[PATCH 2/4] sparc: Avoid new window for FP save/restore
Gedare Bloom gedare at gwu.edu
Fri May 29 14:07:14 UTC 2015
Straightforward leaf-optimization, except is there a reason to use jmp
%o7 + 8 instead of ret?
On Fri, May 29, 2015 at 8:54 AM, Sebastian Huber
> Update #2270.
>  cpukit/score/cpu/sparc/cpu_asm.S | 102 ++++++++++++++++++---------------------
>  1 file changed, 48 insertions(+), 54 deletions(-)
> diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
> index 92674de..ddb2a13 100644
> --- a/cpukit/score/cpu/sparc/cpu_asm.S
> +++ b/cpukit/score/cpu/sparc/cpu_asm.S
> @@ -44,38 +44,35 @@
>          .align 4
>          PUBLIC(_CPU_Context_save_fp)
>  SYM(_CPU_Context_save_fp):
> -        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
>           *  The following enables the floating point unit.
> -        mov     %psr, %l0
> -        sethi   %hi(SPARC_PSR_EF_MASK), %l1
> -        or      %l1, %lo(SPARC_PSR_EF_MASK), %l1
> -        or      %l0, %l1, %l0
> -        mov     %l0, %psr                  ! **** ENABLE FLOAT ACCESS ****
> +        mov     %psr, %o1
> +        sethi   %hi(SPARC_PSR_EF_MASK), %o2
> +        or      %o2, %lo(SPARC_PSR_EF_MASK), %o2
> +        or      %o1, %o2, %o1
> +        mov     %o1, %psr                  ! **** ENABLE FLOAT ACCESS ****
>         nop; nop; nop;                     ! Need three nops before EF is
> -        ld      [%i0], %l0                ! active due to pipeline delay!!!
> -        std     %f0, [%l0 + FO_F1_OFFSET]
> -        std     %f2, [%l0 + F2_F3_OFFSET]
> -        std     %f4, [%l0 + F4_F5_OFFSET]
> -        std     %f6, [%l0 + F6_F7_OFFSET]
> -        std     %f8, [%l0 + F8_F9_OFFSET]
> -        std     %f10, [%l0 + F1O_F11_OFFSET]
> -        std     %f12, [%l0 + F12_F13_OFFSET]
> -        std     %f14, [%l0 + F14_F15_OFFSET]
> -        std     %f16, [%l0 + F16_F17_OFFSET]
> -        std     %f18, [%l0 + F18_F19_OFFSET]
> -        std     %f20, [%l0 + F2O_F21_OFFSET]
> -        std     %f22, [%l0 + F22_F23_OFFSET]
> -        std     %f24, [%l0 + F24_F25_OFFSET]
> -        std     %f26, [%l0 + F26_F27_OFFSET]
> -        std     %f28, [%l0 + F28_F29_OFFSET]
> -        std     %f30, [%l0 + F3O_F31_OFFSET]
> -        st      %fsr, [%l0 + FSR_OFFSET]
> -        ret
> -        restore
> +        ld      [%o0], %o1                ! active due to pipeline delay!!!
> +        std     %f0, [%o1 + FO_F1_OFFSET]
> +        std     %f2, [%o1 + F2_F3_OFFSET]
> +        std     %f4, [%o1 + F4_F5_OFFSET]
> +        std     %f6, [%o1 + F6_F7_OFFSET]
> +        std     %f8, [%o1 + F8_F9_OFFSET]
> +        std     %f10, [%o1 + F1O_F11_OFFSET]
> +        std     %f12, [%o1 + F12_F13_OFFSET]
> +        std     %f14, [%o1 + F14_F15_OFFSET]
> +        std     %f16, [%o1 + F16_F17_OFFSET]
> +        std     %f18, [%o1 + F18_F19_OFFSET]
> +        std     %f20, [%o1 + F2O_F21_OFFSET]
> +        std     %f22, [%o1 + F22_F23_OFFSET]
> +        std     %f24, [%o1 + F24_F25_OFFSET]
> +        std     %f26, [%o1 + F26_F27_OFFSET]
> +        std     %f28, [%o1 + F28_F29_OFFSET]
> +        std     %f30, [%o1 + F3O_F31_OFFSET]
> +        jmp     %o7 + 8
> +         st     %fsr, [%o1 + FSR_OFFSET]
>   *  void _CPU_Context_restore_fp(
> @@ -93,38 +90,35 @@ SYM(_CPU_Context_save_fp):
>          .align 4
>          PUBLIC(_CPU_Context_restore_fp)
>  SYM(_CPU_Context_restore_fp):
> -        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE , %sp
> -        mov     %psr, %l0
> -        or      %l0, %l1, %l0
> +        mov     %psr, %o1
> +        or      %o1, %o2, %o1
> -        ldd     [%l0 + FO_F1_OFFSET], %f0
> -        ldd     [%l0 + F2_F3_OFFSET], %f2
> -        ldd     [%l0 + F4_F5_OFFSET], %f4
> -        ldd     [%l0 + F6_F7_OFFSET], %f6
> -        ldd     [%l0 + F8_F9_OFFSET], %f8
> -        ldd     [%l0 + F1O_F11_OFFSET], %f10
> -        ldd     [%l0 + F12_F13_OFFSET], %f12
> -        ldd     [%l0 + F14_F15_OFFSET], %f14
> -        ldd     [%l0 + F16_F17_OFFSET], %f16
> -        ldd     [%l0 + F18_F19_OFFSET], %f18
> -        ldd     [%l0 + F2O_F21_OFFSET], %f20
> -        ldd     [%l0 + F22_F23_OFFSET], %f22
> -        ldd     [%l0 + F24_F25_OFFSET], %f24
> -        ldd     [%l0 + F26_F27_OFFSET], %f26
> -        ldd     [%l0 + F28_F29_OFFSET], %f28
> -        ldd     [%l0 + F3O_F31_OFFSET], %f30
> -        ld      [%l0 + FSR_OFFSET], %fsr
> -        ret
> -        restore
> +        ldd     [%o1 + FO_F1_OFFSET], %f0
> +        ldd     [%o1 + F2_F3_OFFSET], %f2
> +        ldd     [%o1 + F4_F5_OFFSET], %f4
> +        ldd     [%o1 + F6_F7_OFFSET], %f6
> +        ldd     [%o1 + F8_F9_OFFSET], %f8
> +        ldd     [%o1 + F1O_F11_OFFSET], %f10
> +        ldd     [%o1 + F12_F13_OFFSET], %f12
> +        ldd     [%o1 + F14_F15_OFFSET], %f14
> +        ldd     [%o1 + F16_F17_OFFSET], %f16
> +        ldd     [%o1 + F18_F19_OFFSET], %f18
> +        ldd     [%o1 + F2O_F21_OFFSET], %f20
> +        ldd     [%o1 + F22_F23_OFFSET], %f22
> +        ldd     [%o1 + F24_F25_OFFSET], %f24
> +        ldd     [%o1 + F26_F27_OFFSET], %f26
> +        ldd     [%o1 + F28_F29_OFFSET], %f28
> +        ldd     [%o1 + F3O_F31_OFFSET], %f30
> +        jmp     %o7 + 8
> +         ld     [%o1 + FSR_OFFSET], %fsr
>  #endif /* SPARC_HAS_FPU */
> 1.8.4.5
> devel mailing list
> devel at rtems.org
