Porting ethernet driver from FREEBSD to rtems-libbsd
Thu May 28 12:34:40 UTC 2015
This interrupt server task is a hack. It works for proper interrupt
controllers. You must be able to disable a single interrupt source in
the interrupt controller.
On 28/05/15 14:23, Isaac Gutekunst wrote:
> I'm going to chime in since this sounds like a similar problem I've
> experienced on a PIC32.
> I wanted to reword what Ragunath said in my own words to see if I
> understand it.
> 1) The RX ISR fires, vectoring the code to the ISR entry.
> 2) The code in the ISR disables interrupts, creates an event to be
> handled by RTEMS (in a non interrupt context)
> 3) At some point (dispatch function), interrupts are enabled
> 4) Since the RTEMS task responsible for performing non-generic
> handling hasn't run, the hardware condition that created the initial
> interrupt has not been cleared. Therefore, the interrupt controller
> vectors to the ISR entry again, repeating the cycle.
Yes, this is how it works on the beagle BSP.  With the ARM GIC it works
like this:
2) The code in the ISR disables exactly this interrupt source, creates
an event to be handled by RTEMS (in a non interrupt context)
3) The interrupt server thread eventually calls the real ISR routine
which clears the interrupt condition.
4) The interrupt server thread enables exactly this interrupt source.
> In this case, the fundamental problem is that an ISR will continue
> firing until the condition causing it is resolved. In the case of an
> RX interrupt, that usually would mean reading data from a SFR or
> buffer. I'm not familiar with this specific case, but it sounds
> awfully similar.
> Does this sound right?
> If so, it seems like a rather fundamental problem I haven't been able
> to resolve. I'm hoping someone has found a reasonable solution that I
> wasn't smart enough to figure out my self.
> Isaac
> On Thu, May 28, 2015 at 8:01 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     It depends on the capabilities of the interrupt controller. Maybe
>     you have to drop the support for nested interrupts. The
>     bsp_interrupt_dispatch() function for a state of the art interrupt
>     controller looks like this (arm-gic-irq.c):
>     void bsp_interrupt_dispatch(void)
>       volatile gic_cpuif *cpuif = GIC_CPUIF;
>       uint32_t icciar = cpuif->icciar;
>       rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
>       rtems_vector_number spurious = 1023;
>       if (vector != spurious) {
>         uint32_t psr = _ARMV4_Status_irq_enable();
>         bsp_interrupt_handler_dispatch(vector);
>         _ARMV4_Status_restore(psr);
>         cpuif->icceoir = icciar;
>     On 28/05/15 13:50, ragu nath wrote:
>         Hi Sebastian,
>         The problem is with rx interrupt. We are enabling rx interrupt
>         before
>         it is processed. The rtems server task do not get an
>         opportunity to
>         run.
>         I found this might be the logical explanation of the issue.
>         bsp_interrupt_dispatch() calls bsp_interrupt_server_trigger which
>         disables the rx interrupt and creates BSP_INTERRUPT_EVENT .
>         For this
>         event, bsp_interrupt_server_task() was supposed to call the actual
>         interrupt handler and then enable the rx interrupt. But before the
>         event is processed, we enable the rx interrupt in dispatch
>         function.
>         So again rx interrupt is generated and event is created and
>         the cycle
>         goes on. Server task is never executed in turn actual interrupt
>         handler is never executed.
>         Since we enable the interrupt, it occurs again and again as we
>         never handle it.
>         Is there any other possibility that I might need to look into?
>         Thanks,
>         Ragunath
>         On Thu, May 28, 2015 at 4:58 PM, Sebastian Huber
>             Hello,
>             the bsp_interrupt_dispatch() is quite complicated in the
>             beagle BSP. Is the
>             interrupt controller of this chip really that broken? Sane
>             interrupt
>             controllers block interrupts of equal or lower priority
>             relative to the
>             currently pending interrupt.
>     Sebastian Huber, embedded brains GmbH
>     Address : Dornierstr. 4, D-82178 Puchheim, Germany
>     Phone   : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
>     Fax     : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
>     E-Mail  : sebastian.huber at embedded-brains.de
>     PGP     : Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
