[PATCH] Fix declaration of pthread-structs in s-osinte-rtems.ads
Jan Sommer soja-lists at aries.uberspace.de
Tue Nov 3 17:41:10 UTC 2015
Am Tuesday 03 November 2015, 18:10:53 schrieb Arnaud Charlet:
> > Let's try again. This time I made the diff against trunk with the changes
> > Sebastian recommended, included a ChangeLog and used svn-diff.
> > If this patch goes through, please let me know how the backporting works.
> Your ChangeLog entry is not in the proper format, see sections 6.8.1 and
> 6.8.2 from http://www.gnu.org/prep/standards/standards.html
> The diff itself is OK.
Ok, fixed this. See the new diff below.
> You can use svn merge to merge changes on other branches, or try to
> apply your diff using the "patch" command, and adjust for any merge
> conflict.
Will do. Do I send a patch for each branch to the list or do I add these changes to this patch?
Best regards,
   Jan
Index: gcc/ada/ChangeLog
--- gcc/ada/ChangeLog   (Revision 229715)
+++ gcc/ada/ChangeLog   (Arbeitskopie)
@@ -1,3 +1,8 @@
+2015-11-03  Jan Sommer <soja-lists at aries.uberspace.de>
+       * s-oscons-tmplt.c: Generate pthread constants for RTEMS
+       * s-osinte-rtems.ads: Declare pthread structs as opaque types in Ada
 2015-10-29  Andrew MacLeod  <amacleod at redhat.com>
        * gcc-interface/decl.c: Reorder #include's and remove duplicates.
Index: gcc/ada/s-oscons-tmplt.c
--- gcc/ada/s-oscons-tmplt.c    (Revision 229715)
+++ gcc/ada/s-oscons-tmplt.c    (Arbeitskopie)
@@ -157,7 +157,7 @@ pragma Style_Checks ("M32766");
 # include <_types.h>
 #endif
-#if defined (__linux__) || defined (__ANDROID__)
+#if defined (__linux__) || defined (__ANDROID__) || defined (__rtems__)
 # include <pthread.h>
 # include <signal.h>
 #endif
@@ -1458,7 +1458,7 @@ CNS(CLOCK_RT_Ada, "")
 #endif
 #if defined (__APPLE__) || defined (__linux__) || defined (__ANDROID__) \
-  || defined (DUMMY)
+  || defined (__rtems__) || defined (DUMMY)
    --  Sizes of pthread data types
@@ -1501,7 +1501,7 @@ CND(PTHREAD_RWLOCKATTR_SIZE, "pthread_rwlockattr_t
 CND(PTHREAD_RWLOCK_SIZE,     "pthread_rwlock_t")
 CND(PTHREAD_ONCE_SIZE,       "pthread_once_t")
-#endif /* __APPLE__ || __linux__ || __ANDROID__ */
+#endif /* __APPLE__ || __linux__ || __ANDROID__ || __rtems__ */
Index: gcc/ada/s-osinte-rtems.ads
--- gcc/ada/s-osinte-rtems.ads  (Revision 229715)
+++ gcc/ada/s-osinte-rtems.ads  (Arbeitskopie)
@@ -51,6 +51,8 @@
 --  It is designed to be a bottom-level (leaf) package.
 with Interfaces.C;
+with System.OS_Constants;
 package System.OS_Interface is
    pragma Preelaborate;
@@ -60,6 +62,7 @@ package System.OS_Interface is
    subtype rtems_id       is Interfaces.C.unsigned;
    subtype int            is Interfaces.C.int;
+   subtype char           is Interfaces.C.char;
    subtype short          is Interfaces.C.short;
    subtype long           is Interfaces.C.long;
    subtype unsigned       is Interfaces.C.unsigned;
@@ -68,7 +71,6 @@ package System.OS_Interface is
    subtype unsigned_char  is Interfaces.C.unsigned_char;
    subtype plain_char     is Interfaces.C.plain_char;
    subtype size_t         is Interfaces.C.size_t;
    -- Errno --
@@ -76,11 +78,11 @@ package System.OS_Interface is
    function errno return int;
    pragma Import (C, errno, "__get_errno");
-   EAGAIN    : constant := 11;
-   EINTR     : constant := 4;
-   EINVAL    : constant := 22;
-   ENOMEM    : constant := 12;
-   ETIMEDOUT : constant := 116;
+   EAGAIN    : constant := System.OS_Constants.EAGAIN;
+   EINTR     : constant := System.OS_Constants.EINTR;
+   EINVAL    : constant := System.OS_Constants.EINVAL;
+   ENOMEM    : constant := System.OS_Constants.ENOMEM;
+   ETIMEDOUT : constant := System.OS_Constants.ETIMEDOUT;
    -- Signals --
@@ -448,6 +450,7 @@ package System.OS_Interface is
       ss_low_priority     : int;
       ss_replenish_period : timespec;
       ss_initial_budget   : timespec;
+      sched_ss_max_repl   : int;
    end record;
    pragma Convention (C, struct_sched_param);
@@ -621,43 +624,34 @@ private
    end record;
    pragma Convention (C, timespec);
-   CLOCK_REALTIME :  constant clockid_t := 1;
-   CLOCK_MONOTONIC : constant clockid_t := 4;
+   CLOCK_REALTIME :  constant clockid_t := System.OS_Constants.CLOCK_REALTIME;
+   CLOCK_MONOTONIC : constant clockid_t := System.OS_Constants.CLOCK_MONOTONIC;
+   subtype char_array is Interfaces.C.char_array;
    type pthread_attr_t is record
-      is_initialized  : int;
-      stackaddr       : System.Address;
-      stacksize       : int;
-      contentionscope : int;
-      inheritsched    : int;
-      schedpolicy     : int;
-      schedparam      : struct_sched_param;
-      cputime_clocked_allowed : int;
-      detatchstate    : int;
+      Data : char_array (1 .. OS_Constants.PTHREAD_ATTR_SIZE);
    end record;
    pragma Convention (C, pthread_attr_t);
+   for pthread_attr_t'Alignment use Interfaces.C.double'Alignment;
    type pthread_condattr_t is record
-      flags           : int;
-      process_shared  : int;
+      Data : char_array (1 .. OS_Constants.PTHREAD_CONDATTR_SIZE);
    end record;
    pragma Convention (C, pthread_condattr_t);
+   for pthread_condattr_t'Alignment use Interfaces.C.double'Alignment;
    type pthread_mutexattr_t is record
-      prio_ceiling    : int;
-      protocol        : int;
-      mutex_type      : int;
-      recursive       : int;
-   end record;
+      Data : char_array (1 .. OS_Constants.PTHREAD_MUTEXATTR_SIZE);
+   end  record;
    pragma Convention (C, pthread_mutexattr_t);
+   for pthread_mutexattr_t'Alignment use Interfaces.C.double'Alignment;
    type pthread_rwlockattr_t is record
+      Data : char_array (1 .. OS_Constants.PTHREAD_RWLOCKATTR_SIZE);
    end record;
    pragma Convention (C, pthread_rwlockattr_t);
+   for pthread_rwlockattr_t'Alignment use Interfaces.C.double'Alignment;
    type pthread_t is new rtems_id;
