
Update #2271.
 cpukit/score/include/sys/timetc.h |  4 ++--
 cpukit/score/src/kern_tc.c        | 34 +++++++++++++++++-----------------
 2 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/cpukit/score/include/sys/timetc.h b/cpukit/score/include/sys/timetc.h
index e68e327..1c2a175 100644
--- a/cpukit/score/include/sys/timetc.h
+++ b/cpukit/score/include/sys/timetc.h
@@ -28,7 +28,7 @@
 struct timecounter;
-typedef u_int timecounter_get_t(struct timecounter *);
+typedef uint32_t timecounter_get_t(struct timecounter *);
 typedef void timecounter_pps_t(struct timecounter *);
 struct timecounter {
@@ -45,7 +45,7 @@ struct timecounter {
 		 * events.  Normal hardware does not need it but timecounters
 		 * which latch PPS in hardware (like sys/pci/xrpu.c) do.
-	u_int 			tc_counter_mask;
+	uint32_t 		tc_counter_mask;
 		/* This mask should mask off any unimplemented bits. */
 	uint64_t		tc_frequency;
 		/* Frequency of the counter in Hz. */
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 1c29041..3e33495 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -50,10 +50,10 @@ __FBSDID("$FreeBSD$");
  * time services.
-static u_int
+static uint32_t
 dummy_get_timecount(struct timecounter *tc)
-	static u_int now;
+	static uint32_t now;
 	return (++now);
@@ -67,12 +67,12 @@ struct timehands {
 	struct timecounter	*th_counter;
 	int64_t			th_adjustment;
 	uint64_t		th_scale;
-	u_int	 		th_offset_count;
+	uint32_t	 	th_offset_count;
 	struct bintime		th_offset;
 	struct timeval		th_microtime;
 	struct timespec		th_nanotime;
 	/* Fields not to be copied in tc_windup start with th_generation. */
-	volatile u_int		th_generation;
+	volatile uint32_t	th_generation;
 	struct timehands	*th_next;
@@ -159,7 +159,7 @@ sysctl_kern_boottime(SYSCTL_HANDLER_ARGS)
 static int
 sysctl_kern_timecounter_get(SYSCTL_HANDLER_ARGS)
-	u_int ncount;
+	uint32_t ncount;
 	struct timecounter *tc = arg1;
 	ncount = tc->tc_get_timecount(tc);
@@ -180,7 +180,7 @@ sysctl_kern_timecounter_freq(SYSCTL_HANDLER_ARGS)
  * Return the difference between the timehands' counter value now and what
  * was when we copied it to the timehands' offset_count.
-static __inline u_int
+static __inline uint32_t
 tc_delta(struct timehands *th)
 	struct timecounter *tc;
@@ -338,7 +338,7 @@ void
 binuptime(struct bintime *bt)
 	struct timehands *th;
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -396,7 +396,7 @@ void
 getbinuptime(struct bintime *bt)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -409,7 +409,7 @@ void
 getnanouptime(struct timespec *tsp)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -422,7 +422,7 @@ void
 getmicrouptime(struct timeval *tvp)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -435,7 +435,7 @@ void
 getbintime(struct bintime *bt)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -449,7 +449,7 @@ void
 getnanotime(struct timespec *tsp)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -462,7 +462,7 @@ void
 getmicrotime(struct timeval *tvp)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -985,7 +985,7 @@ void
 dtrace_getnanotime(struct timespec *tsp)
-	u_int gen;
+	uint32_t gen;
 	do {
 		th = timehands;
@@ -1140,7 +1140,7 @@ sysclock_snap2bintime(struct sysclock_snap *cs, struct bintime *bt,
 void
 tc_init(struct timecounter *tc)
-	u_int u;
+	uint32_t u;
 	struct sysctl_oid *tc_root;
 	u = tc->tc_frequency / tc->tc_counter_mask;
@@ -1249,7 +1249,7 @@ tc_windup(void)
 	struct bintime bt;
 	struct timehands *th, *tho;
 	uint64_t scale;
-	u_int delta, ncount, ogen;
+	uint32_t delta, ncount, ogen;
 	int i;
 	time_t t;
@@ -1633,7 +1633,7 @@ pps_event(struct pps_state *pps, int event)
 	struct bintime bt;
 	struct timespec ts, *tsp, *osp;
-	u_int tcount, *pcount;
+	uint32_t tcount, *pcount;
 	int foff, fhard;
 	pps_seq_t *pseq;
 #ifdef FFCLOCK
1.8.4.5
