Build of rtems-libbsd for all BSPs
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Thu May 28 15:40:14 UTC 2015
On 5/28/2015 10:30 AM, Sujay Raj wrote:
> On i386/pc386, adding a line :
> extern u_int64_t tsc_freq;
> to freebsd/sys/contrib/altq/altq/altq_subr.c
> gets it to build successfully. Though I wonder what its repercussions would be.
Does the variable have a value? I looked at it enough to think
that pc386/clock appeared to need to set it.
Alternatively, we could disable the x86 specific timebase
code and use the same as other targets. I kind of lean to
that if it is possible.
> On Thu, May 28, 2015 at 8:43 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> I decided to attempt to build rtems-libbsd for all BSPs. I didn't
>> expect great results but 136 of 193 BSPs did not complete the build.
>> Overall, the results are surprising. No x86 or SPARC BSPs could
>> build rtems-libbsd. And many ARM and PowerPC BSPs had build issues
>> that were *NOT* running out of memory linking.
>> Apparently, a target has to have C++ and dlfcn.h or it is not attempted.
>> Some general failure patterns:
>> + SPARC pci header
>> + Missing bsp/irq-info.h
>> + Missing libcpu/cache.h
>> + Missing rtems_interrupt_server_initialize()
>> + ohci_lpc.c:221:18: error: 'EIO' undeclared
>> + x86 tsc_freq variable missing
>> + powerpc: Unsupported CPU model
>> The full report is attached.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
