Trouble building RTEMS from master
Wed Nov 4 21:57:10 UTC 2015
Did you bootstrap -c and then bootstrap? I think I saw this error
earlier today too, with a new sparc toolchain, but then it went away
after i rm-rf'd my build tree and tried over.
On Wed, Nov 4, 2015 at 4:39 PM, Martin Galvan
<martin.galvan at tallertechnologies.com> wrote:
> Hi everyone! I'm currently having some trouble when building RTEMS
> from the git mainline. I'm using a toolchain built using (a fairly
> recent) RSB. My configure is:
> ../source/configure --target=arm-rtems4.11
> --enable-rtemsbsp=beagleboneblack --enable-posix --enable-cxx
> --disable-networking --enable-tests=no
> However, when I run make, I get this:
> make[1]: *** No rule to make target `make/Templates/Makefile.lib',
> needed by `all-am'.  Stop.
> I tried re-bootstraping and still see the same error. I saw this on a
> couple more BSPs (TMS570 and LPC1768).
> Notice this happens only with master; the 4.11 branch builds ok.
> Is this a bug, or am I doing something wrong?
> devel mailing list
> devel at rtems.org
