[PATCH] LPC1768: Fix compilation error
Martin Galvan
martin.galvan at tallertechnologies.com
Thu Nov 5 14:17:23 UTC 2015
The LPC1768 variants have a gpio.h file whose name clashes with the gpio.h from
the new GPIO API. This results on the BSPs failing to compile.
This patch renames the LPC1768 gpio.* files to lpc-gpio.*, as it's done on other
BSPs (e.g. Beaglebone).
Closes #2441.
c/src/lib/libbsp/arm/lpc176x/Makefile.am | 4 +-
c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c | 392 ------------------------
c/src/lib/libbsp/arm/lpc176x/gpio/lpc-gpio.c | 392 ++++++++++++++++++++++++
c/src/lib/libbsp/arm/lpc176x/include/gpio.h | 100 ------
c/src/lib/libbsp/arm/lpc176x/include/lpc-gpio.h | 100 ++++++
c/src/lib/libbsp/arm/lpc176x/preinstall.am | 6 +-
6 files changed, 497 insertions(+), 497 deletions(-)
delete mode 100644 c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c
create mode 100644 c/src/lib/libbsp/arm/lpc176x/gpio/lpc-gpio.c
delete mode 100644 c/src/lib/libbsp/arm/lpc176x/include/gpio.h
create mode 100644 c/src/lib/libbsp/arm/lpc176x/include/lpc-gpio.h
diff --git a/c/src/lib/libbsp/arm/lpc176x/Makefile.am b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
index 50a7e79..352b2d9 100644
--- a/c/src/lib/libbsp/arm/lpc176x/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
@@ -41,7 +41,7 @@ include_bsp_HEADERS += include/io-defs.h
include_bsp_HEADERS += include/io.h
include_bsp_HEADERS += include/common-types.h
include_bsp_HEADERS += include/gpio-defs.h
-include_bsp_HEADERS += include/gpio.h
+include_bsp_HEADERS += include/lpc-gpio.h
include_bsp_HEADERS += include/can.h
include_bsp_HEADERS += include/can-defs.h
include_bsp_HEADERS += include/pwmout.h
@@ -131,7 +131,7 @@ libbsp_a_SOURCES += ../../shared/tod.c \
rtc/rtc-config.c
# GPIO
-libbsp_a_SOURCES += gpio/gpio.c
+libbsp_a_SOURCES += gpio/lpc-gpio.c
# CAN
libbsp_a_SOURCES += can/can.c
diff --git a/c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c b/c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c
deleted file mode 100644
index e77e07b..0000000
--- a/c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c
+++ /dev/null
@@ -1,392 +0,0 @@
- * @file gpio.c
- * @ingroup lpc176x
- * @brief GPIO library for the lpc176x bsp.
- * Copyright (c) 2014 Taller Technologies.
- * @author Boretto Martin (martin.boretto at tallertechnologies.com)
- * @author Diaz Marcos (marcos.diaz at tallertechnologies.com)
- * @author Lenarduzzi Federico (federico.lenarduzzi at tallertechnologies.com)
- * @author Daniel Chicco (daniel.chicco at tallertechnologies.com)
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <assert.h>
-#include <bsp/irq.h>
-#include <bsp/io.h>
-#include <bsp/gpio.h>
-#include <rtems/status-checks.h>
-static uint32_t function_vector_size = 0u;
-static lpc176x_registered_interrupt_function function_vector[
- LPC176X_RESERVED_ISR_FUNCT_SIZE ];
-static bool isr_installed = false;
-rtems_status_code lpc176x_gpio_config(
- const lpc176x_pin_number pin,
- const lpc176x_gpio_direction dir
- rtems_status_code status_code = RTEMS_INVALID_NUMBER;
- if ( ( pin < LPC176X_MAX_PORT_NUMBER ) &&
- ( dir < LPC176X_GPIO_FUNCTION_COUNT ) ) {
- const lpc176x_gpio_ports port = LPC176X_IO_PORT( pin );
- const uint32_t pin_of_port = LPC176X_IO_PORT_BIT( pin );
- lpc176x_pin_select( pin, LPC176X_PIN_FUNCTION_00 );
- LPC176X_SET_BIT( LPC176X_FIO[ port ].dir, pin_of_port, dir );
- status_code = RTEMS_SUCCESSFUL;
- /* else implies that the pin or the egde are out of range. Also,
- an invalid number is returned. */
- return status_code;
- * @brief Check for a rising edge and call the interrupt function.
- * @param statR Rising edge interrupt.
- * @param pin The pin to check.
- * @param registered_isr_function Interrupt to check.
- * @return TRUE if is a rising edge. FALSE otherwise.
-static bool lpc176x_check_rising_edge_and_call(
- const uint32_t statR,
- const lpc176x_registered_interrupt_function registered_isr_function,
- bool is_rising = false;
- if ( statR & LPC176X_PIN_BIT( pin ) ) {
- registered_isr_function.function( registered_isr_function.pin,
- LPC176X_GPIO_INTERRUPT_RISING );
- is_rising = true;
- /* else implies that the current interrupt is not STATR. Also,
- there is nothing to do. */
- return is_rising;
- * @brief Check for a falling edge and call the interrupt function.
- * @param statR Falling edge interrupt.
- * @return TRUE if is a falling edge. FALSE otherwise.
-static bool lpc176x_check_falling_edge_and_call(
- const uint32_t statF,
- bool is_falling = false;
- if ( statF & LPC176X_PIN_BIT( pin ) ) {
- LPC176X_GPIO_INTERRUPT_FALLING );
- is_falling = true;
- /* else implies that the current interrupt is not STATF. Also,
- return is_falling;
- * @brief Returns the interrupts base address according to the current port.
- * @param port Input/Output port.
- * @return Interrupt base address.
-static lpc176x_interrupt_control*lpc176x_get_interrupt_address(
- const lpc176x_gpio_ports port )
- lpc176x_interrupt_control *interrupt;
- switch ( port ) {
- case ( LPC176X_GPIO_PORT_0 ):
- interrupt = (lpc176x_interrupt_control *) LPC176X_IO0_INT_BASE_ADDRESS;
- break;
- case ( LPC176X_GPIO_PORT_2 ):
- interrupt = (lpc176x_interrupt_control *) LPC176X_IO2_INT_BASE_ADDRESS;
- break;
- case ( LPC176X_GPIO_PORT_1 ):
- case ( LPC176X_GPIO_PORT_3 ):
- case ( LPC176X_GPIO_PORT_4 ):
- default:
- interrupt = NULL;
- return interrupt;
- * @brief Checks the type of the current interrupt.
-static void check_for_interrupt(
- const lpc176x_registered_interrupt_function registered_isr_function )
- assert( registered_isr_function.pin < LPC176X_MAX_PORT_NUMBER );
- registered_isr_function.pin );
- const uint32_t pin = LPC176X_IO_PORT_BIT( registered_isr_function.pin );
- lpc176x_interrupt_control *interrupt = lpc176x_get_interrupt_address( port );
- assert( interrupt != NULL );
- bool is_rising_edge = lpc176x_check_rising_edge_and_call( interrupt->StatR,
- registered_isr_function,
- pin );
- bool is_falling_edge = lpc176x_check_falling_edge_and_call( interrupt->StatF,
- pin );
- if ( is_rising_edge || is_falling_edge ) {
- interrupt->Clr = LPC176X_PIN_BIT( pin );
- /* else implies that the current interrupt is not CLR. Also,
- * @brief Checks all interrupts types.
- * @param arg Interrupt to check.
-static inline void lpc176x_gpio_isr( void *arg )
- unsigned int i;
- for ( i = 0; i < function_vector_size; ++i ) {
- check_for_interrupt( function_vector[ i ] );
- * @brief Depending of the current edge sets rising/falling interrupt.
- * @param edge Current edge.
- * @param pin_of_port Pin of the port to set the interrupt.
- * @param interrupt To enable the falling o rising edge.
-static void lpc176x_set_falling_or_rising_interrupt(
- const lpc176x_gpio_interrupt edge,
- const uint32_t pin_of_port,
- if ( edge & LPC176X_GPIO_INTERRUPT_RISING ) {
- LPC176X_SET_BIT( interrupt->EnR, pin_of_port, LPC176X_INT_ENABLE );
- /* else implies that it should not install the interrupt for a RISING edge.
- Also, there is nothing to do. */
- if ( edge & LPC176X_GPIO_INTERRUPT_FALLING ) {
- LPC176X_SET_BIT( interrupt->EnF, pin_of_port, LPC176X_INT_ENABLE );
- /* else implies that it should not install the interrupt for a FALLING edge.
- * @brief Registers the pin and the callbacks functions.
- * @param pin The pin to configure.
- * @param isr_funct Callback function to set.
-static void lpc176x_register_pin_and_callback(
- const lpc176x_gpio_interrupt_function isr_funct
- if ( edge ) {
- assert( function_vector_size < LPC176X_RESERVED_ISR_FUNCT_SIZE );
- function_vector[ function_vector_size ].function = isr_funct;
- function_vector[ function_vector_size ].pin = pin;
- ++function_vector_size;
- /* else implies that the current interrupt is DISABLED or BOTH. Also,
- * @brief Installs the interrupt handler.
- * @param edge Which edge enable.
- * @return RTEMS_SUCCESSFUL if the installation was success.
-static rtems_status_code lpc176x_install_interrupt_handler(
- const lpc176x_gpio_interrupt edge )
- rtems_status_code status_code = RTEMS_SUCCESSFUL;
- if ( !isr_installed && edge ) {
- status_code = rtems_interrupt_handler_install( LPC176X_IRQ_EINT_3,
- "gpio_interrupt",
- RTEMS_INTERRUPT_UNIQUE,
- lpc176x_gpio_isr,
- NULL );
- isr_installed = true;
- /* else implies that the interrupts have been previously installed. Also,
- * @brief Configures the pin as input, enables interrupt for an
- * edge/s and sets isrfunct as the function to call when that
- * interrupt occurs.
- * @param edge Which edge or edges will activate the interrupt.
- * @param isrfunct The function that is called when the interrupt occurs.
- * @return RTEMS_SUCCESSFUL if the configuration was success.
-static rtems_status_code lpc176x_check_edge_and_set_gpio_interrupts(
- lpc176x_gpio_config( pin, LPC176X_GPIO_FUNCTION_INPUT );
- lpc176x_set_falling_or_rising_interrupt( edge, pin_of_port, interrupt );
- lpc176x_register_pin_and_callback( edge, pin, isr_funct );
- status_code = lpc176x_install_interrupt_handler( edge );
-rtems_status_code lpc176x_gpio_config_input_with_interrupt(
- && ( edge < LPC176X_GPIO_INTERRUPT_COUNT ) ) {
- status_code = lpc176x_check_edge_and_set_gpio_interrupts( pin,
- edge,
- isr_funct );
-rtems_status_code lpc176x_gpio_set_pin( const lpc176x_pin_number pin )
- if ( pin < LPC176X_MAX_PORT_NUMBER ) {
- LPC176X_FIO[ port ].set = LPC176X_PIN_BIT( pin_of_port );
-rtems_status_code lpc176x_gpio_clear_pin( const lpc176x_pin_number pin )
- LPC176X_FIO[ port ].clr = LPC176X_PIN_BIT( pin_of_port );
-rtems_status_code lpc176x_gpio_write_pin(
- const bool value
- rtems_status_code status_code;
- if ( value ) {
- status_code = lpc176x_gpio_set_pin( pin );
- } else {
- status_code = lpc176x_gpio_clear_pin( pin );
-inline rtems_status_code lpc176x_gpio_get_pin_value(
- bool *pin_value
- assert( pin < LPC176X_MAX_PORT_NUMBER );
- *pin_value = ( LPC176X_FIO[ port ].pin & LPC176X_PIN_BIT( pin_of_port ) );
diff --git a/c/src/lib/libbsp/arm/lpc176x/gpio/lpc-gpio.c b/c/src/lib/libbsp/arm/lpc176x/gpio/lpc-gpio.c
new file mode 100644
index 0000000..e7f07fe
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc176x/gpio/lpc-gpio.c
@@ -0,0 +1,392 @@
+ * @file lpc-gpio.c
+ * @ingroup lpc176x
+ * @brief GPIO library for the lpc176x bsp.
+ * Copyright (c) 2014 Taller Technologies.
+ * @author Boretto Martin (martin.boretto at tallertechnologies.com)
+ * @author Diaz Marcos (marcos.diaz at tallertechnologies.com)
+ * @author Lenarduzzi Federico (federico.lenarduzzi at tallertechnologies.com)
+ * @author Daniel Chicco (daniel.chicco at tallertechnologies.com)
+#include <assert.h>
+#include <bsp/irq.h>
+#include <bsp/io.h>
+#include <bsp/lpc-gpio.h>
+#include <rtems/status-checks.h>
+static uint32_t function_vector_size = 0u;
+static lpc176x_registered_interrupt_function function_vector[
+ LPC176X_RESERVED_ISR_FUNCT_SIZE ];
+static bool isr_installed = false;
+rtems_status_code lpc176x_gpio_config(
+ const lpc176x_pin_number pin,
+ const lpc176x_gpio_direction dir
+ rtems_status_code status_code = RTEMS_INVALID_NUMBER;
+ if ( ( pin < LPC176X_MAX_PORT_NUMBER ) &&
+ ( dir < LPC176X_GPIO_FUNCTION_COUNT ) ) {
+ const lpc176x_gpio_ports port = LPC176X_IO_PORT( pin );
+ const uint32_t pin_of_port = LPC176X_IO_PORT_BIT( pin );
+ lpc176x_pin_select( pin, LPC176X_PIN_FUNCTION_00 );
+ LPC176X_SET_BIT( LPC176X_FIO[ port ].dir, pin_of_port, dir );
+ status_code = RTEMS_SUCCESSFUL;
+ /* else implies that the pin or the egde are out of range. Also,
+ an invalid number is returned. */
+ return status_code;
+ * @brief Check for a rising edge and call the interrupt function.
+ * @param statR Rising edge interrupt.
+ * @param pin The pin to check.
+ * @param registered_isr_function Interrupt to check.
+ * @return TRUE if is a rising edge. FALSE otherwise.
+static bool lpc176x_check_rising_edge_and_call(
+ const uint32_t statR,
+ const lpc176x_registered_interrupt_function registered_isr_function,
+ bool is_rising = false;
+ if ( statR & LPC176X_PIN_BIT( pin ) ) {
+ registered_isr_function.function( registered_isr_function.pin,
+ LPC176X_GPIO_INTERRUPT_RISING );
+ is_rising = true;
+ /* else implies that the current interrupt is not STATR. Also,
+ there is nothing to do. */
+ return is_rising;
+ * @brief Check for a falling edge and call the interrupt function.
+ * @param statR Falling edge interrupt.
+ * @return TRUE if is a falling edge. FALSE otherwise.
+static bool lpc176x_check_falling_edge_and_call(
+ const uint32_t statF,
+ bool is_falling = false;
+ if ( statF & LPC176X_PIN_BIT( pin ) ) {
+ LPC176X_GPIO_INTERRUPT_FALLING );
+ is_falling = true;
+ /* else implies that the current interrupt is not STATF. Also,
+ return is_falling;
+ * @brief Returns the interrupts base address according to the current port.
+ * @param port Input/Output port.
+ * @return Interrupt base address.
+static lpc176x_interrupt_control*lpc176x_get_interrupt_address(
+ const lpc176x_gpio_ports port )
+ lpc176x_interrupt_control *interrupt;
+ switch ( port ) {
+ case ( LPC176X_GPIO_PORT_0 ):
+ interrupt = (lpc176x_interrupt_control *) LPC176X_IO0_INT_BASE_ADDRESS;
+ break;
+ case ( LPC176X_GPIO_PORT_2 ):
+ interrupt = (lpc176x_interrupt_control *) LPC176X_IO2_INT_BASE_ADDRESS;
+ break;
+ case ( LPC176X_GPIO_PORT_1 ):
+ case ( LPC176X_GPIO_PORT_3 ):
+ case ( LPC176X_GPIO_PORT_4 ):
+ default:
+ interrupt = NULL;
+ return interrupt;
+ * @brief Checks the type of the current interrupt.
+static void check_for_interrupt(
+ const lpc176x_registered_interrupt_function registered_isr_function )
+ assert( registered_isr_function.pin < LPC176X_MAX_PORT_NUMBER );
+ registered_isr_function.pin );
+ const uint32_t pin = LPC176X_IO_PORT_BIT( registered_isr_function.pin );
+ lpc176x_interrupt_control *interrupt = lpc176x_get_interrupt_address( port );
+ assert( interrupt != NULL );
+ bool is_rising_edge = lpc176x_check_rising_edge_and_call( interrupt->StatR,
+ registered_isr_function,
+ pin );
+ bool is_falling_edge = lpc176x_check_falling_edge_and_call( interrupt->StatF,
+ pin );
+ if ( is_rising_edge || is_falling_edge ) {
+ interrupt->Clr = LPC176X_PIN_BIT( pin );
+ /* else implies that the current interrupt is not CLR. Also,
+ * @brief Checks all interrupts types.
+ * @param arg Interrupt to check.
+static inline void lpc176x_gpio_isr( void *arg )
+ unsigned int i;
+ for ( i = 0; i < function_vector_size; ++i ) {
+ check_for_interrupt( function_vector[ i ] );
+ * @brief Depending of the current edge sets rising/falling interrupt.
+ * @param edge Current edge.
+ * @param pin_of_port Pin of the port to set the interrupt.
+ * @param interrupt To enable the falling o rising edge.
+static void lpc176x_set_falling_or_rising_interrupt(
+ const lpc176x_gpio_interrupt edge,
+ const uint32_t pin_of_port,
+ if ( edge & LPC176X_GPIO_INTERRUPT_RISING ) {
+ LPC176X_SET_BIT( interrupt->EnR, pin_of_port, LPC176X_INT_ENABLE );
+ /* else implies that it should not install the interrupt for a RISING edge.
+ Also, there is nothing to do. */
+ if ( edge & LPC176X_GPIO_INTERRUPT_FALLING ) {
+ LPC176X_SET_BIT( interrupt->EnF, pin_of_port, LPC176X_INT_ENABLE );
+ /* else implies that it should not install the interrupt for a FALLING edge.
+ * @brief Registers the pin and the callbacks functions.
+ * @param pin The pin to configure.
+ * @param isr_funct Callback function to set.
+static void lpc176x_register_pin_and_callback(
+ const lpc176x_gpio_interrupt_function isr_funct
+ if ( edge ) {
+ assert( function_vector_size < LPC176X_RESERVED_ISR_FUNCT_SIZE );
+ function_vector[ function_vector_size ].function = isr_funct;
+ function_vector[ function_vector_size ].pin = pin;
+ ++function_vector_size;
+ /* else implies that the current interrupt is DISABLED or BOTH. Also,
+ * @brief Installs the interrupt handler.
+ * @param edge Which edge enable.
+ * @return RTEMS_SUCCESSFUL if the installation was success.
+static rtems_status_code lpc176x_install_interrupt_handler(
+ const lpc176x_gpio_interrupt edge )
+ rtems_status_code status_code = RTEMS_SUCCESSFUL;
+ if ( !isr_installed && edge ) {
+ status_code = rtems_interrupt_handler_install( LPC176X_IRQ_EINT_3,
+ "gpio_interrupt",
+ RTEMS_INTERRUPT_UNIQUE,
+ lpc176x_gpio_isr,
+ NULL );
+ isr_installed = true;
+ /* else implies that the interrupts have been previously installed. Also,
+ * @brief Configures the pin as input, enables interrupt for an
+ * edge/s and sets isrfunct as the function to call when that
+ * interrupt occurs.
+ * @param edge Which edge or edges will activate the interrupt.
+ * @param isrfunct The function that is called when the interrupt occurs.
+ * @return RTEMS_SUCCESSFUL if the configuration was success.
+static rtems_status_code lpc176x_check_edge_and_set_gpio_interrupts(
+ lpc176x_gpio_config( pin, LPC176X_GPIO_FUNCTION_INPUT );
+ lpc176x_set_falling_or_rising_interrupt( edge, pin_of_port, interrupt );
+ lpc176x_register_pin_and_callback( edge, pin, isr_funct );
+ status_code = lpc176x_install_interrupt_handler( edge );
+rtems_status_code lpc176x_gpio_config_input_with_interrupt(
+ && ( edge < LPC176X_GPIO_INTERRUPT_COUNT ) ) {
+ status_code = lpc176x_check_edge_and_set_gpio_interrupts( pin,
+ edge,
+ isr_funct );
+rtems_status_code lpc176x_gpio_set_pin( const lpc176x_pin_number pin )
+ if ( pin < LPC176X_MAX_PORT_NUMBER ) {
+ LPC176X_FIO[ port ].set = LPC176X_PIN_BIT( pin_of_port );
+rtems_status_code lpc176x_gpio_clear_pin( const lpc176x_pin_number pin )
+ LPC176X_FIO[ port ].clr = LPC176X_PIN_BIT( pin_of_port );
+rtems_status_code lpc176x_gpio_write_pin(
+ const bool value
+ rtems_status_code status_code;
+ if ( value ) {
+ status_code = lpc176x_gpio_set_pin( pin );
+ } else {
+ status_code = lpc176x_gpio_clear_pin( pin );
+inline rtems_status_code lpc176x_gpio_get_pin_value(
+ bool *pin_value
+ assert( pin < LPC176X_MAX_PORT_NUMBER );
+ *pin_value = ( LPC176X_FIO[ port ].pin & LPC176X_PIN_BIT( pin_of_port ) );
diff --git a/c/src/lib/libbsp/arm/lpc176x/include/gpio.h b/c/src/lib/libbsp/arm/lpc176x/include/gpio.h
index 35f34be..0000000
--- a/c/src/lib/libbsp/arm/lpc176x/include/gpio.h
+++ /dev/null
@@ -1,100 +0,0 @@
- * @file gpio.h
- * @brief API of the GPIO driver for the lpc176x bsp in RTEMS.
-#ifndef LIBBSP_ARM_LPC176X_GPIO_H
-#define LIBBSP_ARM_LPC176X_GPIO_H
-#include <bsp/lpc176x.h>
-#include <bsp/gpio-defs.h>
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
- * @brief Configures the pin as input or output GPIO.
- * @param dir Input or output.
- lpc176x_pin_number pin,
- lpc176x_gpio_direction dir
- * @return RTEMS_SUCCESSFULL if the configurations was success.
- lpc176x_gpio_interrupt edge,
- lpc176x_gpio_interrupt_function isrfunct
- * @brief Sets the output pin to 1.
- * @param pin The pin to set
-rtems_status_code lpc176x_gpio_set_pin( lpc176x_pin_number pin );
- * @brief Sets the output pin to 0.
-rtems_status_code lpc176x_gpio_clear_pin( lpc176x_pin_number pin );
- * @brief Sets the output pin to 0 or 1 according to value.
- * @param value the value to set.
- bool value
- * @brief Returns the value at the given input pin.
- * @param pin The pin where to read the value.
- * @param pin_value TRUE if the pin value was getted successfuly.
- * @return RTEMS_SUCCESSFUL if the pin value was getted successfuly.
-rtems_status_code lpc176x_gpio_get_pin_value(
- bool *pin_value
-#ifdef __cplusplus
-#endif /* LIBBSP_ARM_LPC176X_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/lpc176x/include/lpc-gpio.h b/c/src/lib/libbsp/arm/lpc176x/include/lpc-gpio.h
index 0000000..9cb23df
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc176x/include/lpc-gpio.h
@@ -0,0 +1,100 @@
+ * @file lpc-gpio.h
+ * @brief API of the GPIO driver for the lpc176x bsp in RTEMS.
+#ifndef LIBBSP_ARM_LPC176X_GPIO_H
+#define LIBBSP_ARM_LPC176X_GPIO_H
+#include <bsp/lpc176x.h>
+#include <bsp/gpio-defs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Configures the pin as input or output GPIO.
+ * @param dir Input or output.
+ lpc176x_pin_number pin,
+ lpc176x_gpio_direction dir
+ * @return RTEMS_SUCCESSFULL if the configurations was success.
+ lpc176x_gpio_interrupt edge,
+ lpc176x_gpio_interrupt_function isrfunct
+ * @brief Sets the output pin to 1.
+ * @param pin The pin to set
+rtems_status_code lpc176x_gpio_set_pin( lpc176x_pin_number pin );
+ * @brief Sets the output pin to 0.
+rtems_status_code lpc176x_gpio_clear_pin( lpc176x_pin_number pin );
+ * @brief Sets the output pin to 0 or 1 according to value.
+ * @param value the value to set.
+ bool value
+ * @brief Returns the value at the given input pin.
+ * @param pin The pin where to read the value.
+ * @param pin_value TRUE if the pin value was getted successfuly.
+ * @return RTEMS_SUCCESSFUL if the pin value was getted successfuly.
+rtems_status_code lpc176x_gpio_get_pin_value(
+ bool *pin_value
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_LPC176X_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/lpc176x/preinstall.am b/c/src/lib/libbsp/arm/lpc176x/preinstall.am
index 5c86c8b..8d6c4d3 100644
--- a/c/src/lib/libbsp/arm/lpc176x/preinstall.am
+++ b/c/src/lib/libbsp/arm/lpc176x/preinstall.am
@@ -113,9 +113,9 @@ $(PROJECT_INCLUDE)/bsp/gpio-defs.h: include/gpio-defs.h $(PROJECT_INCLUDE)/bsp/$
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gpio-defs.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gpio-defs.h
-$(PROJECT_INCLUDE)/bsp/gpio.h: include/gpio.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gpio.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/gpio.h
+$(PROJECT_INCLUDE)/bsp/lpc-gpio.h: include/lpc-gpio.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-gpio.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-gpio.h
$(PROJECT_INCLUDE)/bsp/can.h: include/can.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/can.h
2.6.2
