[PATCH 3/4] sparc: Remove superfluous FP enable
Fri May 29 13:54:29 UTC 2015
The FP context save/restore makes only sense in the context of FP
threads.
Update #2270.
 cpukit/score/cpu/sparc/cpu.c     |  5 +++++
 cpukit/score/cpu/sparc/cpu_asm.S | 24 ++----------------------
 2 files changed, 7 insertions(+), 22 deletions(-)
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index ee64b1e..bab0040 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -133,6 +133,11 @@ void _CPU_Initialize(void)
 #if (SPARC_HAS_FPU == 1)
   Context_Control_fp *pointer;
+  uint32_t            psr;
+  sparc_get_psr( psr );
+  psr |= SPARC_PSR_EF_MASK;
+  sparc_set_psr( psr );
    *  This seems to be the most appropriate way to obtain an initial
diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
index ddb2a13..3fa0532 100644
--- a/cpukit/score/cpu/sparc/cpu_asm.S
+++ b/cpukit/score/cpu/sparc/cpu_asm.S
@@ -44,17 +44,7 @@
         .align 4
         PUBLIC(_CPU_Context_save_fp)
 SYM(_CPU_Context_save_fp):
-         *  The following enables the floating point unit.
-        mov     %psr, %o1
-        sethi   %hi(SPARC_PSR_EF_MASK), %o2
-        or      %o2, %lo(SPARC_PSR_EF_MASK), %o2
-        or      %o1, %o2, %o1
-        mov     %o1, %psr                  ! **** ENABLE FLOAT ACCESS ****
-	nop; nop; nop;			   ! Need three nops before EF is
-        ld      [%o0], %o1		   ! active due to pipeline delay!!!
+        ld      [%o0], %o1
         std     %f0, [%o1 + FO_F1_OFFSET]
         std     %f2, [%o1 + F2_F3_OFFSET]
         std     %f4, [%o1 + F4_F5_OFFSET]
@@ -90,17 +80,7 @@ SYM(_CPU_Context_save_fp):
         .align 4
         PUBLIC(_CPU_Context_restore_fp)
 SYM(_CPU_Context_restore_fp):
-        mov     %psr, %o1
-        or      %o1, %o2, %o1
+        ld      [%o0], %o1
         ldd     [%o1 + FO_F1_OFFSET], %f0
         ldd     [%o1 + F2_F3_OFFSET], %f2
         ldd     [%o1 + F4_F5_OFFSET], %f4
1.8.4.5
