[PATCH 05/45] score: Add header to _Watchdog_Remove()
Fri May 15 18:07:17 UTC 2015
On Fri, May 15, 2015 at 7:41 AM, Sebastian Huber
> Add watchdog header parameter to _Watchdog_Remove() to be in line with
> the other operations.  Add _Watchdog_Remove_ticks() and
> _Watchdog_Remove_seconds() for convenience.
> Update #2307.
>  cpukit/posix/src/alarm.c                        |  2 +-
>  cpukit/posix/src/psignalunblockthread.c         |  2 +-
>  cpukit/posix/src/pthread.c                      |  2 +-
>  cpukit/posix/src/pthreadsetschedparam.c         |  4 ++--
>  cpukit/posix/src/timerdelete.c                  |  2 +-
>  cpukit/posix/src/timerinserthelper.c            |  2 +-
>  cpukit/posix/src/timersettime.c                 |  2 +-
>  cpukit/posix/src/ualarm.c                       |  2 +-
>  cpukit/rtems/include/rtems/rtems/timerimpl.h    | 13 ++++++++++---
>  cpukit/rtems/src/eventseize.c                   |  2 +-
>  cpukit/rtems/src/eventsurrender.c               |  2 +-
>  cpukit/rtems/src/ratemoncancel.c                |  2 +-
>  cpukit/rtems/src/ratemondelete.c                |  2 +-
>  cpukit/rtems/src/timercancel.c                  |  3 +--
>  cpukit/rtems/src/timercreate.c                  | 21 +++++++++++++++++++++
>  cpukit/rtems/src/timerdelete.c                  |  2 +-
>  cpukit/rtems/src/timerfireafter.c               |  2 +-
>  cpukit/rtems/src/timerfirewhen.c                |  2 +-
>  cpukit/rtems/src/timerreset.c                   |  2 +-
>  cpukit/rtems/src/timerserver.c                  | 19 ++++++++++++++++---
>  cpukit/rtems/src/timerserverfireafter.c         |  2 +-
>  cpukit/rtems/src/timerserverfirewhen.c          |  2 +-
>  cpukit/score/include/rtems/score/mrspimpl.h     |  2 +-
>  cpukit/score/include/rtems/score/watchdogimpl.h | 18 +++++++++++++++++-
>  cpukit/score/src/threadqenqueue.c               |  2 +-
>  cpukit/score/src/threadrestart.c                |  4 ++--
>  cpukit/score/src/watchdogremove.c               |  1 +
>  cpukit/score/src/watchdogtickle.c               |  2 +-
>  testsuites/sptests/spintrcritical08/init.c      |  2 +-
>  testsuites/sptests/spintrcritical09/init.c      |  2 +-
>  30 files changed, 92 insertions(+), 35 deletions(-)
> diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
> index 4803661..6f051d7 100644
> --- a/cpukit/posix/src/alarm.c
> +++ b/cpukit/posix/src/alarm.c
> @@ -73,7 +73,7 @@ unsigned int alarm(
>    _Thread_Disable_dispatch();
> -  state = _Watchdog_Remove( the_timer );
> +  state = _Watchdog_Remove_seconds( the_timer );
>    if ( (state == WATCHDOG_ACTIVE) || (state == WATCHDOG_REMOVE_IT) ) {
>       *  The stop_time and start_time fields are snapshots of ticks since
> diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
> index 1b3db68..3b310a9 100644
> --- a/cpukit/posix/src/psignalunblockthread.c
> +++ b/cpukit/posix/src/psignalunblockthread.c
> @@ -115,7 +115,7 @@ bool _POSIX_signals_Unblock_thread(
>         *  queue, but is also interruptible by a POSIX signal.
>         if ( _States_Is_delaying(the_thread->current_state) ) {
> -          (void) _Watchdog_Remove( &the_thread->Timer );
> +          _Watchdog_Remove_ticks( &the_thread->Timer );
>            _Thread_Unblock( the_thread );
>         } else {
>           _Thread_queue_Extract_with_proxy( the_thread );
> diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
> index 4d28de5..97882bf 100644
> --- a/cpukit/posix/src/pthread.c
> +++ b/cpukit/posix/src/pthread.c
> @@ -286,7 +286,7 @@ static void _POSIX_Threads_Terminate_extension(
>        *(void **)the_thread->Wait.return_argument = value_ptr;
>    if ( api->schedpolicy == SCHED_SPORADIC )
> -    (void) _Watchdog_Remove( &api->Sporadic_timer );
> +    _Watchdog_Remove_ticks( &api->Sporadic_timer );
>    _Thread_Enable_dispatch();
> diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
> index d5d0a5b..dcb70bd 100644
> --- a/cpukit/posix/src/pthreadsetschedparam.c
> +++ b/cpukit/posix/src/pthreadsetschedparam.c
> @@ -70,7 +70,7 @@ int pthread_setschedparam(
>        api = the_thread->API_Extensions[ THREAD_API_POSIX ];
>        api->schedpolicy = policy;
>        api->schedparam  = *param;
> @@ -99,7 +99,7 @@ int pthread_setschedparam(
>          case SCHED_SPORADIC:
>            api->ss_high_priority = api->schedparam.sched_priority;
> -          _Watchdog_Remove( &api->Sporadic_timer );
>            _POSIX_Threads_Sporadic_budget_TSR( 0, the_thread );
>            break;
> diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
> index 71b25fa..e090be2 100644
> --- a/cpukit/posix/src/timerdelete.c
> +++ b/cpukit/posix/src/timerdelete.c
> @@ -54,7 +54,7 @@ int timer_delete(
>      case OBJECTS_LOCAL:
>        _Objects_Close( &_POSIX_Timer_Information, &ptimer->Object );
>        ptimer->state = POSIX_TIMER_STATE_FREE;
> -      (void) _Watchdog_Remove( &ptimer->Timer );
> +      _Watchdog_Remove_ticks( &ptimer->Timer );
>        _Objects_Put( &ptimer->Object );
>        _POSIX_Timer_Free( ptimer );
>        _Objects_Allocator_unlock();
> diff --git a/cpukit/posix/src/timerinserthelper.c b/cpukit/posix/src/timerinserthelper.c
> index 9d02835..4d7c3fb 100644
> --- a/cpukit/posix/src/timerinserthelper.c
> +++ b/cpukit/posix/src/timerinserthelper.c
> @@ -39,7 +39,7 @@ bool _POSIX_Timer_Insert_helper(
>    ISR_Level            level;
> -  (void) _Watchdog_Remove( timer );
> +  _Watchdog_Remove_ticks( timer );
>    _ISR_Disable( level );
> diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
> index 6cc3780..2967df6 100644
> --- a/cpukit/posix/src/timersettime.c
> +++ b/cpukit/posix/src/timersettime.c
> @@ -85,7 +85,7 @@ int timer_settime(
>        /* First, it verifies if the timer must be stopped */
>        if ( normalize.it_value.tv_sec == 0 && normalize.it_value.tv_nsec == 0 ) {
>           /* Stop the timer */
>           /* The old data of the timer are returned */
>           if ( ovalue )
>             *ovalue = ptimer->timer_data;
> diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
> index d9a85e6..9235ef1 100644
> --- a/cpukit/posix/src/ualarm.c
> +++ b/cpukit/posix/src/ualarm.c
> @@ -72,7 +72,7 @@ useconds_t ualarm(
> +  state = _Watchdog_Remove_ticks( the_timer );
> diff --git a/cpukit/rtems/include/rtems/rtems/timerimpl.h b/cpukit/rtems/include/rtems/rtems/timerimpl.h
> index b695d5e..4f200ef 100644
> --- a/cpukit/rtems/include/rtems/rtems/timerimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/timerimpl.h
> @@ -50,9 +50,9 @@ extern "C" {
>  typedef struct Timer_server_Control Timer_server_Control;
> - * @brief Method used to schedule the insertion of task based timers.
> + * @brief Method used for task based timers.
> -typedef void (*Timer_server_Schedule_operation)(
> +typedef void (*Timer_server_Method)(
>    Timer_server_Control *timer_server,
>    Timer_Control        *timer
> @@ -84,9 +84,14 @@ struct Timer_server_Control {
>    Thread_Control *thread;
> +   * @brief The cancel method of the timer server.
> +  Timer_server_Method cancel;
>     * @brief The schedule operation method of the timer server.
> -  Timer_server_Schedule_operation schedule_operation;
> +  Timer_server_Method schedule_operation;
>     * @brief Interval watchdogs triggered by the timer server.
> @@ -220,6 +225,8 @@ RTEMS_INLINE_ROUTINE bool _Timer_Is_dormant_class (
>    return ( the_class == TIMER_DORMANT );
> +void _Timer_Cancel( Timer_Control *the_timer );
>  #ifdef __cplusplus
> diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
> index 9296656..36b1964 100644
> --- a/cpukit/rtems/src/eventseize.c
> +++ b/cpukit/rtems/src/eventseize.c
> @@ -101,7 +101,7 @@ void _Event_Seize(
>      wait_class | THREAD_WAIT_STATE_BLOCKED
>    if ( !success ) {
> -    _Watchdog_Remove( &executing->Timer );
> +    _Watchdog_Remove_ticks( &executing->Timer );
>      _Thread_Unblock( executing );
> diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
> index ba4e429..e29d203 100644
> --- a/cpukit/rtems/src/eventsurrender.c
> +++ b/cpukit/rtems/src/eventsurrender.c
> @@ -111,7 +111,7 @@ void _Event_Surrender(
>      _Thread_Lock_release_default( the_thread, lock_context );
>      _Giant_Acquire( cpu_self );
> -    _Watchdog_Remove( &the_thread->Timer );
>      _Giant_Release( cpu_self );
> diff --git a/cpukit/rtems/src/ratemoncancel.c b/cpukit/rtems/src/ratemoncancel.c
> index d4a9102..67b230f 100644
> --- a/cpukit/rtems/src/ratemoncancel.c
> +++ b/cpukit/rtems/src/ratemoncancel.c
> @@ -38,7 +38,7 @@ rtems_status_code rtems_rate_monotonic_cancel(
>          _Objects_Put( &the_period->Object );
>          return RTEMS_NOT_OWNER_OF_RESOURCE;
> -      (void) _Watchdog_Remove( &the_period->Timer );
> +      _Watchdog_Remove_ticks( &the_period->Timer );
>        the_period->state = RATE_MONOTONIC_INACTIVE;
>        _Scheduler_Release_job( the_period->owner, 0 );
> diff --git a/cpukit/rtems/src/ratemondelete.c b/cpukit/rtems/src/ratemondelete.c
> index 971ad8e..77cf3fe 100644
> --- a/cpukit/rtems/src/ratemondelete.c
> +++ b/cpukit/rtems/src/ratemondelete.c
> @@ -37,7 +37,7 @@ rtems_status_code rtems_rate_monotonic_delete(
>      case OBJECTS_LOCAL:
>        _Objects_Close( &_Rate_monotonic_Information, &the_period->Object );
>        _Rate_monotonic_Free( the_period );
> diff --git a/cpukit/rtems/src/timercancel.c b/cpukit/rtems/src/timercancel.c
> index a8ce147..1e737a2 100644
> --- a/cpukit/rtems/src/timercancel.c
> +++ b/cpukit/rtems/src/timercancel.c
> @@ -45,8 +45,7 @@ rtems_status_code rtems_timer_cancel(
>    switch ( location ) {
>      case OBJECTS_LOCAL:
> -      if ( !_Timer_Is_dormant_class( the_timer->the_class ) )
> -        (void) _Watchdog_Remove( &the_timer->Ticker );
> +      _Timer_Cancel( the_timer );
>        _Objects_Put( &the_timer->Object );
>        return RTEMS_SUCCESSFUL;
> diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
> index 0b1c44b..390c965 100644
> --- a/cpukit/rtems/src/timercreate.c
> +++ b/cpukit/rtems/src/timercreate.c
> @@ -25,6 +25,27 @@
>  #include <rtems/rtems/timerimpl.h>
>  #include <rtems/score/watchdogimpl.h>
> +  Timer_server_Control *timer_server;
> +  switch ( the_timer->the_class ) {
> +    case TIMER_INTERVAL:
> +      _Watchdog_Remove_ticks( &the_timer->Ticker );
> +      break;
> +    case TIMER_TIME_OF_DAY:
> +      _Watchdog_Remove_seconds( &the_timer->Ticker );
> +      break;
> +    case TIMER_INTERVAL_ON_TASK:
> +    case TIMER_TIME_OF_DAY_ON_TASK:
> +      timer_server = _Timer_server;
> +      (*timer_server->cancel)( timer_server, the_timer );
> +      break;
> +    default:
Should this be an error case?
> +      break;
>  rtems_status_code rtems_timer_create(
>    rtems_name  name,
>    rtems_id   *id
> diff --git a/cpukit/rtems/src/timerdelete.c b/cpukit/rtems/src/timerdelete.c
> index 19232c8..0849ec5 100644
> --- a/cpukit/rtems/src/timerdelete.c
> +++ b/cpukit/rtems/src/timerdelete.c
> @@ -38,7 +38,7 @@ rtems_status_code rtems_timer_delete(
>      case OBJECTS_LOCAL:
>        _Objects_Close( &_Timer_Information, &the_timer->Object );
>        _Timer_Free( the_timer );
> diff --git a/cpukit/rtems/src/timerfireafter.c b/cpukit/rtems/src/timerfireafter.c
> index 07862cd..84cf46b 100644
> --- a/cpukit/rtems/src/timerfireafter.c
> +++ b/cpukit/rtems/src/timerfireafter.c
> @@ -46,7 +46,7 @@ rtems_status_code rtems_timer_fire_after(
>      case OBJECTS_LOCAL:
> diff --git a/cpukit/rtems/src/timerfirewhen.c b/cpukit/rtems/src/timerfirewhen.c
> index 6ac7d17..1acbaf9 100644
> --- a/cpukit/rtems/src/timerfirewhen.c
> +++ b/cpukit/rtems/src/timerfirewhen.c
> @@ -51,7 +51,7 @@ rtems_status_code rtems_timer_fire_when(
>      case OBJECTS_LOCAL:
>        the_timer->the_class = TIMER_TIME_OF_DAY;
>        _Watchdog_Initialize( &the_timer->Ticker, routine, id, user_data );
>        _Watchdog_Insert_seconds(
> diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
> index 49c4925..7ab172e 100644
> --- a/cpukit/rtems/src/timerreset.c
> +++ b/cpukit/rtems/src/timerreset.c
> @@ -67,7 +67,7 @@ rtems_status_code rtems_timer_reset(
>              return RTEMS_INCORRECT_STATE;
>          #endif
> -        _Watchdog_Remove( &the_timer->Ticker );
>          (*timer_server->schedule_operation)( timer_server, the_timer );
>        } else {
> diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
> index 25191e4..15cbdfd 100644
> --- a/cpukit/rtems/src/timerserver.c
> +++ b/cpukit/rtems/src/timerserver.c
> @@ -38,7 +38,7 @@ static void _Timer_server_Stop_interval_system_watchdog(
>    Timer_server_Control *ts
> -  _Watchdog_Remove( &ts->Interval_watchdogs.System_watchdog );
> +  _Watchdog_Remove_ticks( &ts->Interval_watchdogs.System_watchdog );
>  static void _Timer_server_Reset_interval_system_watchdog(
> @@ -71,7 +71,7 @@ static void _Timer_server_Stop_tod_system_watchdog(
> -  _Watchdog_Remove( &ts->TOD_watchdogs.System_watchdog );
> +  _Watchdog_Remove_seconds( &ts->TOD_watchdogs.System_watchdog );
>  static void _Timer_server_Reset_tod_system_watchdog(
> @@ -210,6 +210,18 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
> +static void _Timer_server_Cancel_method(
> +  Timer_server_Control *ts,
> +  Timer_Control *timer
> +  if ( timer->the_class == TIMER_INTERVAL_ON_TASK ) {
> +    _Watchdog_Remove( &ts->Interval_watchdogs.Header, &timer->Ticker );
> +  } else if ( timer->the_class == TIMER_TIME_OF_DAY_ON_TASK ) {
> +    _Watchdog_Remove( &ts->TOD_watchdogs.Header, &timer->Ticker );
>  static void _Timer_server_Schedule_operation_method(
> @@ -563,9 +575,10 @@ rtems_status_code rtems_timer_initiate_server(
> -   *  Initialize the pointer to the timer schedule method so applications that
> +   *  Initialize the pointer to the timer server methods so applications that
>     *  do not use the Timer Server do not have to pull it in.
> +  ts->cancel = _Timer_server_Cancel_method;
>    ts->schedule_operation = _Timer_server_Schedule_operation_method;
>    ts->Interval_watchdogs.last_snapshot = _Watchdog_Ticks_since_boot;
> diff --git a/cpukit/rtems/src/timerserverfireafter.c b/cpukit/rtems/src/timerserverfireafter.c
> index 1256645..0636782 100644
> --- a/cpukit/rtems/src/timerserverfireafter.c
> +++ b/cpukit/rtems/src/timerserverfireafter.c
> @@ -50,7 +50,7 @@ rtems_status_code rtems_timer_server_fire_after(
>      case OBJECTS_LOCAL:
> diff --git a/cpukit/rtems/src/timerserverfirewhen.c b/cpukit/rtems/src/timerserverfirewhen.c
> index 32695fb..0069af1 100644
> --- a/cpukit/rtems/src/timerserverfirewhen.c
> +++ b/cpukit/rtems/src/timerserverfirewhen.c
> @@ -72,7 +72,7 @@ rtems_status_code rtems_timer_server_fire_when(
>      case OBJECTS_LOCAL:
>        the_timer->the_class = TIMER_TIME_OF_DAY_ON_TASK;
>        the_timer->Ticker.initial = seconds - _TOD_Seconds_since_epoch();
> diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
> index c40f41f..07f78ce 100644
> --- a/cpukit/score/include/rtems/score/mrspimpl.h
> +++ b/cpukit/score/include/rtems/score/mrspimpl.h
> @@ -216,7 +216,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
>    _Thread_Set_life_protection( initial_life_protection );
>    if ( timeout > 0 ) {
>    return status;
> diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
> index e548e7025..ddd1ca4 100644
> --- a/cpukit/score/include/rtems/score/watchdogimpl.h
> +++ b/cpukit/score/include/rtems/score/watchdogimpl.h
> @@ -99,10 +99,12 @@ void _Watchdog_Handler_initialization( void );
>   *  This routine removes @a the_watchdog from the watchdog chain on which
>   *  it resides and returns the state @a the_watchdog timer was in.
> + *  @param[in] header The watchdog chain.
>   *  @param[in] the_watchdog will be removed
>   *  @retval the state in which @a the_watchdog was in when removed
>  Watchdog_States _Watchdog_Remove (
> +  Watchdog_Header  *header,
>    Watchdog_Control *the_watchdog
> @@ -306,6 +308,20 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Insert_seconds(
> +RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_ticks(
> +  Watchdog_Control *the_watchdog
> +  return _Watchdog_Remove( &_Watchdog_Ticks_header, the_watchdog );
> +RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_seconds(
> +  return _Watchdog_Remove( &_Watchdog_Seconds_header, the_watchdog );
>   * This routine resets THE_WATCHDOG timer to its state at INSERT
>   * time.  This routine is valid only on interval watchdog timers
> @@ -318,7 +334,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Reset_ticks(
> -  (void) _Watchdog_Remove( the_watchdog );
> +  _Watchdog_Remove_ticks( the_watchdog );
>    _Watchdog_Insert( &_Watchdog_Ticks_header, the_watchdog );
> diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
> index 5f94ec9..590865d 100644
> --- a/cpukit/score/src/threadqenqueue.c
> +++ b/cpukit/score/src/threadqenqueue.c
> @@ -66,7 +66,7 @@ static void _Thread_blocking_operation_Finalize(
>    if ( _Watchdog_Is_active( &the_thread->Timer ) ) {
>      _Watchdog_Deactivate( &the_thread->Timer );
>      _Thread_queue_Release( lock_context );
>    } else
> diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
> index e759b5b..8dea518 100644
> --- a/cpukit/score/src/threadrestart.c
> +++ b/cpukit/score/src/threadrestart.c
> @@ -62,7 +62,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
>    _Thread_Set_state( the_thread, STATES_ZOMBIE );
>    _ISR_lock_ISR_disable_and_acquire( &zombies->Lock, &lock_context );
>    _Chain_Append_unprotected( &zombies->Chain, &the_thread->Object.Node );
> @@ -235,7 +235,7 @@ static void _Thread_Start_life_change(
>    _Thread_Set_state( the_thread, STATES_RESTARTING );
>    _Scheduler_Set_priority_if_higher( scheduler, the_thread, priority );
>    _Thread_Add_post_switch_action( the_thread, &the_thread->Life.Action );
>    _Thread_Ready( the_thread );
> diff --git a/cpukit/score/src/watchdogremove.c b/cpukit/score/src/watchdogremove.c
> index 34d97b0..d689e3c 100644
> --- a/cpukit/score/src/watchdogremove.c
> +++ b/cpukit/score/src/watchdogremove.c
> @@ -23,6 +23,7 @@
>  Watchdog_States _Watchdog_Remove(
Is the parameter unused in this function?
> diff --git a/cpukit/score/src/watchdogtickle.c b/cpukit/score/src/watchdogtickle.c
> index 8c1a3a7..5b2f258 100644
> --- a/cpukit/score/src/watchdogtickle.c
> +++ b/cpukit/score/src/watchdogtickle.c
> @@ -74,7 +74,7 @@ void _Watchdog_Tickle(
>    do {
> -     watchdog_state = _Watchdog_Remove( the_watchdog );
> +     watchdog_state = _Watchdog_Remove( header, the_watchdog );
>       _ISR_Enable( level );
> diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
> index 13544b2..f375cd4 100644
> --- a/testsuites/sptests/spintrcritical08/init.c
> +++ b/testsuites/sptests/spintrcritical08/init.c
> @@ -55,7 +55,7 @@ static rtems_timer_service_routine test_release_from_isr(
>        watchdog->delta_interval == 0
>          && watchdog->routine == _Rate_monotonic_Timeout
> -      Watchdog_States state = _Watchdog_Remove( watchdog );
> +      Watchdog_States state = _Watchdog_Remove_ticks( watchdog );
>        rtems_test_assert( state == WATCHDOG_ACTIVE );
>        (*watchdog->routine)( watchdog->id, watchdog->user_data );
> diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
> index 2f9caa5..0e38351 100644
> --- a/testsuites/sptests/spintrcritical09/init.c
> +++ b/testsuites/sptests/spintrcritical09/init.c
> @@ -52,7 +52,7 @@ static rtems_timer_service_routine test_release_from_isr(
>          && watchdog->routine == _Thread_queue_Timeout
> 1.8.4.5
> devel mailing list
> devel at rtems.org
