[PATCH] tmtests/tm26: Fix context switch to FP task
Sebastian Huber
Fri May 29 19:32:08 UTC 2015
It is wrong to restore the floating point context here. The
_Context_Switch() ends up in _Thread_Handler() which will call
_Thread_Restore_fp(). In _Thread_Do_dispatch() the FP restore is after
the context switch.
testsuites/tmtests/tm26/task1.c | 3 ---
1 file changed, 3 deletions(-)
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index 6cec7da..ee66218 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -439,9 +439,6 @@ rtems_task Low_task(
thread_disable_dispatch();
benchmark_timer_initialize();
-#if (CPU_HARDWARE_FP == 1) || (CPU_SOFTWARE_FP == 1)
- _Context_Restore_fp( &_Thread_Get_executing()->fp_context );
-#endif
_Context_Switch(
&executing->Registers,
&_Thread_Get_executing()->Registers
2.1.4
