[PATCH 29/45] score: Fine grained locking for mutexes
Sebastian Huber
Fri May 15 11:47:49 UTC 2015
Update #2273.
cpukit/libnetworking/rtems/rtems_glue.c | 19 ++----
cpukit/posix/src/mutexlocksupp.c | 7 --
cpukit/posix/src/mutexsetprioceiling.c | 11 ++-
cpukit/posix/src/mutexunlock.c | 11 ++-
cpukit/rtems/src/semobtain.c | 7 --
cpukit/rtems/src/semrelease.c | 6 +-
cpukit/score/include/rtems/score/coremuteximpl.h | 40 ++++++-----
cpukit/score/src/apimutexlock.c | 8 ---
cpukit/score/src/apimutexunlock.c | 17 +++--
cpukit/score/src/coremutex.c | 5 +-
cpukit/score/src/coremutexseize.c | 30 ++++++---
cpukit/score/src/coremutexsurrender.c | 86 +++++++++++++++++-------
cpukit/score/src/debugisownerofallocator.c | 13 +---
13 files changed, 143 insertions(+), 117 deletions(-)
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index 63d4b80..e43dc6e 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -378,9 +378,6 @@ rtems_bsdnet_semaphore_obtain (void)
#ifdef RTEMS_FAST_MUTEX
ISR_lock_Context lock_context;
Thread_Control *executing;
-#ifdef RTEMS_SMP
- _Thread_Disable_dispatch();
-#endif
_ISR_lock_ISR_disable(&lock_context);
if (!the_networkSemaphore)
rtems_panic ("rtems-net: network sema obtain: network not initialised\n");
@@ -393,9 +390,6 @@ rtems_bsdnet_semaphore_obtain (void)
0, /* forever */
&lock_context
-#ifdef RTEMS_SMP
- _Thread_Enable_dispatch();
-#endif
if (executing->Wait.return_code)
rtems_panic ("rtems-net: can't obtain network sema: %d\n",
executing->Wait.return_code);
@@ -416,18 +410,19 @@ void
rtems_bsdnet_semaphore_release (void)
- int i;
+ ISR_lock_Context lock_context;
+ CORE_mutex_Status status;
- i = _CORE_mutex_Surrender (
+ _ISR_lock_ISR_disable(&lock_context);
+ status = _CORE_mutex_Surrender (
&the_networkSemaphore->Core_control.mutex,
networkSemaphore,
- NULL
+ NULL,
+ &lock_context
- if (i)
+ if (status != CORE_MUTEX_STATUS_SUCCESSFUL)
rtems_panic ("rtems-net: can't release network sema: %i\n");
#else
rtems_status_code sc;
diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
index 9b20f58..b63a89a 100644
--- a/cpukit/posix/src/mutexlocksupp.c
+++ b/cpukit/posix/src/mutexlocksupp.c
@@ -54,9 +54,6 @@ int _POSIX_Mutex_Lock_support(
switch ( location ) {
case OBJECTS_LOCAL:
-#if defined(RTEMS_SMP)
-#endif
executing = _Thread_Executing;
_CORE_mutex_Seize(
&the_mutex->Mutex,
@@ -66,10 +63,6 @@ int _POSIX_Mutex_Lock_support(
timeout,
&lock_context
-#endif
- _Objects_Put_for_get_isr_disable( &the_mutex->Object );
return _POSIX_Mutex_Translate_core_mutex_return_code(
(CORE_mutex_Status) executing->Wait.return_code
diff --git a/cpukit/posix/src/mutexsetprioceiling.c b/cpukit/posix/src/mutexsetprioceiling.c
index f0fb8f5..32d9210 100644
--- a/cpukit/posix/src/mutexsetprioceiling.c
+++ b/cpukit/posix/src/mutexsetprioceiling.c
@@ -41,6 +41,7 @@ int pthread_mutex_setprioceiling(
register POSIX_Mutex_Control *the_mutex;
Objects_Locations location;
Priority_Control the_priority;
if ( !old_ceiling )
return EINVAL;
@@ -64,7 +65,11 @@ int pthread_mutex_setprioceiling(
* NOTE: This makes it easier to get 100% binary coverage since the
* bad Id case is handled by the switch.
- the_mutex = _POSIX_Mutex_Get( mutex, &location );
+ the_mutex = _POSIX_Mutex_Get_interrupt_disable(
+ mutex,
+ &location,
+ &lock_context
case OBJECTS_LOCAL:
@@ -78,9 +83,9 @@ int pthread_mutex_setprioceiling(
_CORE_mutex_Surrender(
&the_mutex->Mutex,
the_mutex->Object.id,
- NULL
+ NULL,
+ &lock_context
- _Objects_Put( &the_mutex->Object );
return 0;
diff --git a/cpukit/posix/src/mutexunlock.c b/cpukit/posix/src/mutexunlock.c
index dbb9d1a..c5b2375 100644
--- a/cpukit/posix/src/mutexunlock.c
+++ b/cpukit/posix/src/mutexunlock.c
@@ -41,17 +41,22 @@ int pthread_mutex_unlock(
+ mutex,
+ &location,
+ &lock_context
case OBJECTS_LOCAL:
status = _CORE_mutex_Surrender(
&the_mutex->Mutex,
- NULL
+ NULL,
+ &lock_context
return _POSIX_Mutex_Translate_core_mutex_return_code( status );
#if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
index 46d1b82..1ebc98b 100644
--- a/cpukit/rtems/src/semobtain.c
+++ b/cpukit/rtems/src/semobtain.c
@@ -73,9 +73,6 @@ rtems_status_code rtems_semaphore_obtain(
} else
#endif
if ( !_Attributes_Is_counting_semaphore( attribute_set ) ) {
-#endif
_CORE_mutex_Seize(
&the_semaphore->Core_control.mutex,
executing,
@@ -84,10 +81,6 @@ rtems_status_code rtems_semaphore_obtain(
timeout,
&lock_context
-#endif
- _Objects_Put_for_get_isr_disable( &the_semaphore->Object );
return _Semaphore_Translate_core_mutex_return_code(
executing->Wait.return_code );
diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
index 1f0581e..7e4b98e 100644
--- a/cpukit/rtems/src/semrelease.c
+++ b/cpukit/rtems/src/semrelease.c
@@ -86,14 +86,12 @@ rtems_status_code rtems_semaphore_release(
} else
#endif
- _ISR_lock_ISR_enable( &lock_context );
mutex_status = _CORE_mutex_Surrender(
id,
- MUTEX_MP_SUPPORT
+ MUTEX_MP_SUPPORT,
+ &lock_context
return _Semaphore_Translate_core_mutex_return_code( mutex_status );
} else {
semaphore_status = _CORE_semaphore_Surrender(
diff --git a/cpukit/score/include/rtems/score/coremuteximpl.h b/cpukit/score/include/rtems/score/coremuteximpl.h
index 3c0a6c9..e6e8196 100644
--- a/cpukit/score/include/rtems/score/coremuteximpl.h
+++ b/cpukit/score/include/rtems/score/coremuteximpl.h
@@ -210,17 +210,10 @@ void _CORE_mutex_Seize_interrupt_blocking(
* @retval this method returns true if dispatch is in an unsafe state.
-#ifdef RTEMS_SMP
- #define _CORE_mutex_Check_dispatch_for_seize(_wait) \
- (_Thread_Dispatch_get_disable_level() != 1 \
- && (_wait) \
- && (_System_state_Get() >= SYSTEM_STATE_UP))
-#else
- (!_Thread_Dispatch_is_enabled() \
- && (_wait) \
-#endif
+#define _CORE_mutex_Check_dispatch_for_seize(_wait) \
+ (!_Thread_Dispatch_is_enabled() \
+ && (_wait) \
+ && (_System_state_Get() >= SYSTEM_STATE_UP))
* @brief Attempt to obtain the mutex.
@@ -265,9 +258,10 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
+ _Thread_queue_Acquire_critical( &the_mutex->Wait_queue, lock_context );
if ( _CORE_mutex_Seize_interrupt_trylock( the_mutex, executing, lock_context ) ) {
if ( !wait ) {
- _ISR_lock_ISR_enable( lock_context );
+ _Thread_queue_Release( &the_mutex->Wait_queue, lock_context );
executing->Wait.return_code =
CORE_MUTEX_STATUS_UNSATISFIED_NOWAIT;
} else {
@@ -320,13 +314,15 @@ RTEMS_INLINE_ROUTINE void _CORE_mutex_Seize_body(
* @param[in] id is the id of the RTEMS Object associated with this mutex
* @param[in] api_mutex_mp_support is the routine that will be called when
* unblocking a remote mutex
+ * @param[in] lock_context is the interrupt level
* @retval an indication of whether the routine succeeded or failed
CORE_mutex_Status _CORE_mutex_Surrender(
CORE_mutex_Control *the_mutex,
Objects_Id id,
- CORE_mutex_API_mp_support_callout api_mutex_mp_support
+ CORE_mutex_API_mp_support_callout api_mutex_mp_support,
+ ISR_lock_Context *lock_context
@@ -472,7 +468,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
if ( !_CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
return 0;
} /* else must be CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING
@@ -486,19 +482,21 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
ceiling = the_mutex->Attributes.priority_ceiling;
current = executing->current_priority;
if ( current == ceiling ) {
return 0;
if ( current > ceiling ) {
+ Per_CPU_Control *cpu_self;
+ cpu_self = _Thread_Dispatch_disable_critical();
_Thread_Change_priority(
executing,
ceiling,
false
+ _Thread_Dispatch_enable( cpu_self );
return 0;
/* if ( current < ceiling ) */ {
@@ -506,7 +504,7 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
the_mutex->holder = NULL;
the_mutex->nest_count = 0; /* undo locking above */
executing->resource_count--; /* undo locking above */
return 0;
@@ -522,12 +520,12 @@ RTEMS_INLINE_ROUTINE int _CORE_mutex_Seize_interrupt_trylock_body(
switch ( the_mutex->Attributes.lock_nesting_behavior ) {
case CORE_MUTEX_NESTING_ACQUIRES:
the_mutex->nest_count++;
return 0;
#if defined(RTEMS_POSIX_API)
case CORE_MUTEX_NESTING_IS_ERROR:
executing->Wait.return_code = CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
return 0;
#endif
case CORE_MUTEX_NESTING_BLOCKS:
diff --git a/cpukit/score/src/apimutexlock.c b/cpukit/score/src/apimutexlock.c
index 45ad0ba..bcac71a 100644
--- a/cpukit/score/src/apimutexlock.c
+++ b/cpukit/score/src/apimutexlock.c
@@ -30,10 +30,6 @@ void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
previous_thread_life_protection = _Thread_Set_life_protection( true );
- #if defined(RTEMS_SMP)
- #endif
_ISR_lock_ISR_disable( &lock_context );
_CORE_mutex_Seize(
@@ -49,8 +45,4 @@ void _API_Mutex_Lock( API_Mutex_Control *the_mutex )
the_mutex->previous_thread_life_protection =
previous_thread_life_protection;
- #endif
diff --git a/cpukit/score/src/apimutexunlock.c b/cpukit/score/src/apimutexunlock.c
index d0432a6..04657dd 100644
--- a/cpukit/score/src/apimutexunlock.c
+++ b/cpukit/score/src/apimutexunlock.c
@@ -24,18 +24,21 @@
void _API_Mutex_Unlock( API_Mutex_Control *the_mutex )
- bool previous_thread_life_protection;
- bool restore_thread_life_protection;
+ bool previous_thread_life_protection;
+ bool restore_thread_life_protection;
the_mutex->previous_thread_life_protection;
restore_thread_life_protection = the_mutex->Mutex.nest_count == 1;
- _CORE_mutex_Surrender( &the_mutex->Mutex, the_mutex->Object.id, NULL );
+ _ISR_lock_ISR_disable( &lock_context );
+ _CORE_mutex_Surrender(
+ &the_mutex->Mutex,
+ the_mutex->Object.id,
+ NULL,
+ &lock_context
if ( restore_thread_life_protection ) {
_Thread_Set_life_protection( previous_thread_life_protection );
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index 2f584f2..58c6c42 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -48,13 +48,14 @@ CORE_mutex_Status _CORE_mutex_Initialize(
if ( is_priority_ceiling ||
_CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ) {
Priority_Control ceiling = the_mutex->Attributes.priority_ceiling;
* The mutex initialization is only protected by the allocator lock in
* general. Disable thread dispatching before the priority check to
* prevent interference with priority inheritance.
+ cpu_self = _Thread_Dispatch_disable();
if ( is_priority_ceiling && executing->current_priority < ceiling ) {
@@ -73,7 +74,7 @@ CORE_mutex_Status _CORE_mutex_Initialize(
_Thread_Change_priority( executing, ceiling, false );
} else {
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index 4ecb702..2be8fd9 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -53,17 +53,28 @@ void _CORE_mutex_Seize_interrupt_blocking(
+#if !defined(RTEMS_SMP)
+ * We must disable thread dispatching here since we enable the interrupts for
+ * priority inheritance mutexes.
+ _Thread_Dispatch_disable_critical();
+#endif
if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ) {
Thread_Control *holder = the_mutex->holder;
- * To enable interrupts here works only since we own the Giant lock and
- * only threads are allowed to seize and surrender mutexes with the
- * priority inheritance protocol.
+ * To enable interrupts here works only since exactly one executing thread
+ * exists and only threads are allowed to seize and surrender mutexes with
+ * the priority inheritance protocol. On SMP configurations more than one
+ * executing thread may exist, so here we must not release the lock, since
+ * otherwise the current holder may be no longer the holder of the mutex
+ * once we released the lock.
+#endif
_Scheduler_Change_priority_if_higher(
_Scheduler_Get( holder ),
@@ -72,10 +83,11 @@ void _CORE_mutex_Seize_interrupt_blocking(
false
- _ISR_lock_ISR_disable( lock_context );
+ _Thread_queue_Acquire( &the_mutex->Wait_queue, lock_context );
+#endif
- _Thread_queue_Acquire_critical( &the_mutex->Wait_queue, lock_context );
_Thread_queue_Enqueue_critical(
executing,
@@ -85,6 +97,8 @@ void _CORE_mutex_Seize_interrupt_blocking(
lock_context
+ _Thread_Dispatch_enable( _Per_CPU_Get() );
+#endif
diff --git a/cpukit/score/src/coremutexsurrender.c b/cpukit/score/src/coremutexsurrender.c
index 8fba301..1fdf2f3 100644
--- a/cpukit/score/src/coremutexsurrender.c
+++ b/cpukit/score/src/coremutexsurrender.c
@@ -89,11 +89,12 @@ CORE_mutex_Status _CORE_mutex_Surrender(
Objects_Id id,
#else
Objects_Id id __attribute__((unused)),
- CORE_mutex_API_mp_support_callout api_mutex_mp_support __attribute__((unused))
+ CORE_mutex_API_mp_support_callout api_mutex_mp_support __attribute__((unused)),
#endif
Thread_Control *the_thread;
@@ -110,14 +111,20 @@ CORE_mutex_Status _CORE_mutex_Surrender(
if ( the_mutex->Attributes.only_owner_release ) {
- if ( !_Thread_Is_executing( holder ) )
+ if ( !_Thread_Is_executing( holder ) ) {
+ _ISR_lock_ISR_enable( lock_context );
return CORE_MUTEX_STATUS_NOT_OWNER_OF_RESOURCE;
/* XXX already unlocked -- not right status */
- if ( !the_mutex->nest_count )
+ if ( !the_mutex->nest_count ) {
return CORE_MUTEX_STATUS_SUCCESSFUL;
the_mutex->nest_count--;
@@ -130,10 +137,12 @@ CORE_mutex_Status _CORE_mutex_Surrender(
#if defined(RTEMS_DEBUG)
/* should never occur */
return CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED;
#endif
@@ -141,6 +150,7 @@ CORE_mutex_Status _CORE_mutex_Surrender(
break;
#else
/* must be CORE_MUTEX_NESTING_ACQUIRES or we wouldn't be here */
#endif
@@ -155,20 +165,12 @@ CORE_mutex_Status _CORE_mutex_Surrender(
CORE_mutex_Status pop_status =
_CORE_mutex_Pop_priority( the_mutex, holder );
- if ( pop_status != CORE_MUTEX_STATUS_SUCCESSFUL )
+ if ( pop_status != CORE_MUTEX_STATUS_SUCCESSFUL ) {
return pop_status;
holder->resource_count--;
- * Whether or not someone is waiting for the mutex, an
- * inherited priority must be lowered if this is the last
- * mutex (i.e. resource) this task has.
- if ( !_Thread_Owns_resources( holder ) &&
- holder->real_priority != holder->current_priority ) {
- _Thread_Change_priority( holder, holder->real_priority, true );
@@ -176,20 +178,21 @@ CORE_mutex_Status _CORE_mutex_Surrender(
* Now we check if another thread was waiting for this mutex. If so,
* transfer the mutex to that thread.
- if ( ( the_thread = _Thread_queue_Dequeue( &the_mutex->Wait_queue ) ) ) {
+ if ( ( the_thread = _Thread_queue_First_locked( &the_mutex->Wait_queue ) ) ) {
+ * We must extract the thread now since this will restore its default
+ * thread lock. This is necessary to avoid a deadlock in the
+ * _Thread_Change_priority() below due to a recursive thread queue lock
+ * acquire.
+ _Thread_queue_Extract_locked( &the_mutex->Wait_queue, the_thread );
- if ( !_Objects_Is_local_id( the_thread->Object.id ) ) {
- the_mutex->holder = NULL;
- the_mutex->nest_count = 1;
- ( *api_mutex_mp_support)( the_thread, id );
- } else
+ if ( _Objects_Is_local_id( the_thread->Object.id ) )
#endif
the_mutex->holder = the_thread;
@@ -215,6 +218,41 @@ CORE_mutex_Status _CORE_mutex_Surrender(
break;
+ _Thread_queue_Unblock_critical(
+ &the_mutex->Wait_queue,
+ the_thread,
+ lock_context
+#if defined(RTEMS_MULTIPROCESSING)
+ if ( !_Objects_Is_local_id( the_thread->Object.id ) ) {
+ the_mutex->holder = NULL;
+ the_mutex->nest_count = 1;
+ ( *api_mutex_mp_support)( the_thread, id );
+#endif
+ } else {
+ * Whether or not someone is waiting for the mutex, an
+ * inherited priority must be lowered if this is the last
+ * mutex (i.e. resource) this task has.
+ if ( !_Thread_Owns_resources( holder ) &&
+ holder->real_priority != holder->current_priority ) {
+ _Thread_Change_priority( holder, holder->real_priority, true );
diff --git a/cpukit/score/src/debugisownerofallocator.c b/cpukit/score/src/debugisownerofallocator.c
index 7879902..57da2ca 100644
--- a/cpukit/score/src/debugisownerofallocator.c
+++ b/cpukit/score/src/debugisownerofallocator.c
@@ -18,8 +18,7 @@
#include <rtems/score/apimutex.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/threaddispatch.h>
+#include <rtems/score/threadimpl.h>
#if defined( RTEMS_DEBUG )
bool _Debug_Is_owner_of_allocator( void )
@@ -27,20 +26,12 @@
API_Mutex_Control *mutex = _RTEMS_Allocator_Mutex;
bool owner;
- * We have to synchronize with the _CORE_mutex_Surrender() operation,
- * otherwise we may observe an outdated mutex holder.
if ( mutex != NULL ) {
- owner = mutex->Mutex.holder == _Thread_Executing;
+ owner = mutex->Mutex.holder == _Thread_Get_executing();
} else {
owner = false;
return owner;
#endif
1.8.4.5
