USB Host and MMC/SD Card Stack
Sebastian Huber
Fri May 15 13:54:52 UTC 2015
Hello,
the USB host and MMC/SD card stack for RTEMS is now available via the
libbsd:
http://git.rtems.org/rtems-libbsd.git/
I will remove my libusb repository to avoid confusion.
On 27/08/14 14:19, Sebastian Huber wrote:
> Hello,
> I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
> repository area:
> http://git.rtems.org/sebh/rtems-libusb.git/
> It was previously only available as a snapshot:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
> The USB host stack is a port from FreeBSD 8. The MMC/SD card stack is
> a port from FreeBSD 9.3.
> The libusb is a subset an older version of the libbsd which contains
> also the network stack from FreeBSD 9.3. We use libusb on some boards
> and projects. I simply had no time to test the USB and MMC/SD parts
> in libbsd.
> http://git.rtems.org/rtems-libbsd/
> Both libraries lack documentation. The basic network stack in libbsd
> works well, but more work is required to polish it.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
