[PATCH 2/4] sparc: Avoid new window for FP save/restore
Gedare Bloom gedare at gwu.edu
Fri May 29 16:38:10 UTC 2015
On Fri, May 29, 2015 at 11:37 AM, Gedare Bloom <gedare at gwu.edu> wrote:
> On Fri, May 29, 2015 at 10:46 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> ----- Gedare Bloom <gedare at gwu.edu> schrieb:
>>> Straightforward leaf-optimization, except is there a reason to use jmp
>>> %o7 + 8 instead of ret?
>> Hm, the GCC generates this instruction, is this the same as "ret"?
> Yes I think so. Probably the manual will list ret as a synthetic
> instruction, which is usually better for readability.
Also, I think sparc has retl instruction for returning from a
leaf-optimized function, which I think will not have the delay slot.
Should check the sparc manual though...
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
