[PATCH] sapi: Add rtems_chain_get_first_unprotected()
Sebastian Huber
Tue Nov 3 10:11:11 UTC 2015
cpukit/sapi/include/rtems/chain.h | 10 ++++++++++
doc/user/chains.t | 33 +++++++++++++++++++++++++++++++++
testsuites/sptests/spchain/init.c | 7 +++++++
3 files changed, 50 insertions(+)
diff --git a/cpukit/sapi/include/rtems/chain.h b/cpukit/sapi/include/rtems/chain.h
index 8da355d..4d586ff 100644
--- a/cpukit/sapi/include/rtems/chain.h
+++ b/cpukit/sapi/include/rtems/chain.h
@@ -624,6 +624,16 @@ RTEMS_INLINE_ROUTINE rtems_chain_node *rtems_chain_get_unprotected(
+ * @brief See _Chain_Get_first_unprotected().
+RTEMS_INLINE_ROUTINE rtems_chain_node *rtems_chain_get_first_unprotected(
+ rtems_chain_control *the_chain
+ return _Chain_Get_first_unprotected( the_chain );
* @brief Insert a node on a chain
* This routine inserts @a the_node on a chain immediately following
diff --git a/doc/user/chains.t b/doc/user/chains.t
index e5dffc2..79e5984 100644
--- a/doc/user/chains.t
+++ b/doc/user/chains.t
@@ -35,6 +35,7 @@ provided by RTEMS is:
@item @code{@value{DIRPREFIX}chain_extract_unprotected} - Extract the node from the chain (unprotected)
@item @code{@value{DIRPREFIX}chain_get} - Return the first node on the chain
@item @code{@value{DIRPREFIX}chain_get_unprotected} - Return the first node on the chain (unprotected)
+ at item @code{@value{DIRPREFIX}chain_get_first_unprotected} - Get the first node on the chain (unprotected)
@item @code{@value{DIRPREFIX}chain_insert} - Insert the node into the chain
@item @code{@value{DIRPREFIX}chain_insert_unprotected} - Insert the node into the chain (unprotected)
@item @code{@value{DIRPREFIX}chain_append} - Append the node to chain
@@ -661,6 +662,38 @@ interrupts.
@c
@c
@page
+ at subsection Get the First Node (unprotected)
+ at cindex chain get first node
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at findex @value{DIRPREFIX}chain_get_first_unprotected
+ at example
+ at value{DIRPREFIX}chain_node *@value{DIRPREFIX}chain_get_first_unprotected(
+ @value{DIRPREFIX}chain_control *the_chain
+ at end example
+ at end ifset
+ at subheading RETURNS:
+A pointer to the former first node is returned.
+ at subheading DESCRIPTION:
+Removes the first node from the chain and returns a pointer to it. In case the
+chain was empty, then the results are unpredictable.
+ at subheading NOTES:
+The function does nothing to ensure the atomicity of the operation.
+ at c
+ at c
+ at c
+ at page
@subsection Insert a Node
@cindex chain insert a node
diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
index ca2e135..476629b 100644
--- a/testsuites/sptests/spchain/init.c
+++ b/testsuites/sptests/spchain/init.c
@@ -117,6 +117,13 @@ static void test_chain_first_and_last(void)
puts( "INIT - Verify rtems_chain_is_last" );
cnode = rtems_chain_last(&chain);
rtems_test_assert( rtems_chain_is_last( cnode ) );
+ cnode = rtems_chain_get_first_unprotected( &chain );
+ rtems_test_assert( cnode == &node1 );
+ cnode = rtems_chain_first( &chain );
+ rtems_test_assert( cnode == &node2 );
+ cnode = rtems_chain_last( &chain );
static void test_chain_with_notification(void)
1.8.4.5
