[PATCH 4/4] sparc: Optimize non-deferred FP save/restore
Gedare Bloom gedare at gwu.edu
Fri May 29 14:22:57 UTC 2015
On Fri, May 29, 2015 at 8:54 AM, Sebastian Huber
> Update #2270.
>  cpukit/score/cpu/sparc/cpu.c             | 16 ++++++++++++
>  cpukit/score/cpu/sparc/cpu_asm.S         | 44 ++++++++++++++++++++++++++++++++
>  cpukit/score/cpu/sparc/rtems/score/cpu.h | 22 ++++++++++++++--
>  3 files changed, 80 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
> index bab0040..b2f67c4 100644
> --- a/cpukit/score/cpu/sparc/cpu.c
> +++ b/cpukit/score/cpu/sparc/cpu.c
> @@ -134,6 +134,10 @@ void _CPU_Initialize(void)
>  #if (SPARC_HAS_FPU == 1)
>    Context_Control_fp *pointer;
>    uint32_t            psr;
> +#if CPU_USE_DEFERRED_FP_SWITCH == FALSE
> +  Per_CPU_Control    *cpu_self;
> +  uint32_t            isr_dispatch_disable;
> +#endif
>    sparc_get_psr( psr );
>    psr |= SPARC_PSR_EF_MASK;
> @@ -146,7 +150,19 @@ void _CPU_Initialize(void)
>    pointer = &_CPU_Null_fp_context;
> +  cpu_self = _Per_CPU_Get();
> +  isr_dispatch_disable = cpu_self->cpu_per_cpu.isr_dispatch_disable;
> +  cpu_self->cpu_per_cpu.isr_dispatch_disable = 1;
> +  pointer->is_valid = 1;
> +#endif
>    _CPU_Context_save_fp( &pointer );
> +  cpu_self->cpu_per_cpu.isr_dispatch_disable = isr_dispatch_disable;
> +#endif
>  #endif
> diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
> index 3fa0532..fd63f19 100644
> --- a/cpukit/score/cpu/sparc/cpu_asm.S
> +++ b/cpukit/score/cpu/sparc/cpu_asm.S
> @@ -44,7 +44,26 @@
>          .align 4
>          PUBLIC(_CPU_Context_save_fp)
>  SYM(_CPU_Context_save_fp):
> +#if CPU_USE_DEFERRED_FP_SWITCH == TRUE
>          ld      [%o0], %o1
> +#else
> +         * On SMP configurations we cannot use the deferred floating point
> +         * switch.  Save the FP context only in case we have an interrupted
> +         * thread (indicated by a non-zero per-CPU ISR dispatch disable flag).
> +         * This works since the complete floating point context is volatile on
> +         * SPARC.
> +        ld      [%g6 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o2
> +        cmp     %o2, 0
> +        bne     do_save_fp
> +         ld     [%o0], %o1
> +        jmp    %o7 + 8
> +         nop
> +do_save_fp:
> +#endif
>          std     %f0, [%o1 + FO_F1_OFFSET]
>          std     %f2, [%o1 + F2_F3_OFFSET]
>          std     %f4, [%o1 + F4_F5_OFFSET]
> @@ -61,6 +80,15 @@ SYM(_CPU_Context_save_fp):
>          std     %f26, [%o1 + F26_F27_OFFSET]
>          std     %f28, [%o1 + F28_F29_OFFSET]
>          std     %f30, [%o1 + F3O_F31_OFFSET]
> +         * Set the is valid flag of the floating point context to true.  It is
> +         * store here to store the fields in sequence.
> +        st      %o2, [%o1 + SPARC_FP_CONTEXT_IS_VALID_OFFSET]
> +#endif
>          jmp     %o7 + 8
>           st     %fsr, [%o1 + FSR_OFFSET]
> @@ -81,6 +109,22 @@ SYM(_CPU_Context_save_fp):
>          PUBLIC(_CPU_Context_restore_fp)
>  SYM(_CPU_Context_restore_fp):
>          ld      [%o0], %o1
> +         * Check if we have a valid floating point context.  Clear the is valid
> +         * flag.  Restore the floating point context if necessary.
> +        ld      [%o1 + SPARC_FP_CONTEXT_IS_VALID_OFFSET], %o2
> +        cmp     %o2, 0
> +        bne     do_restore_fp
> +         st     %g0, [%o1 + SPARC_FP_CONTEXT_IS_VALID_OFFSET]
> +        jmp     %o7 + 8
> +         nop
> +do_restore_fp:
> +#endif
>          ldd     [%o1 + FO_F1_OFFSET], %f0
>          ldd     [%o1 + F2_F3_OFFSET], %f2
>          ldd     [%o1 + F4_F5_OFFSET], %f4
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index 02891b0..e51a4ab 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -609,6 +609,10 @@ typedef struct {
>    double      f28_f29;
>    /** This will contain the contents of the f30 and f31 register. */
>    double      f30_f31;
> +  /** Indicates if the context is valid. */
> +  uint32_t    is_valid;
Is it the case that is_valid is only true during a context switch
while interrupt handling (dispatch disabled)? I'd appreciate a bit
more clarity in this comment. Is there a need to put is_valid before
fsr? if the #if controlled field goes to the end of the block, then
that can simplify the below offset calculations.
> +#endif
>    /** This will contain the contents of the floating point status register. */
>    uint32_t    fsr;
>  } Context_Control_fp;
> @@ -651,11 +655,25 @@ typedef struct {
>  #define F28_F29_OFFSET   0x70
>  /** This macro defines an offset into the FPU context for use in assembly. */
>  #define F3O_F31_OFFSET   0x78
> +  /** This macro defines an offset into the FPU context for use in assembly. */
> +  #define SPARC_FP_CONTEXT_IS_VALID_OFFSET 0x80
> +#endif
> -#define FSR_OFFSET       0x80
> +  #define FSR_OFFSET 0x80
> +#else
> +  #define FSR_OFFSET 0x84
> +#endif
>  /** This defines the size of the FPU context area for use in assembly. */
> -#define CONTEXT_CONTROL_FP_SIZE 0x84
> +  #define CONTEXT_CONTROL_FP_SIZE 0x84
> +#else
> +  #define CONTEXT_CONTROL_FP_SIZE 0x88
> +#endif
I'd prefer to always have the #if check the same direction, i.e.
always check if it is FALSE.
>  #ifndef ASM
> 1.8.4.5
> devel mailing list
> devel at rtems.org
