[PATCH 2/4] sparc: Avoid new window for FP save/restore
Gedare Bloom gedare at gwu.edu
Fri May 29 16:37:13 UTC 2015
On Fri, May 29, 2015 at 10:46 AM, Sebastian Huber
> ----- Gedare Bloom <gedare at gwu.edu> schrieb:
>> Straightforward leaf-optimization, except is there a reason to use jmp
>> %o7 + 8 instead of ret?
> Hm, the GCC generates this instruction, is this the same as "ret"?
Yes I think so. Probably the manual will list ret as a synthetic
instruction, which is usually better for readability.
> devel mailing list
> devel at rtems.org
