I think there is a mistake in some bsp_specs files
Gedare Bloom gedare at gwu.edu
Fri May 15 14:45:14 UTC 2015
Someone please open a ticket on Trac for this.
On Wed, May 13, 2015 at 9:08 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 14/05/2015 9:59 am, Joel Sherrill wrote:
>> On May 13, 2015 6:57:29 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>>> On 14/05/2015 3:10 am, Joel Sherrill wrote:
>>>> On 5/13/2015 4:07 AM, Tom wrote:
>>>>> Hi all
>>>>> I read the bsp_specs files contained in some bsps, which reside in
>>>>> libbsp/arm, libbsp/bfin and libbsp/m32r
>>>>> *endfile:
>>>>> %{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
>>>>> I think it should be %.
>>>>> I wrote a specs file and tested using gcc 4.8.2.
>>>> This definitely looks like a typo that we are lucky appears
>>>> to have no impact. The only time the bsp_spec is used, the other
>>>> path (-qrtems) is tripped.
>>>> Is there objection to me fixing this in the following files:
>>> No. Please raise a ticket to track the change.
>> If there is a ticket can it be done before branching? I would have filed the ticket.
> Sorry about that, I meant no objection from me.
> Yes it can be committed but I would like a ticket to track an changes
> until we branch.
> Chris
> devel mailing list
> devel at rtems.org
