[PATCH 34/45] score: Do not inline SMP lock if profiling enabled
Gedare Bloom gedare at gwu.edu
Sun May 17 02:21:03 UTC 2015
Not really related, but what is the "rule" for when we should use
RTEMS_INLINE_ROUTINE versus being able to say "static inline"?
-Gedare
On Fri, May 15, 2015 at 7:41 AM, Sebastian Huber
> This reduces the code size drastically.
>  cpukit/score/Makefile.am                   |  1 +
>  cpukit/score/include/rtems/score/smplock.h | 57 ++++++++++++++++++++++++-
>  cpukit/score/src/smplock.c                 | 68 ++++++++++++++++++++++++++++++
>  3 files changed, 125 insertions(+), 1 deletion(-)
>  create mode 100644 cpukit/score/src/smplock.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index cede673..714bd66 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -138,6 +138,7 @@ libscore_a_SOURCES += src/schedulerprioritysmp.c
>  libscore_a_SOURCES += src/schedulersimplesmp.c
>  libscore_a_SOURCES += src/schedulersmpdebug.c
>  libscore_a_SOURCES += src/smp.c
> +libscore_a_SOURCES += src/smplock.c
>  libscore_a_SOURCES += src/smpmulticastaction.c
>  libscore_a_SOURCES += src/cpuset.c
>  libscore_a_SOURCES += src/cpusetprintsupport.c
> diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
> index 5eb6ef3..50a0662 100644
> --- a/cpukit/score/include/rtems/score/smplock.h
> +++ b/cpukit/score/include/rtems/score/smplock.h
> @@ -10,7 +10,7 @@
>   * COPYRIGHT (c) 1989-2011.
>   * On-Line Applications Research Corporation (OAR).
> - * Copyright (c) 2013-2014 embedded brains GmbH
> + * Copyright (c) 2013-2015 embedded brains GmbH
>   * The license and distribution terms for this file may be
>   * found in the file LICENSE in this distribution or at
> @@ -32,6 +32,10 @@
>  #include <string.h>
>  #endif
> +#if defined( RTEMS_PROFILING )
> +#define RTEMS_SMP_LOCK_DO_NOT_INLINE
> +#endif
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> @@ -368,7 +372,16 @@ typedef struct {
>   * @param[in] name The name for the SMP lock statistics.  This name must be
>   * persistent throughout the life time of this statistics block.
> +#if defined( RTEMS_SMP_LOCK_DO_NOT_INLINE )
> +void _SMP_lock_Initialize(
> +  SMP_lock_Control *lock,
> +  const char *name
> +static inline void _SMP_lock_Initialize_body(
> +#else
>  static inline void _SMP_lock_Initialize(
> +#endif
>    const char *name
> @@ -383,7 +396,13 @@ static inline void _SMP_lock_Initialize(
>   * @param[in,out] lock The SMP lock control.
> +void _SMP_lock_Destroy( SMP_lock_Control *lock );
> +static inline void _SMP_lock_Destroy_body( SMP_lock_Control *lock )
> +#else
>  static inline void _SMP_lock_Destroy( SMP_lock_Control *lock )
> +#endif
>    _SMP_ticket_lock_Destroy( &lock->ticket_lock );
> @@ -399,7 +418,16 @@ static inline void _SMP_lock_Destroy( SMP_lock_Control *lock )
>   * @param[in,out] context The local SMP lock context for an acquire and release
>   * pair.
> +void _SMP_lock_Acquire(
> +  SMP_lock_Context *context
> +static inline void _SMP_lock_Acquire_body(
> +#else
>  static inline void _SMP_lock_Acquire(
> +#endif
> @@ -415,7 +443,16 @@ static inline void _SMP_lock_Acquire(
>   * pair.
> +void _SMP_lock_Release(
> +static inline void _SMP_lock_Release_body(
> +#else
>  static inline void _SMP_lock_Release(
> +#endif
> @@ -431,7 +468,16 @@ static inline void _SMP_lock_Release(
>   * pair.
> +void _SMP_lock_ISR_disable_and_acquire(
> +static inline void _SMP_lock_ISR_disable_and_acquire_body(
> +#else
>  static inline void _SMP_lock_ISR_disable_and_acquire(
> +#endif
> @@ -447,7 +493,16 @@ static inline void _SMP_lock_ISR_disable_and_acquire(
>   * pair.
> +void _SMP_lock_Release_and_ISR_enable(
> +static inline void _SMP_lock_Release_and_ISR_enable_body(
> +#else
>  static inline void _SMP_lock_Release_and_ISR_enable(
> +#endif
> diff --git a/cpukit/score/src/smplock.c b/cpukit/score/src/smplock.c
> new file mode 100644
> index 0000000..1440091
> --- /dev/null
> +++ b/cpukit/score/src/smplock.c
> @@ -0,0 +1,68 @@
> + * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/score/smplock.h>
> +#if defined(RTEMS_SMP_LOCK_DO_NOT_INLINE)
> +  const char *name
> +  _SMP_lock_Initialize_body( lock, name );
> +  _SMP_lock_Destroy_body( lock );
> +  _SMP_lock_Acquire_body( lock, context );
> +  _SMP_lock_Release_body( lock, context );
> +  _SMP_lock_ISR_disable_and_acquire_body( lock, context );
> +  _SMP_lock_Release_and_ISR_enable_body( lock, context );
> +#endif /* defined(RTEMS_SMP_LOCK_DO_NOT_INLINE) */
> 1.8.4.5
> devel mailing list
> devel at rtems.org
