Tools for RTEMS 4.12
Thu Nov 5 14:56:55 UTC 2015
Hi Sebastian,
I see no problem with using the newer GCC assuming our development
cycle is probably still at least 1yr+. Until we get good automation
this is the case. Also, we are planning to apply to Google Code-In,
and bumping the tool versions could be a set of tasks. If you would
like to do one or a few as a sample, then we can have high school
students do the rest during the GCI program period.
On Thu, Nov 5, 2015 at 9:41 AM, Sebastian Huber
> Hello,
> I would like to add the tools for RTEMS 4.12 to the RSB. The question is
> which GCC version should we use? Since our release process is so slow I tend
> to use GCC 6 since it includes support for OpenMP and C++11 threads out of
> the box. I use it currently for development and it works quite good at least
> on ARM and PowerPC.
> devel mailing list
> devel at rtems.org
