USB Host and MMC/SD Card Stack
Mon May 18 07:01:06 UTC 2015
On 16/05/15 20:53, Afshin Jamaali (Arian) wrote:
> Hi Sebastian,
> Sorry, it seems a problem exists. The link
> "http://git.rtems.org/rtems-libbsd.git/" says:
> "No repositories found"
Sorry, the right link is:
https://git.rtems.org/rtems-libbsd
> Best Regards,
> Afshin Jamaali
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
> Sent: Friday, May 15, 2015 18:25
> To: devel at rtems.org
> Subject: Re: USB Host and MMC/SD Card Stack
> Hello,
> the USB host and MMC/SD card stack for RTEMS is now available via the
> libbsd:
> I will remove my libusb repository to avoid confusion.
> On 27/08/14 14:19, Sebastian Huber wrote:
>> Hello,
>> I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
>> repository area:
>> http://git.rtems.org/sebh/rtems-libusb.git/
>> It was previously only available as a snapshot:
>> https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
>> The USB host stack is a port from FreeBSD 8.  The MMC/SD card stack is
>> a port from FreeBSD 9.3.
>> The libusb is a subset an older version of the libbsd which contains
>> also the network stack from FreeBSD 9.3.  We use libusb on some boards
>> and projects.  I simply had no time to test the USB and MMC/SD parts
>> in libbsd.
>> http://git.rtems.org/rtems-libbsd/
>> Both libraries lack documentation.  The basic network stack in libbsd
>> works well, but more work is required to polish it.
> devel mailing list
> devel at rtems.org
