tms570 warning on master
Thu May 21 23:37:50 UTC 2015
On 5/21/2015 4:44 PM, Chris Johns wrote:
> On 22/05/2015 1:38 am, Joel Sherrill wrote:
>> Does libbsd still build for all architectures? I haven't tried that in a
>> while but it did at one point.
> No and it will not. Adding the waf support to build libbsd I noticed it
> contained and installed dlfcn.h and over wrote the one in RTEMS provided
> by libdl. We cannot have 2 different versions of this file around.
> I did a 'git rm' of the header to check libbsd builds using the RTEMS
> one and it does build but forgot I had done this and committed and push it.
> The issue is not all archs build and install libdl so they will not
> build libbsd.
Is it possible for the libbsd code to detect when an architecture does
not meet minimum
requirements and then give an error and stop.
> Chris
> devel mailing list
> devel at rtems.org
